Carry a fire extinguisher a cautionary tail - Page 2 - Polaris RZR Forum - RZR Forums.net
 23Likes
post #16 of 44 Old April 23rd, 2019, 01:57 PM
Macs Dad's Avatar
My RZR: 2008 Ranger RZR
Member #8581
Re: Carry a fire extinguisher a cautionary tail
Originally Posted by idiggplants View Post
Originally Posted by Macs Dad View Post
https://www.amazon.com/dp/B07HB3TJQV...3-e19ee3aed6a0
Here's a fire extinguisher and mount. Thank goodness you had beer. LOL.
there is nothing to indicate that that fire extinguisher comes with it. i believe that is only the mount.
can anyone tell me what type of extinguisher i need? ive read that the ones you use in the kitchen are no good cause they use co2 to displace the oxygen. so a small breeze makes them useless outside? or maybe im mistaken. id like an extinguisher to keep in my trunk box/cab. eventually ill spend the $ for a mount, but for now, it's better than nothing.
Scroll down the page and pic the one you prefer.
Macs Dad is offline
post #17 of 44 Old April 23rd, 2019, 03:02 PM
rottendiesel's Avatar
Member #233994
View rottendiesel's Photo Gallery(0)
You must live a long way from the beer store if you needed to carry extra gas to get there.
This thread should be titled "Don't carry gas unless you are going to need it a cautionary tale"
Sent from my Pixel 2 XL using Tapatalk
adam_s05 likes this.
rottendiesel is offline
post #18 of 44 Old April 23rd, 2019, 03:18 PM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Originally Posted by Doin It View Post
Note to all SxS owners, DO NOT CARRY EXTRA FUEL IN THE BACK OF YOUR SXS.
I think its safe to carry extra fuel if done properly & safely. A plastic gas can tied down with bungee cords or motorcycle straps is not the proper way to do it.
I use a Rotopax with the Rotopax mount on the roll bar. I allow room for fuel expansion (don't over fill the tank to get an extra 1/2 gallon) and use OEM Rotopax cap & filler with seals in good shape. I have a spare set of seals and filler spouts that are carried on the RZR.
I also carry 2 Halon fire extinguishers that are inspected every year. I work at a place where we have to have our fire extinguishers inspected every year and they can inspect, recharge & certify Halon units as needed. One is out back on the roll bar the other is in the cab.
Rockymtn5280 is offline
post #19 of 44 Old April 23rd, 2019, 03:34 PM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
should be carrying 2 fire extinguishers, one you can reach in the cockpit, and one on cage that can be reached from outside the machine.
Rockymtn5280 likes this.
GimpyRZR is offline
post #20 of 44 Old April 23rd, 2019, 05:58 PM
TheRealBuzz's Avatar
Member #8930
View TheRealBuzz's Photo Gallery(0)
Curious to know if this machine had the updated heat sheild.
TheRealBuzz is offline
post #21 of 44 Old April 24th, 2019, 06:58 AM
Bullitt427's Avatar
Member #133409
Originally Posted by Bullitt427 View Post
You want at least a CLASS AB extinguisher and 2.5lb or more. Go with a brand that sells a metal nozzle as well. The plastic nozzle and handle will break on a RZR
thanks.
this doesnt really say how many lbs it is.
https://smile.amazon.com/dp/B000UHP9...v_ov_lig_dp_it
and i see it is rated 10-bc? is that better or worse than ab?
I would consider that extinguisher more as a Marine unit. Class A is general consumables, which means it's good for grass, wood and paper.. common stuff found near trails. Class B is for flammables. Class C is electrical.
Ideally you'll want Class ABC, but I would look for Class AB for the trails.
The "10" before the class is either/or the square footage or the amount in seconds the extinguisher will output.
Rockymtn5280 and idiggplants like this.
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #22 of 44 Old April 24th, 2019, 07:05 AM
idiggplants's Avatar
Member #258450
View idiggplants's Photo Gallery(0)
im not sure what that means.
2011 rzr 800 LE - EPS
idiggplants is offline
post #23 of 44 Old April 24th, 2019, 08:14 AM
Steamfitters38's Avatar
Member #225146
Pick a class ABC Extinguisher. 5lbs would be good. No need to spend hundreds, you’ll have to replace it eventually. They are warrantied good one year out from the date stamped on the tag.
Denver likes this.
Steamfitters38 is offline
post #24 of 44 Old April 28th, 2019, 11:15 AM Thread Starter
MinnesotaEric's Avatar
Member #263712
View MinnesotaEric's Photo Gallery(0)
Originally Posted by RzrDan13 View Post
MinnesotaEric maybe carry this extinguisher it’s dual purpose. Attachment 575712
Aw man, you're killin' me! LOL
Eight days after my fire run and my RZR is back to making engine noises again–I just need to slap the Tupperware back on and screw it down and start editing a video...
From this
To this
MinnesotaEric is offline
post #25 of 44 Old April 28th, 2019, 11:34 AM Thread Starter
Member #263712
Originally Posted by bmerwin View Post
Any suggestions on a brand/mount to go with?
This is the fire extinguisher kit that I just purchased.
https://www.rockymountainatvmc.com/p...nguisher-kit-p
Liv59047 and bmerwin like this.
post #26 of 44 Old April 28th, 2019, 12:18 PM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
I've seen his videos on YouTube. This was a salvaged machine that he repaired frame and cage damage on. I doubt the latest recalls have been performed.
BWXT is online now
post #27 of 44 Old April 28th, 2019, 06:05 PM Thread Starter
Member #263712
Thanks for watching! All my RZR really needed was a new roll cage. I couldn't believe that it was sitting at my local auction. After I replaced the roll cage I put it on an alignment rack and everything looked pretty good.
Anyway, here is what I had to do get my firebug RZR running again.
post #28 of 44 Old April 29th, 2019, 10:15 AM
UTVFrank's Avatar
Member #28410
View UTVFrank's Photo Gallery(0)
I run one on each D Pillar, and one in the center between the seats. With the turbo cars, a fire is likely to start on the passenger side.
UTVFrank is offline
post #29 of 44 Old April 29th, 2019, 12:02 PM
timoloco's Avatar
My RZR: XPT
Member #71730
View timoloco's Photo Gallery(0)
Don't carry extra gas on these machines. pretty simple
2017 Polaris RZR XP4 Turbo- UTV inc. Destroyer cage, Polaris front and rear bumpers, Polaris lower door assemblies, Polaris 4500lbs winch, Polaris side mirrors, Rigid Industries midnight edition 12" light bar, Ricochet offroad skid plates, Rockford Fosgate Stage 5 system, Shock Therapy Stage 4 springs, PRP GT/SE seats, PRP 4-2 harnesses, PRP upper and lower door bags, MBRP Power Tech4 exhaust, NRP gated shifter, Super ATV rock sliders, Method 401 14" wheels, MOTO Race X-ROX-DD 32" tires, Walker Evans sway bar end links, EMP tinted half windshield
Past units- 2016 Orange Madness XP Turbo, 2014 XP 900 Orange Madness
timoloco is offline
post #30 of 44 Old April 29th, 2019, 02:42 PM
Army Signals Retired
Mike-in-Kingston's Avatar
My RZR: 2018 RZR 900
Member #260880
View Mike-in-Kingston's Photo Gallery(0)
This is where I mounted my RotoPax. And my fire extinguisher on the inside of the cab.
Many of the trails that we ride, require you to have extra gas before you hit the next gas station.
ID:	576034   Click image for larger version
ID:	576038   Click image for larger version
2018 RZR 900 Trail. KIMPEX 27x9x12, Poly sport roof in black, Tusk glass full windshield with manual wiper, poly rear panel, lower door inserts, front deluxe bumper, HD 3,500 lb. integrated winch. SuperATV 2in lift, Bronco 1in wheel spacers, extended fenders, low profile rock sliders, Tusk spare tire mount.
Mike-in-Kingston is offline
need fire extinguisher for my 1000 whats the best Joezrzr RZR XP 1000 61 October 3rd, 2017 08:12 PM
Pro Armor Fire Extinguisher Kit W/ mount Adrenaline Cycles Adrenaline Cycles 11 March 22nd, 2017 07:10 AM
1.75" black clamp on fire extinguisher mount UTV Inc. UTV Inc 11 August 23rd, 2013 04:31 PM
Carry a fire extinguisher wdrthird General RZR Discussion 11 March 8th, 2010 03:24 PM
