SuperAtv Rhino Prop Shaft and A Tacoma Bearing Carrier - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 1 Post By Splash24
  • 1 Post By Bullitt427
post #1 of 13 Old December 21st, 2018, 10:01 AM Thread Starter
dirtysided0wn's Avatar
Member #212897
View dirtysided0wn's Photo Gallery(0)
Have upgraded to a SATV Rhino U Series prop shaft. Had previously ordered their billet carrier bearing. While it's better, I still have some noise and growling. SATV even tells you there is going to be noise when using a solid mounted carrier bearing. Has any one else run a rhino prop shaft and tried a non satv carrier bearing? Would like to go back to the Tacoma bearing and silicone to help cushion the vibes that are left. They say only their bearing will work on the rhino shaft, but can't get a clear reason why the oem style or Tacoma wouldn't work...
It better than it was but still not right for the $$$ spent.
dirtysided0wn is offline
post #2 of 13 Old December 21st, 2018, 12:07 PM
Contact: 855-743-3427
SuperATV's Avatar
First Name: SuperATV
Member #7943
Re: SuperAtv Rhino Prop Shaft and A Tacoma Bearing Carrier
Make sure you grease the bearing really well, and check to see where the growl is coming from. Most of the time its the ring or pinion gear bearing in the diff, and it transfers through the drive line into the carrier bearing.
SuperATV Official Website
SuperATV is offline
post #3 of 13 Old December 21st, 2018, 12:31 PM Thread Starter
Member #212897
Removed the seals on the carrier bearing and hand packed the bearing. Replaced all the bearings in the front diff with the Sandcraft SKF kit. Upgraded the sprague and armature while I was in there too.
There is some disconnect between your instructions and install video on YouTube for the carrier bearing I think. The video looks like they are installing on a non turbo 1000, like I have. At the end when they install the cover with the zerk, the SuperAtv is towards the back of the machine. Per the instructions that would be how a turbo model would be orientated.....Not sure if that would make a difference or not.
I have my "SuperAtv" to the rear like the video, the bearing grease ring appears centered in the carrier grease ring, but possibly 180 out of phase. Don't know if that would make a difference.
I feel I would have felt the bearing fighting to be seated in the carrier if it was in the wrong slot or backwards.
Or perhaps I have an different version of the carrier and logo was etched in a different orientation.
So I guess, possibly my bearing is on the prop shaft backwards, and the carrier is in the machine backwards for the model, but it is oriented in the carrier the correct way, which i would think would be the most important thing....
post #4 of 13 Old December 21st, 2018, 02:01 PM
SuperATV's Avatar
Member #7943
Your 1k ant the Turbo S models have the logo towards the front of the machine and the basic Turbo models should go towards the rear, but...they'll work in either direction if you happen to set it up the other way. I'll check that video to make sure we didn't do it backwards.
SuperATV is offline
post #5 of 13 Old December 21st, 2018, 02:23 PM Thread Starter
Member #212897
Ok, so that then is not causing the noise, the diff isn't either. Why will the Toyota Tacoma style not work? That way I can get some damping back?
It seem like the high dollar CCI and RCV use the higher quality OEM style approach over a solid one like this?
post #6 of 13 Old December 21st, 2018, 09:20 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Following
Dstew619 is offline
post #7 of 13 Old March 1st, 2019, 02:21 PM
Mingoxj's Avatar
Member #232865
View Mingoxj's Photo Gallery(0)
Did anyone fix this problem yet or find out if I can run a factory carrier bearing I just install the rhino prop on my 18 rzr 1000 and vibrates and growls worse than stock please help !
Mingoxj is offline
post #8 of 13 Old March 1st, 2019, 04:48 PM
mattmanstroked's Avatar
First Name: matthew
My RZR: 2016 900S
Member #40089
View mattmanstroked's Photo Gallery(0)
I was thinking the same thing when I replaced my carrier bearing with superatv one. The rubber acts as a damper. Vehicles usually have a rubber mounted carrier bearing.
Better quality bearing in stock assembly is probably all most of us needed.
mattmanstroked is offline
post #9 of 13 Old March 1st, 2019, 05:01 PM
Mingoxj's Avatar
Member #232865
I just wanted the heavy duty shaft. Because my u joints were Getting a little sloppy so I figure I’d do it once and be done. I just tried to regrease it took it for another ride and and still vibrates something terrible
Mingoxj is offline
post #10 of 13 Old April 14th, 2019, 05:45 PM
Splash24's Avatar
My RZR: XP 4 1000 High Lifter
Member #185089
View Splash24's Photo Gallery(0)
Ordered superatv carrier bearing and both prop shafts (preventative, had no vibration with stock). Installed with much care, filmed the imbalance and vibration at front diff, sent it back to Superatv, they sent another complete set up. Same issue of vibration and visible imbalance. Unfortunately for those of us looking for an upgrade... Superatv isnít there yet, they still need some R&D on the prop shafts. Friend installed same setup at his shop, same result. Heíll be sending his back also. Now waiting for their response... will report back if they donít handle the issue after giving a 2nd chance. Looks good, installs good (photos), but not a viable solution with excess vibration (video link).... would clearly destroy my front diff bearing over time.
https://www.dropbox.com/s/my0iag1vd0...37.02.mov?dl=0
ID:	575192Click image for larger version
ID:	575194Click image for larger version
Dstew619 likes this.
Splash24 is offline
post #11 of 13 Old April 14th, 2019, 06:10 PM
Dstew619's Avatar
Member #174273
That is unfortunate to hear, I was looking to buy it before next winter (dune season). SuperATV do keep us updated on findings and changes made. Otherwise Iíll be going with Sandcraft
Dstew619 is offline
post #12 of 13 Old April 15th, 2019, 05:56 AM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Following as well
Rockymtn5280 is offline
post #13 of 13 Old April 15th, 2019, 06:54 AM
Bullitt427's Avatar
Member #133409
A solid mount doesn't seem like a good idea, especially in regards to vibration. Every vehicle with a 2-piece driveshaft (cars, trucks, semis, heavy equipment and OEM Polaris) has a rubber mounted carrier bearing.
Splash24 likes this.
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
RCV Ultimate CV Prop Shaft for Polaris XP1000 & RZR XP Turbo from PRO UTV PARTS craigstumph Pro UTV Parts 51 July 11th, 2019 03:52 PM
RZR 800 prop shaft easier removal tip highpocket74 RZR 800 Specific Discussion 11 June 19th, 2019 02:55 PM
CHEAP carrier bearing fix for all RZRs HawkEng Hawk Engineering Inc. 41 November 28th, 2018 03:56 PM
Sand craft carrier bearing Yarmer RZR XP 4 1000 44 February 4th, 2017 08:17 PM
How to fix your 2011 Prop Shaft bearing for good Dangerous Dan RZR XP 900 0 December 26th, 2013 10:05 AM
