DG Tailgate Support - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old January 31st, 2018, 08:15 AM Thread Starter
Tailgunner's Avatar
My RZR: 900 Trail
Member #230761
View Tailgunner's Photo Gallery(0)
Usa DG Tailgate Support
Has anyone used DGs Tailgate Support Bars, if so how do you like them?
I have a Silverado 1500 1/2 ton pickup I would like to be able to haul around my 900 trail for day trips, instead of hooking up my toyhauler. The problem is the ass end/front end of the 900 will be resting on the tailgate and I don't trust the standard cables. I have already installed a set of air bag suspension supports when I got the toyhauler.
Tailgunner is offline
post #2 of 12 Old January 31st, 2018, 08:19 AM
02Fatboy's Avatar
First Name: Rick
My RZR: 2016 Graphite Turbo XPT4 & 2017 Velocity Blue XPT 4
Member #85625
View 02Fatboy's Photo Gallery(4)
Re: DG Tailgate Support
What are they made out of? If they are steel I see no problem using them.
02Fatboy is offline
post #3 of 12 Old January 31st, 2018, 09:24 AM
atocha's Avatar
Member #174297
View atocha's Photo Gallery(0)
I have them. Use them on my silverado 2500 when I put a quad in the back of my truck.
Gives me a little more peace of mind. It does say on instructions, not to use when hauling, only for loading, but I keep mine on there when hauling.
atocha is offline
post #4 of 12 Old January 31st, 2018, 09:57 AM
1idrod's Avatar
My RZR: Gen 2 Green
Member #784
View 1idrod's Photo Gallery(0)
I bought some stainless straps someone was making like the metal ones they use to put on pickups before the cables and put on my 06 gmc. They give you piece of mind over cable but you can still put to much weight on tailgate and bend the cup part that the tailgate pivots on if not careful. Mine bent some but it's all still functional. Latch is just a little tougher to pull to open.
1idrod is offline
post #5 of 12 Old January 31st, 2018, 12:00 PM
Expat's Avatar
First Name: Larry
My RZR: 2016 Turbo
Member #75196
View Expat's Photo Gallery(0)
Yes I have used them and they work great.
2016 XPT Spectra Orange
Method 408s with 31x11.50x15 Super Swamper LTBs and a few other things
http://www.wolfsnout.net
Expat is offline
post #6 of 12 Old January 31st, 2018, 01:59 PM
csacsa's Avatar
Member #71077
View csacsa's Photo Gallery(0)
I use them but they have bent the sheet metal that the tailgate inserts go in so my tailgate is hard to close
csacsa is offline
post #7 of 12 Old January 31st, 2018, 05:46 PM
Expat's Avatar
First Name: Larry
My RZR: 2016 Turbo
Member #75196
Yes if you load them heavy they can do that, mine did. Easy fit to bend the upper latches back.
Expat is offline
post #8 of 12 Old May 9th, 2018, 06:24 AM
nhrzr900's Avatar
First Name: Jay
My RZR: 18 900 Trail EPS
Member #247378
View nhrzr900's Photo Gallery(0)
I ordered a set for my f-150.. Ordered them on a Tues, they shipped same day and will be here on Thursday...
I loaded the RZR in the back of the truck reverse when I picked it up at dealership because they had a loading ramp to back into, didn't have the bars yet so it was a nerve racking 20 miles back home..
Will eventually get a trailer but for now it is being loaded in back of bed...
nhrzr900 is offline
post #9 of 12 Old May 28th, 2018, 03:27 AM
nhrzr900's Avatar
First Name: Jay
Member #247378
They work awesome ...
nhrzr900 is offline
post #10 of 12 Old May 28th, 2018, 06:03 AM
Macs Dad's Avatar
My RZR: 2008 Ranger RZR
Member #8581
I have them on my Chevy 2500 and drive the RZR in front first and they work great. Just connect to bed and tailgate and go.
Macs Dad is offline
post #11 of 12 Old May 28th, 2018, 06:25 AM
georgecdisc's Avatar
Member #154377
View georgecdisc's Photo Gallery(0)
I have them for my 2008 Silverado 1500, not sure they do much of anything. I can't tell if the latches on the tailgate are plastic... or plastic covering metal. The DG supports are loose with the tailgate down as all load is on the cables. Not sure what happens during loading, if the cables stretch just enough to distribute more load onto the DG supports. So yea, between potential plastic latches and sloppy brackets... in my case it seems like a waste of money.
My bed is 8ft, I pull the RZR in forward, rear tires end up on the bed/tailgate hinge point so I'm not concerned about transport, only loading. I replaced the cables, even though the old ones looked in good repair - never know what they are like under the crimped section.
georgecdisc is offline
post #12 of 12 Old May 28th, 2018, 06:41 AM
Addicted
CFDWheeler's Avatar
First Name: Steve
My RZR: 17' White/Reflex Blue XP1k
Member #6186
Feedback Score: 13 reviews
View CFDWheeler's Photo Gallery(0)
Could always put a 2x12 board the length of your bed/rzr under each side of the rzr to distribute the load.
2017 1000XP. White w/ Reflex Blue
FUTV UHMW Full skid package; SATV radius rods,
Viper Elite 5K Wide on Bad Dawg front bumper, SATV rear bumper
SSV Works Stereo; Axiom Roof, 30" front LED radius bar
RacerTech Heavy Springs, 32" Carnivores on STI HD9's
XXL Front fenders with Mudbuster Max rear.
IAFF LOCAL 38 Covington KY
CFDWheeler is offline
Heel clicker support w/ new spider. RockyMtnRZR-S RZR XP Turbo 14 October 27th, 2016 09:56 PM
Support nm senate bill 270 zoecoe Public Lands Advocacy 1 February 6th, 2016 05:40 AM
