Samsung Tab A for GPS - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old January 3rd, 2019, 07:35 PM Thread Starter
bpinner's Avatar
First Name: Bob
My RZR: 2013 RZR 800S
Member #51038
View bpinner's Photo Gallery(0)
Just purchased a Samsung Tab A with 16GB to use as a GPS. First off it doesn't load a complete map as the screen will have blanks. Tried this on BCN and GAIA. Does the memory need to be expanded? Second, this unit does not seem to have the magnet sensor so the compass apps will not work. Does this effect how the GPS works?
Thanks,
Bob
bpinner is offline
post #2 of 8 Old January 3rd, 2019, 07:52 PM
nateburch's Avatar
First Name: Nathan
My RZR: 2016 RZR 1000 S
Member #85715
View nateburch's Photo Gallery(0)
Re: Samsung Tab A for GPS
16 GB should be fine for maps, but maybe other programs are using all of the space. I don’t use either of them; I use Orux. In orux, you can set it to save the offline maps on the memory card.
My old Samsung didn’t have the compass either, but GPS will show your direction of travel once you start moving. I upgraded my tablet to have a compass and a better screen.
nateburch is online now
post #3 of 8 Old January 3rd, 2019, 07:56 PM Thread Starter
bpinner's Avatar
First Name: Bob
Member #51038
Thanks nateburch, what did you upgrade to?
bpinner is offline
post #4 of 8 Old January 3rd, 2019, 07:59 PM
jeremywatco's Avatar
My RZR: '18 XP4 1000
Member #234434
View jeremywatco's Photo Gallery(0)
I have same setup as you. I bought a sdcard but more for music storage.
I use BCN and it's great. There is a setting in there to not attempt to use compass for heading and to use gps track direction instead. Flag that and you are good to go.
Sent from my Pixel 3 using Tapatalk
jeremywatco is offline
post #5 of 8 Old January 3rd, 2019, 08:01 PM
Member #234434
BCN Setting is under : Compass and Rotation > Compass Algorithm > Rotation Vector I think. Mess with them until it points you the direction you are moving.
post #6 of 8 Old January 3rd, 2019, 08:05 PM
nateburch's Avatar
First Name: Nathan
Member #85715
I think I had the exact same tablet as you. My new tablet is a Samsung Tab S2 9.7”. The screen is amazing. I have it in an otterbox case, and the screen has a resolution of 2048x1536, and is really bright. I even had to upgrade the USB charger in my RZR to keep it charged. I couldn’t get the lighter and charger to charge this new tablet. I use this charger:
https://www.amazon.com/YonHan-Charge...ger+waterproof
post #7 of 8 Old January 3rd, 2019, 08:31 PM Thread Starter
bpinner's Avatar
First Name: Bob
Member #51038
Thanks everyone for the help. Will be on the trails tomorrow and will see how it does.
bpinner
bpinner is offline
post #8 of 8 Old January 3rd, 2019, 09:52 PM
Medi0gre's Avatar
Member #256750
View Medi0gre's Photo Gallery(0)
Originally Posted by jeremywatco View Post
BCN Setting is under Compass Algorithm > Rotation Vector I think. Mess with them until it points you the direction you are moving.
That's not quite correct, You want to go Settings> Compass and Rotation Options > Map/Pointer Rotation Direction > Choose Moving Direction.
Compass algorithms don't affect anything as there is no compass in the device. Took me a good long while to get that figured out and working correctly
Also in settings >Display Options > Enable Show My Location Button. This will give the ability to use four different map orientations, one where the map follows North all the time or alternatively your heading direction, which I prefer. etc.
Medi0gre is offline
Brand New Unlocked Blackberry Curve 8900....$250 phill296 Want to Buy 1 April 14th, 2009 09:20 AM
