Coolant won't circulate, please help - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old September 29th, 2018, 07:11 PM Thread Starter
blazinrzr's Avatar
First Name: Ben
My RZR: '11 XP
Member #16793
View blazinrzr's Photo Gallery(0)
Was driving my 2011 xp 900 in Pismo and was on the gas hard when the coolant hose below the header on the front side of the engine blew. I immediately stopped and shut it down (I thought I was on fire). I replaced the hose filled the system with coolant, then removed the upper hose the radiator topped it off, then pulled the small vent hose at the top of the radiator off and topped it off again. When I fire it up the engine gets to 200 degrees and the radiator fan kicks on but the radiator and hoses that go to the radiator are cold. The engine temp keeps climbing and I have to shut it down. I've tried 3 times and it's the same. What am I doing wrong? Thanks.
blazinrzr is offline
post #2 of 5 Old September 29th, 2018, 07:41 PM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Coolant won't circulate, please help
Try this.
Clothier is offline
post #3 of 5 Old September 29th, 2018, 07:43 PM Thread Starter
blazinrzr's Avatar
First Name: Ben
My RZR: '11 XP
Member #16793
Thanks, I'll try it tomorrow.
post #4 of 5 Old October 1st, 2018, 09:29 PM
claas's Avatar
Member #85471
View claas's Photo Gallery(0)
To make the bleeding process faster, jack the front end up and then crack that bleeder screw and it should do the trick done this multiple times on a 900
claas is offline
post #5 of 5 Old October 1st, 2018, 10:03 PM Thread Starter
blazinrzr's Avatar
First Name: Ben
My RZR: '11 XP
Member #16793
Thanks for the replys. I was able to bleed most of the system, but I've got bigger problems now. Its got at least a blown head gasket. Combustion gases are coming out of the coolant filler neck and the oil tank.
Losing Coolant??? sceblack RZR XP 4 900 Specific Discussion 6 June 13th, 2018 08:57 AM
Coolant gauge jack.andy.568 General RZR Discussion 0 December 17th, 2017 07:50 AM
Reservoir coolant machinist1 RZR 900 Engine 0 November 28th, 2017 05:48 PM
coolant loss Rode Warrior RZR 800 Specific Discussion 4 August 30th, 2016 04:45 AM
207 miles and found coolant under oil filter Dunegoon16 RZR XP Turbo 5 July 17th, 2016 09:46 PM
