Stator testing - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old April 24th, 2019, 04:22 AM Thread Starter
Vashway's Avatar
Member #268496
View Vashway's Photo Gallery(0)
Stator testing
Hello, I'm testing my stator because I think it my be cooking my voltage regulator. I have performed the stator tests as per the service manual for a 2008 rzr 800. The results are as follows: y1 to y2 resistance = .5 ohms (1 to 3 & 2 to 3 equal same number). The book calls for .19ohms +/- %15. Where as .5 ohm's is outside the tolerances has it gone bad? The continuity check for yellow wires to ground is "open" wich according to the book is good. Any help would be appreciated!
Vashway is offline
post #2 of 4 Old April 24th, 2019, 08:46 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Re: Stator testing
Take a look at https://www.rzrforums.net/rzr-800-sp...-charging.html
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is offline
post #3 of 4 Old April 24th, 2019, 10:46 AM Thread Starter
Vashway's Avatar
Member #268496
Originally Posted by CA 800 View Post
Thanks for the link! I saw where you posted the voltage readings and mine are in those tolerances. So I'm thinking if the voltages are good then I'm okay? Thanks again!
Vashway is offline
post #4 of 4 Old April 24th, 2019, 12:05 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Re: Stator testing
Was your .5 ohm reading at the stator plug, or up at the voltage regulator.
If at the voltage regulator, the higher reading could be due to resistance of wires.
CA 800 is offline
