XP1k Trails & Rocks Lower A-Arms and Radias arms - Polaris RZR Forum - RZR Forums.net
 4Likes
  • 1 Post By 100gld
  • 1 Post By Bullitt427
  • 2 Post By American Rock Rods
post #1 of 13 Old January 23rd, 2018, 01:38 PM Thread Starter
Bullitt427's Avatar
Member #133409
What are the actual part numbers for the XP1K T&R Edition lower A-Arms and Radius arms? Looking them up on a Polaris Parts Locator doesn't give much info on the various a-arms on the different models.
Basically I am just getting an idea of using the factory Polaris parts versus SATV or Highlifter.
Josh
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #2 of 13 Old January 24th, 2018, 02:07 PM
100gld's Avatar
First Name: Rob
My RZR: 2017 Rocks and Trails
Member #188425
View 100gld's Photo Gallery(0)
Re: XP1k Trails & Rocks Lower A-Arms and Radias arms
Josh......I know what you mean when you look at the parts fiche on suspension parts....that being said, go to the actual accessory catalog and you will find the exact ones listed in there. Sorry I'm not more help.
Bullitt427 likes this.
100gld is offline
post #3 of 13 Old January 24th, 2018, 02:24 PM Thread Starter
Bullitt427's Avatar
Member #133409
There it is... sorta.
Front LCA for $379 with balljoints
Rear Complete kit for $499.99, but doesn't fit 12mm rear bolts.
Hmmm... gotta be a way to just get the lower radius arms from the Gold Edition
Josh
2013 RZR 800 LE
post #4 of 13 Old January 24th, 2018, 10:50 PM
400exrider's Avatar
Member #27656
View 400exrider's Photo Gallery(0)
I believe it is part #: 1543751-458 for the radius rods. Its unclear if they use 10 or 12mm as they list both bolts. The description says high clearance black. You can buy the a arms themselves as well minus the ball joints and bushings. I believe it is 1021482-458 and 1021483-458 but those part numbers are harder to tell by the description. I bought red oem highlifter a arms for my turbo and they worked great.
400exrider is offline
post #5 of 13 Old January 25th, 2018, 05:09 AM
Iowegian's Avatar
My RZR: 2018 Ghost Grey XP Turbo
Member #231329
View Iowegian's Photo Gallery(0)
Just buy high clearance lower radius rods from highlifter and the lower a arms from superatv. Itíll be cheaper and you will have better parts.
Iowegian is offline
post #6 of 13 Old January 25th, 2018, 05:48 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Not sure why you think those options are better than the OEM parts. All Polaris special parts (High clearance A-Arms, skid plates, high clearance radius rods, etc....) are built by a 3rd party vendor (Aftermarket).
The factory R&T high clearance A-arms and Radius rods are very good quality parts.
OP: If you get the OEM R&T radius rods they will be 12mm.
RZR_Joe is offline
post #7 of 13 Old January 25th, 2018, 05:59 AM Thread Starter
Bullitt427's Avatar
Member #133409
I had SATV front and rear high clearance A-Arms on my 2017 S1000. I wouldn't really say they were superior to the factory parts, but they were nice units and the price was decent. My biggest complaint on the SATV LCA's was setting the camber. Their recommended setting was nowhere near correct for my machine and it's a pain to disassemble everything to recorrect it. I'd rather just bolt up and go, hence OEM parts.
I was more curious about what was available OEM and how much. So far it seems a good deal to use the Polaris lower HC A-Arms and possibly an aftermarket solution for the radius rods.
RZR_Joe likes this.
2013 RZR 800 LE
post #8 of 13 Old January 25th, 2018, 06:23 AM
zulufoxtrot's Avatar
First Name: Jeff
My RZR: XP Turbo
Member #84100
View zulufoxtrot's Photo Gallery(0)
I just bought a 2018 trails and rock, it actually came with a part number sheet for all the upgraded parts and accessories on it. I will get that data when I get home after lunch.
2016 900 Trail
2016 xp Turbo
2018 Rock and Trails
zulufoxtrot is offline
post #9 of 13 Old January 25th, 2018, 01:24 PM
Iowegian's Avatar
Member #231329
I did not realize that. I thought polaris made all that stuff.
Iowegian is offline
post #10 of 13 Old January 25th, 2018, 01:36 PM
XR4Honda's Avatar
My RZR: 2008 RZR, Rear Bench for my 2 boys
Member #13135
View XR4Honda's Photo Gallery(0)
I have a 2016 xp4 1000 highlighter. I always wondered if Polaris or highlighter made the high clearance parts. I figured if was highlighter and they probably used the same parts on the Rock and Trails. Just a different color. Who knows.
XR4Honda is offline
post #11 of 13 Old January 25th, 2018, 02:35 PM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
Josh
The rockcrawler edition is code AZ
Front lower A arms:
1021482-458 WELD-CTRLARM,HC LWR,FR,LH,64,B [AZ]
1021483-458 WELD-CTRLARM,HC,LWR,FR,RH,64,B [AZ]
Radius rods:
1543751-458 ASM-RADIUS ROD,BTM,HC,M.BLK [AZ]
If your car uses 10x1.25 rear bolts you will need to get the correct bolts, and drill out the frame and rear carriers, or replace with the updated parts. It would depend on when yours was made.
RZR_Joe and Bullitt427 like this.
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #12 of 13 Old January 25th, 2018, 02:37 PM Thread Starter
Bullitt427's Avatar
Member #133409
Josh
Front lower A arms:
Radius rods:
Thanks, I have an 18 XPT
Josh
2013 RZR 800 LE
post #13 of 13 Old February 3rd, 2018, 12:46 PM Thread Starter
Bullitt427's Avatar
Member #133409
For those curious of an update
Josh
2013 RZR 800 LE
