Two battery setups. - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old April 14th, 2019, 11:11 AM Thread Starter
Vashway's Avatar
Member #268496
View Vashway's Photo Gallery(0)
Two battery setups.
Hello, I recently purchased an 08 RZR 800 with two batteries and an isolator between them. My question is should both batteries be grounded to frame or would this create a "multi point" grounding problem? Thanks.
Vashway is offline
post #2 of 5 Old April 15th, 2019, 07:00 AM
redbeard719's Avatar
Member #211393
View redbeard719's Photo Gallery(0)
Re: Two battery setups.
My second battery ground is tied to my first (main) battery ground lug. No issues with this set up.
redbeard719 is offline
post #3 of 5 Old April 15th, 2019, 10:48 AM Thread Starter
Vashway's Avatar
Member #268496
Nice setup! Thanks for the pic!
Vashway is offline
post #4 of 5 Old April 15th, 2019, 07:27 PM
machineguy's Avatar
Member #264262
View machineguy's Photo Gallery(0)
The text book method would be to have both batteries grounded at the same spot on the frame. Will you ever see a difference if each is grounded at a sep location on the frame, (creating a ground loop) or wired as above....I doubt it.
2017 XP 1000. All stock
machineguy is offline
post #5 of 5 Old April 16th, 2019, 08:31 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
There is also an Electrical section under the Technical sub-forum to take a look at.
https://www.rzrforums.net/30-technical/
XB3 fire extinguisher, in cab. RAM-mounted Samsung Tab GPS. Larsonator DIY dual rate spring kit and Schmidty Racing resi end caps. Garage Products bushings. BugBuster mesh windscreen and rear mesh screen. Outerwears on R2C air filter and clutch intake. 3500# Winch, parking brake. Polaris DVR mirror & Drift Innovation action camera. PRP harnesses. Roof. DIY mud flaps. Tusk front bumper. UHMW A-arm guards. Hunterworks Gates Carbon belt.
Denver is offline
Odyssey Battery Specifications FNG Lighting, Stereo and Electrical 0 April 6th, 2015 02:11 PM
Battery setups TRzr4 RZR XP 4 1000 9 October 22nd, 2014 11:37 AM
Single battery setups - What do you use? safehaven Lighting, Stereo and Electrical 26 February 14th, 2013 02:38 PM
anyone have this problem? bikermike Engine and Drivetrain 8 July 14th, 2011 10:42 AM
