ATV gates - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old April 14th, 2019, 01:57 PM Thread Starter
bpbess1956!'s Avatar
Member #265558
View bpbess1956!'s Photo Gallery(0)
Question ATV gates
I saw an old discussion of ATV gate widths vs RZR width. They were asking specifically about the gate width, but there was no definitive answer. I just have a general question of the amount of play (in general) in gate widths when you take a 50" RZR through them. Are your tires rubbing the posts as you go through or is there some play? I would think that if they are EXACTLY 50", they probably don't want even trail RZRs going through.
I just bought a RZR with 1" wider tires, so it appears that I will be 51" (I don't know exactly, because it is now 55" with 2" spacers.
I live in Colorado.
bpbess1956! is offline
post #2 of 9 Old April 14th, 2019, 02:06 PM
pgiannetto65's Avatar
Member #266074
View pgiannetto65's Photo Gallery(0)
Re: ATV gates
I think they 50ish”. I think some are a tad over 50”. A stock trail Rzr is a little over 50”. I’ll find and post a video a guy made who rides in AZ. He shows his trail Rzr going thru 50” gates.
2016 Polaris Rzr EPS Trail Fox Edition
pgiannetto65 is offline
post #3 of 9 Old April 14th, 2019, 02:11 PM
Member #266074
Re: ATV gates
post #4 of 9 Old April 14th, 2019, 03:02 PM
Rotzilla's Avatar
First Name: Steve
My RZR: 2015 RZR 900 trail
Member #18806
View Rotzilla's Photo Gallery(0)
Re: ATV gates
Up in Woodland park I ran into gates that where dang near 50", my 2011 had popo sliders on it and I could not fit through, I was around 51".
The gates around Buna Vista are much wider about 54" I would guess.
Most of riding areas do have bypasses to around the gates, whats the purpose?? who knows. I ride with persons driving S's and 1000 turbos and very seldom do we have any issues.
Rotzilla is online now
post #5 of 9 Old April 14th, 2019, 03:51 PM
william_04_x's Avatar
Member #16899
View william_04_x's Photo Gallery(0)
Re: ATV gates
Paiute trail in Utah has 50" restriction gates. They are tight. If my stock 50" RZR is a little off camber it will rub the tubing at shoulder height area.
A lot of times there are other legal routes around the restricted areas of the trail.
2010 800 White LE
2017 S1K Indy Red
william_04_x is offline
post #6 of 9 Old April 14th, 2019, 05:17 PM
Zbird's Avatar
First Name: Dan
My RZR: 2014 800
Member #259732
View Zbird's Photo Gallery(0)
Re: ATV gates
I don't see what State you are riding in but here in PA they vary quite a bit. In fact in the same area they vary. For instance in Potter County the Denton Hill area near Cherry Springs I encountered one gate that my 50 inch barely fit through yet at another access point to the same "trails" and I say that sarcastically because the trails are mostly pretty wide roads we snowmobile on and a full size truck could travel on any of them so why they are restricted to 50 inch is beyond me. Anyway back my point... at another gate you could fit a 60 inch through with no problem. I only rode there one time because I found it quite boring riding on those dirt roads seeing all kinds of real trails leading off them with No ATV signs at all of them.
Zbird is online now
post #7 of 9 Old Yesterday, 08:03 AM Thread Starter
Member #265558
Re: ATV gates
I live in Colorado. I just called the Montrose Public Lands Office and they said without pause that they are 50". I suppose that they are hit and miss, but it makes it difficult to plan without knowing.
post #8 of 9 Old Yesterday, 09:30 AM
MN1965's Avatar
My RZR: 2017 S 1000
Member #220258
View MN1965's Photo Gallery(0)
Re: ATV gates
They sure as heck aren't standardized around here. There is one I'm aware of in Central MN that is legal for Class II (60") but gets a bit tricky with an S1000. The way it is set up requires you to turn while part way through the gate to avoid a huge tree in front of you. I don't think a 4 seat would be able to do it without squashing a door against the post, despite it being technically legal.
MN1965 is offline
post #9 of 9 Old Today, 07:21 PM
Oldbiker's Avatar
My RZR: 2017 900 S
Member #69733
View Oldbiker's Photo Gallery(0)
Re: ATV gates
I believe the metal ones installed by the local atv club are 51" wide on the Grand Mesa. I understand there were numerous complaints made to the forest service by hunters that they could not get their loaded machines through the uprights so the atv club (which maintains and builds most of the trails for the forest service) was told to spread the top portion of the uprights. So now the tire width is still 50" but the upper machine body can be wider. It seems that each federal agency and local jurisdiction interprets the 50" rule as they deem appropriate and source their restrictors accordingly. I believe they also enforce those regulations differently so it ends up being 'rider beware'.
2017 900 S - 28x10 Sedona Rock-A-Billys on 14x7 wheels.
Oldbiker is online now
Tags
atv gate , width
[UPDATED 2018] UTV INC RZR Wheel Bearing Greasing Tool UTV Inc. UTV Inc 146 Yesterday 05:42 PM
Gladiator ATV ATR Now Available Discount Tire Wheels and Tires 0 November 7th, 2016 01:05 PM
Front diff and driveline vibration. Me vs polaris luckylawnboy RZR XP 1000 47 May 30th, 2015 12:23 PM
