Grease zerks. - Polaris RZR Forum - RZR Forums.net
post #1 of 35 Old April 28th, 2011, 03:27 PM Thread Starter
PETE O.'s Avatar
First Name: PETE
My RZR: 2010 LE
Member #18045
View PETE O.'s Photo Gallery(0)
Thumbs down Grease zerks.
Just thought I'd mention this: I was finishing up the installation of a new RokTec lift kit and decided to throw a little grease toward the suspension parts, ie, swing arms and such. I found two zerks that would not take grease so I pulled them and found they had never taken grease. They were as dry as a popcorn fart in a sand storm, as were the a-arm shafts. They were both 90 degree fittings and when I disassembled them I found the part with the check valve was not functioning. This is a pretty new machine so I'm hoping no permanent damage was done. I also found the rear swaybar was dry. These fittings worked okay, they just hadn't ever been greased. Polaris "Quality Control" is definitely in question. You guys migh want to check all your zerks.
Be aware!
Pete O.
OLD GUYS RULE
PETE O. is offline
post #2 of 35 Old April 28th, 2011, 03:30 PM
Macs Dad's Avatar
My RZR: 2008 Ranger RZR
Member #8581
Re: Grease zerks.
Pete O.
Ok that was funny.
Macs Dad is offline
post #3 of 35 Old April 28th, 2011, 03:41 PM
RzrTheRoof's Avatar
My RZR: 2009 LE
Member #7974
Feedback Score: 11 reviews
View RzrTheRoof's Photo Gallery(0)
Re: Grease zerks.
Does anyone know the size/thread for the zerks?
RzrTheRoof is offline
post #4 of 35 Old April 28th, 2011, 03:43 PM
Rzr spy
grant22's Avatar
First Name: Grant
My RZR: Currently Rzr Free
Member #1714
View grant22's Photo Gallery(0)
Re: Grease zerks.
That WAS funny and thx for the heads up dude.
grant22 is offline
post #5 of 35 Old April 28th, 2011, 04:16 PM
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Re: Grease zerks.
RzrTheRoof RzrTheRoof is online now
Member #7974
Re: Grease zerks.
A few notes on the serts:
The grease job on my XP was dismall at best. No complaining but some of us pointed it out over on the "problems thread" just as a heads up.
Easy fix as most of us has a grease gun and preferred grease.
What are they using? Look up that Polaris part#. It has to be an SAE std.
Problem is it is already drilled an tapped and you live with it.
If you need to replace it take it down to Pep Boys to match it. They will probably have a vernier at the counter if you don't at home.
If you want to drill and tap your own serts for whatever reason, and we have discussed that, use an UNDERSIZED drill bit in the THIN wall areas. That hole will open to the correct size super fast usually. I'm only talking about a few thousandths. If you start to insert the sert and there is too much resistence you can go with the .003 larger drill bit and like that feel threading it in.
In drilling and taping thick iron less caution is needed, just use the nominal drill size usually.
When in doubt find a test part.
You won't want metal shavings inside so consider a magnetic thingy. Sears sells them for a few bucks. you slide it over your bit a few times and its gaussed. Instant magnetic drill bits.
Another cheap way to magnetize is to lay it on a speaker magnet. It works.
All these guys with huge woofers have instant magnetizers.
itsruf is offline
post #6 of 35 Old April 28th, 2011, 04:49 PM
turkeyhunter's Avatar
First Name: gary
My RZR: XP turbo
Member #16815
View turkeyhunter's Photo Gallery(0)
Re: Grease zerks.
1/4" x 28 threads
turkeyhunter is offline
post #7 of 35 Old April 28th, 2011, 05:32 PM
jmattor's Avatar
First Name: Jim
My RZR: 2010 RZR 4bo
Member #12929
Feedback Score: 4 reviews
View jmattor's Photo Gallery(19)
Re: Grease zerks.
Mark, as much as I hate to fall into the ranks of the Internet spelling and grammar Nazis by correcting people here, I felt compelled to step up for Mr. Zerk.
Yes, it's Zerk fitting, named for its inventor. Oscar.
Consider it a public service message.
And a big thanks to the OP for making peeps aware and to Turkeyhunter for the specs.
Also there's one hidden on the rear of the drive shaft....grease that puppy
I love the smell of styrene in the morning....
jmattor is offline
post #8 of 35 Old April 28th, 2011, 06:00 PM
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Re: Grease zerks.
yes I know i use the slang and Jim has been helpfiul before.
More notes:
interesting that on the front arm uses both, the top uses the smaller 1/8" or metric???? in the center
and the bottom of the arm is 1/4" or metric???? outbound. (Mine does anyway)
My Machinery's Handbook shows metric in 5,6,7, 8,10,12mm and higher
God only knows what Polaris does.
Also BSP (British) std. in that book.
Hey Jim, add another raspberry Entenmanns to your list.
itsruf is offline
post #9 of 35 Old April 28th, 2011, 06:52 PM
Ok_State_RZR's Avatar
First Name: Curtis
My RZR: 2011 RZR 800
Member #23063
View Ok_State_RZR's Photo Gallery(0)
Re: Grease zerks.
Greased my suspension ones today
Ok_State_RZR is offline
post #10 of 35 Old April 28th, 2011, 08:18 PM
jmattor's Avatar
First Name: Jim
Member #12929
Re: Grease zerks.
Now, that's the best thing I've heard all day.....grew up not too far from the Entenmann's spread on L.I.
Kinda partial to the cream cheese filled coffee crumb cake myself...
Just for conversation sake, what are you guys using to grease your RZR's? Whatever you have in the gun or something special?
jmattor is offline
post #11 of 35 Old April 28th, 2011, 09:00 PM
RzrTheRoof's Avatar
My RZR: 2009 LE
Member #7974
Re: Grease zerks.
Thanks fellas. Because I keep the Rzr at my place up north, I often find myself trying to put together plans down here without the convenience of actually seeing/measuring.
I know one or two of my zerks seem to never want to take grease. I have to hold the gun fitting dead on, and strongly on, just to get the first one or two squeezes. It's not the coupler because it works fine on the sway bar and other zerks. I figured I simply could replace the zerks with new hardware.
post #12 of 35 Old April 28th, 2011, 09:28 PM
Rzr spy
grant22's Avatar
First Name: Grant
Member #1714
Re: Grease zerks.
I use Amsoil's Hi Temp Synthetic grease. It's purple-ish color.
grant22 is offline
post #13 of 35 Old April 28th, 2011, 09:51 PM
RzrTheRoof's Avatar
My RZR: 2009 LE
Member #7974
Re: Grease zerks.
Green Grease.
post #14 of 35 Old April 28th, 2011, 10:29 PM
medik418's Avatar
First Name: Tom
My RZR: 2009 RZR
Member #14212
Re: Grease zerks.
We always called them grease tits. I swear.
medik418 is offline
post #15 of 35 Old April 29th, 2011, 02:19 AM
Banned
itsruf's Avatar
First Name: Mark -
Member #16159
Re: Grease zerks.
My RZR: 2009 LE
Member #7974
Re: Grease zerks.
I know one or two of my zerks seem to never want to take grease..... I have to hold the gun fitting dead on, and strongly on, just to get the first one or two squeezes..........
they will do that - rock the joint around and fight it
more notes:
I use a multi-purpose Mystic brand. Temp rating is somewhat high and waterproof, but I'm willing to learn.
My XP splined drive shaft grease job was pretty hack. Clearly seen only if you have the center console off. The skid bellys are supposed to leave a hole for that? Polaris uses a funky white grease there, albeit 1/4 of the spline.
I spent some time on that joint.
Sure thought Jim was Raspberry last year not the Cream Cheese. The Raspberry's been effective for me....I'm stickin with it. Don't matter how old or hard it is you will get free stuff wherever you take it in. But take in that Cream Cheese and you might be mounting your own tires.
itsruf is offline
A better way to grease? txwpd103 Projects and How-To 4 April 1st, 2017 12:29 AM
Cv grease canuk General RZR Discussion 6 April 28th, 2011 05:45 AM
Grease Zerks?? rardoin General RZR Discussion 19 July 6th, 2010 12:58 PM
? on grease fishlips RZR-S Specific Discussion 6 January 20th, 2010 04:04 PM
Grease Zerks Sid Community Help 15 January 3rd, 2010 08:46 AM
