Slow speed steering issues - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Gene Bond
post #1 of 6 Old November 8th, 2018, 11:07 AM Thread Starter
tbone74's Avatar
First Name: Tony
My RZR: 2018 XP4 1K
Member #260498
View tbone74's Photo Gallery(0)
Hi all, I recently purchased a new 2018 xp4 1k. I have noticed that when I want to turn sharp going very slowly, for example turning around on a trail, the front tires don't "bite" and the machine just kind of drifts in the direction I am turning if that makes sense. It almost feels like there isn't any weight on the front tires. Could this be an issue with the settings on the suspension? I haven't messed with anything, or is this just normal. BTW the car turns just fine when at speed.. Thanks for your assistance!
tbone74 is offline
post #2 of 6 Old November 8th, 2018, 11:37 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Slow speed steering issues
Sounds pretty normal, the turning radius on a 4 seat isn't optimal to begin with, and you have to turn it with the throttle pretty often. At slow speed on loose soil the rear tends to push the fronts through the dirt
2018 XPT4 - Bailey
RWB713 is offline
post #3 of 6 Old November 8th, 2018, 02:48 PM
Gene Bond's Avatar
First Name: Gene
My RZR: 900 EPS Trail
Member #243386
View Gene Bond's Photo Gallery(0)
It's a symptom of the locked rear axle. That's another reason I like the Turf Mode on my 'Trail
The rear wheels are both trying to push forward at the same speed, so one of them has to slide to make the turn.
RWB713 likes this.
Gene Bond is offline
post #4 of 6 Old November 9th, 2018, 08:30 AM
moore3cam's Avatar
My RZR: 2017 1000 XP LE
Member #195793
View moore3cam's Photo Gallery(0)
If you have Bighorn tires I would also say that is a symptom or known downside of them. They aren't the best at tracking and tend to push while cornering. It happens at higher speeds as well.
For me that's probably the biggest issue with the tread design.
2017 RZR 1000 XP LE w/ Ride Command
SOLD 2013 Sportsman 850 XP HO EPS
SOLD 2003 Sportsman 700 Twin, 26" Mud Lite XTRs
SOLD 2000 Honda Rancher 350 ES, 26" Outlaws
Kawasaki Bayou 220
Honda ATC 3 Wheeler
moore3cam is offline
post #5 of 6 Old November 9th, 2018, 09:43 AM
Gene Bond's Avatar
First Name: Gene
Member #243386
I have noticed that the Bighorns are not that great for sideways traction as well. They seem to slide down into the ruts a little too easily for my liking. I don't know why I have them on all 4 of my machines??? Just keep forgetting about it I guess. Or, 'The devil you know'...
post #6 of 6 Old November 9th, 2018, 11:36 AM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
Pit it in AWD and the problem almost goes completely away at speed or slow. At least thatís my experience. My XP handles much better in AWD.
BWXT is offline
Deeper Explanation of Shift RPM Hunterworks Hunterworks 18 June 13th, 2017 06:55 AM
Why top speed is important on clutching Hunterworks Hunterworks 2 August 28th, 2016 07:23 AM
2015 Rzr 900 S EPS - Power Steering Issues ! Olson55 RZR S 900 1 July 2nd, 2016 11:36 AM
2014 xp1k power steering issues Bmaher Community Help 1 June 11th, 2016 02:38 PM
steering issues 4strokejunkie Suspension 0 July 6th, 2013 03:51 PM
