Servicing an XP900, - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 24 Old January 14th, 2018, 08:18 AM
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Re: Servicing an XP900,
Originally Posted by mattt181 View Post
Besides the Wix filter, what other auto filters have people had good luck using?
https://www.rzrforums.net/general-rzr...ts-thread.html
ntrsandman is offline
post #17 of 24 Old January 14th, 2018, 10:47 AM Thread Starter
mattt181's Avatar
Member #40346
View mattt181's Photo Gallery(0)
Thanks. Great info right there! I've been looking here for a thread like that with comprehensive info but couldn't find it. Thanks for the pointer.
mattt181 is offline
post #18 of 24 Old January 16th, 2018, 02:51 AM
Z15
Z15's Avatar
My RZR: 2018 S 900 EPS Black Pearl
Member #9114
View Z15's Photo Gallery(0)
UTV/SxS Oil/Filter Lookup Guide
Mike
2018 RZR S 900 EPS Black Pearl
2017 John Deere X738
2017 GMC Sierra CC Denali 6.2L
2016 RZR 900 EPS Trail
Z15 is offline
post #19 of 24 Old January 29th, 2018, 10:29 PM Thread Starter
mattt181's Avatar
Member #40346
Originally Posted by gburden1 View Post
I would check the intake boots for cracks or damage and invest in a wheel bearing greaser.
I've tried to get my eyes all over the intake boots and they're buried in there pretty good. Is there a how to in checking these boots for no cracks, or is the only real way to check them by disassembling the intake tract? Thank you.
mattt181 is offline
post #20 of 24 Old January 30th, 2018, 06:30 AM
gburden1's Avatar
First Name: George
My RZR: 2012 900 XP
Member #171785
View gburden1's Photo Gallery(1)
Yes you will have to remove the the air filter housing, but it's not a big deal.
gburden1 is online now
post #21 of 24 Old January 30th, 2018, 11:05 AM Thread Starter
mattt181's Avatar
Member #40346
Thank you
mattt181 is offline
post #22 of 24 Old January 31st, 2018, 09:03 AM
ShakyDog's Avatar
My RZR: 2013 Jagged X
Member #41826
View ShakyDog's Photo Gallery(0)
I have a vague recollection of reading where someone sprayed ether or starter fluid around the area of the boots, while the engine is running, to determine if there was a leak. Or did I dream this also?
Steve
ShakyDog is online now
post #23 of 24 Old January 31st, 2018, 10:57 AM Thread Starter
mattt181's Avatar
Member #40346
Steve
That would work, RPMs would rise if there is a leak.
mattt181 is offline
post #24 of 24 Old February 27th, 2018, 11:26 PM Thread Starter
mattt181's Avatar
Member #40346
Re: Oil Change, & Gear oil maintenance on '13 XP900
Originally Posted by hotrod9193 View Post
There is no fuel filter. Just on the fuel pump in the tank.
I would also pull the belt cover and check belt/clutches blow the dust out of them with some air.
And I would change front diff fluid and rear diff/trans fluid clean the drain plug magnets
Sent from my SM-G930R4 using Tapatalk
I did all these suggestions and glad I did. Ended up with new front diff gear oil all over the place when refilling, the capacity is so little and I poured toooo much in the funnel.
I was able to pull the belt cover completely off without removing the shock mount. There is one specific spot and way you can get the cover completely off and it makes the job easier than having the cover in the way. When I did blow out the clutches and belt housing, a lot of grey-ish dust went flying. I would guess that to be the norm for a used 900 XP? (no chunks or belt pieces whatsoever). Belt looked good, like the new one I have in the package which was surprising.
mattt181 is offline
2011 XP900 Lots of xtras, Rides like a dream! superdean RZR For Sale - Southwest / Arizona 13 October 31st, 2017 09:37 PM
VisionX RZR XP900 (11-14) Headlight Kits NOW In Stock! AlternativeOffroad Lighting, Stereo and Electrical 2 December 18th, 2016 02:09 PM
2011 xp900 dranger962000 Polaris RZRs For Sale 2 December 4th, 2016 05:14 PM
xp900 Transmssion same as Xp1000? Krapcars General RZR Discussion 5 November 10th, 2016 10:58 AM
Xp900 stud size tmaxxman21 General RZR Discussion 1 September 20th, 2016 11:38 AM
