Show me how you secure your RZR on a trailer for towing - Polaris RZR Forum - RZR Forums.net
 27Likes
post #1 of 68 Unread April 23rd, 2019, 09:05 PM Thread Starter
RZR_Pilot's Avatar
First Name: -Jeff
Member #261642
View RZR_Pilot's Photo Gallery(0)
Hey all, I am new to the SxS/ UTV world and just picked up my new flat-bed trailer yesterday. Never have attempted to secure a load this size before, and curious what is the best way to do so. Lets see your set-up!
Life is short, drive fast!
RZR_Pilot is offline
post #2 of 68 Unread April 23rd, 2019, 09:10 PM
Feldhege's Avatar
First Name: Robb
My RZR: 2017 Polaris RZR S 900
Member #268354
View Feldhege's Photo Gallery(0)
Re: Show me how you secure your RZR on a trailer for towing
I dont have a picture right now, but I use 4 ratchet straps. One off each hold by the hitch and one to each mounting point on the lower part of the front bumper. I angle them to the sides of the trailer and make sure it is in park. Just got back from a 3.5 hour drive up north and it worked perfectly. I also keep the engine over the front axle of the trailer for weight distribution. I have a dual axle flatbed trailer.
RZR_Pilot likes this.
Feldhege is offline
post #3 of 68 Unread April 23rd, 2019, 09:17 PM
jeremywatco's Avatar
My RZR: '18 XP4 1000
Member #234434
View jeremywatco's Photo Gallery(0)
I used to use ratchet straps to the frame. Now I use Mac tiedowns wheel nets and tracks. Waaaaaaaay better. My rzr never moves now. Always tight and stays put.
Sent from my Pixel 3 using Tapatalk
UtahMarv, ckr, RZR_Pilot and 1 others like this.
jeremywatco is offline
post #4 of 68 Unread April 23rd, 2019, 09:34 PM
bnemmie's Avatar
First Name: Bret
My RZR: 2015 RZR 900 Trail
Member #83097
View bnemmie's Photo Gallery(0)
Tire bonnets on the e track I installed on my trailer deck. The fastest and most secure I have ever strapped something with wheels down.
bnemmie is offline
post #5 of 68 Unread April 24th, 2019, 02:32 AM
pete4x4's Avatar
Member #237625
View pete4x4's Photo Gallery(0)
Ez straps over the tires
pete4x4 is offline
post #6 of 68 Unread April 24th, 2019, 05:26 AM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
E track the entire length of the trailer and straps over the tires.
Michale is offline
post #7 of 68 Unread April 24th, 2019, 07:14 AM
rottendiesel's Avatar
Member #233994
View rottendiesel's Photo Gallery(0)
I know that many people simply use straps over the tires, and I'm sure they will all swear that it's perfectly safe - and it might be - but strapping that way does nothing to prevent lateral shift. Tire bonnets, in my opinion, are much safer and more secure.
Sent from my Pixel 2 XL using Tapatalk
ckr, Ringo and reginal98 like this.
rottendiesel is offline
post #8 of 68 Unread April 24th, 2019, 07:41 AM
pete4x4's Avatar
Member #237625
You might be right. But till now nothing haven't shifted laterally ..even doing wash road...
I was skeptical at first but when I 've tried it and tried to push it laterally....only ting that it wanted to do is make the all thing tumble over with the trailer. So if someting would happen...the sxs and the trailer would tip over in one part...if that happens...I'll probably be in deep sh$^%@...
UtahMarv likes this.
pete4x4 is offline
post #9 of 68 Unread April 24th, 2019, 07:53 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
What if a tires going down and suddenly you have to make a drastic avoidance maneuver.
One tire down....strap is not holding could start a domino effect?
Im still Old school. Tie down to frame all four corners. 2 HD ratchet straps. Hooks with buckles.
Im concerned for the other guy if my-load comes off.
Im in no hurry. 5 minutes Id guess it takes me to ratchet down.
Bizill and BeltFed like this.
RickRou56 is offline
post #10 of 68 Unread April 24th, 2019, 08:04 AM
pete4x4's Avatar
Member #237625
I’m still Old school. Tie down to frame all four corners. 2” HD ratchet straps. Hooks with buckles.
I’m concerned for the other guy if my-load comes off.
I’m in no hurry. 5 minutes I’d guess it takes me to ratchet down.
Still have 3 straps holding tight.
On the other hand I had more issue with straps on the frame...
The thing is with strapping on the frame the suspension moves and can make the car move because at some point the strap comes loose.
That why I went with the straps on the tires. Wanted to go with the bonnet style...but for my rig it didn't worth the extra $..but if I had a 4 seaters...I surely would go with the bonnet style for the extra peace of mind.
pete4x4 is offline
post #11 of 68 Unread April 24th, 2019, 08:24 AM
RickRou56's Avatar
Member #28887
I agree with bonnets. And 3 tires still holding probably gonna do the trick.
I pull mine down about 2 into the suspension stroke. It doesnt move. Unless a tire is going down!
Im also pulling side to side and front to back.
Guy who does my shocks says it doesnt hurt anything.
And loose straps yes a problem.
That is why I use HD buckles on the hooks. And ez track hooks with the HD O Ring.
Hey 4 tires 4 straps. 4 straps to the frame.
We are way ahead of the guy with a $6.99 set of Harbor Freight 1 Dirt Bike Cam buckles.
And even then they only use 1-2.!!!
post #12 of 68 Unread April 24th, 2019, 08:27 AM
Total Loss's Avatar
Member #4844
View Total Loss's Photo Gallery(33)
This...
Or as I do- I loop through the suspension points so the car can float.
I also put an extra emergency strap to the front so the car cannot slip rearwards.
2 things I have see with 4 straps- some people use the same tie down point for 2 straps-frame hook front and rear. Don't like that either in case the tie down point breaks.
Remember-if unfortunately you get into a rear ender collision, the straps can break and launch the car into your tow rig.
Happened to my friend on a smaller scale (bikes) when some moron pulled out in front of him in his camper and he T-boned him- broke most of the straps.
I use 12k straps for the car. X 4
"When you are going through hell, just keep going"
Winston Churchill
Total Loss is offline
post #13 of 68 Unread April 24th, 2019, 08:57 AM
dajo's Avatar
First Name: Dave
My RZR: 2010 RZR4 Street legal & 2011 XP 900(Arizona)
Member #19884
View dajo's Photo Gallery(0)
Hard to visualize. Loop through suspension points? can you post a picture?
dajo is offline
post #14 of 68 Unread April 24th, 2019, 09:05 AM
Total Loss's Avatar
Member #4844
No photos available- basically I have loop racket straps that I loop around the lower a/arms in front and trailing arm in the rear. I used to loop them through the wheels like the tow truck guys do but my new wheels are too small openings.
Winston Churchill
post #15 of 68 Unread April 24th, 2019, 09:37 AM
idiggplants's Avatar
Member #258450
View idiggplants's Photo Gallery(0)
i use 4 of these (they get as low as 25 for a pair)
https://www.amazon.com/Erickson-3441...web_3027725011
which are strictly used for tying down atvs.
one on each corner of the machine. one end goes on the outer a arm, other goes to the trailer tie down point. similar to wheel bonnets in that it allows the rzr suspension to help out the trailer suspension. no chance of losing a strap when the suspension compresses over a road bump. but way cheaper than wheel bonnets.
2011 rzr 800 LE - EPS
idiggplants is online now
Help...Secure RZR to open trailer cuffem2 General RZR Discussion 13 May 22nd, 2015 07:40 PM
Polaris Adds Multi-Passenger Vehicle to the RZR Family awd4life Polaris RZR News 22 January 22nd, 2015 06:25 PM
All new 2015 rzr accessories awd4life General RZR Discussion 6 October 1st, 2014 11:52 AM
RZR in a short bed truck ronald2009 General RZR Discussion 38 August 4th, 2010 05:48 PM
