Got an idea for hot cab....lets hear input or flame me!! - Page 2 - Polaris RZR Forum - RZR Forums.net
 19Likes
post #16 of 41 Old July 18th, 2017, 01:29 AM
rzrmuddawg's Avatar
First Name: Steve
My RZR: 2017 1000 xp 4 turbo
Member #192881
View rzrmuddawg's Photo Gallery(0)
Re: Got an idea for hot cab....lets hear input or flame me!!
your could always relocate radiator to the back w/ a Radiator Relocation Kit
rzrmuddawg is online now
post #17 of 41 Old July 18th, 2017, 12:35 PM
UncleJerm76's Avatar
My RZR: 2015 900XC
Member #80603
View UncleJerm76's Photo Gallery(0)
Originally Posted by SpeedQuest View Post
New XP4 Turbo owner here and I'm in the process of lining the center console with Thermal tape...
Nice job, please follow up and let us know if the results are worth it.
UncleJerm76 is offline
post #18 of 41 Old July 20th, 2017, 08:10 PM
SpeedQuest's Avatar
Member #205121
View SpeedQuest's Photo Gallery(0)
Got both parts of the console insulated finally today...
Took it out for a late afternoon drive and have to say I am VERY PLEASED. It wasn't SUPER HOT out, as it had recently rained, but after a 20 minute ride, the console was warm to the touch but nowhere near the scalding hot it's been in the past. Hope to take it out for a trail ride this weekend for a more in-depth test...
Rockwerx likes this.
SpeedQuest is offline
post #19 of 41 Old July 21st, 2017, 12:41 PM
E.T.X.Rzr's Avatar
First Name: Justin
My RZR: 2019 HLE4
Member #81149
Used spray from on the console then trimmed it down to fit after it expanded and dried. I also used header rap on the rad lines. The console does not get hot anymore.
Attachment 447185
E.T.X.Rzr is offline
post #20 of 41 Old July 21st, 2017, 01:39 PM
Backfire1's Avatar
My RZR: XP1K
Member #202297
View Backfire1's Photo Gallery(0)
Attachment 447185
I may have to borrow this idea.
Backfire1 is offline
post #21 of 41 Old July 21st, 2017, 02:06 PM
Profuzz's Avatar
Member #163225
View Profuzz's Photo Gallery(0)
trim to fit after foam cures ! Helps for sure still a lot of heat coming thru front firewall / under dash ?
Profuzz is offline
post #22 of 41 Old July 21st, 2017, 03:14 PM
Wolfsnout Racing's Avatar
First Name: Tim
My RZR: 2018 XPT
Member #26446
View Wolfsnout Racing's Photo Gallery(2)
This set up works great and you can easily take it out for the winter or if you have get to your carrier bearing. They will have a few other insulators not pictured that will be with them.
Expat likes this.
WOLFSNOUT
High Performance ATV/UTV Dust Mask
Amazon-https://tinyurl.com/yb6n5oou
http://www.wolfsnout.com
Wolfsnout Racing is offline
post #23 of 41 Old July 22nd, 2017, 07:39 AM
RZR_Rob's Avatar
First Name: Robert
My RZR: 2017 RZR 900 XC
Member #44037
View RZR_Rob's Photo Gallery(0)
Looks good! Where do you buy it?
RZR_Rob is offline
post #24 of 41 Old July 22nd, 2017, 12:46 PM
wadewoot's Avatar
First Name: wade
My RZR: 2016 rzr s1000
Member #75338
View wadewoot's Photo Gallery(0)
T foam will soak up water like a sponge and cause rust. Make sure it's not in contact with any metal
wadewoot is offline
post #25 of 41 Old July 22nd, 2017, 12:52 PM
Profuzz's Avatar
Member #163225
Closed cell foam ! still I'll keep an eye on it thanks
Profuzz is offline
post #26 of 41 Old July 23rd, 2017, 05:52 PM
littleboss's Avatar
My RZR: 2016 XP Turbo Spectra Orange
Member #47857
View littleboss's Photo Gallery(1)
Originally Posted by srt20 View Post
Originally Posted by Kurt Schlosser View Post
Originally Posted by btrshoes View Post
Yeah we were just taking about removing them too. I got my center console out now going to cover the aluminum rad lines with heater hose to see if that cools things down.
I'd worry that covering those lines may make your engine run hotter. I'd try to insulate between you and the lines, rather than stopping heat from dissipating.
The radiator is for transferring heat. The lines are for transferring fluid. The thermostat controls how hot your coolant is allowed to get.
Its does not make it run hotter. I have mine insulated with pipe insulation. The only temp that changed was the temp in the cab.
I also insulated the entire center console. My feet( I ride in flip flops a lot) and drinks don't get over ambient air temp now.
Since the tunnel is hot we know the lines are radiating heat not just transferring fluid. If you put pipe wrap on the lines then whatever heat was radiating from the line is now contained (or better contained) in the lines. This extra heat now goes to the radiator and engine. Whether it makes a difference or not I don't know, someone would have to measure it.
I say insulate the top of the tunnel, put a 12V fan it there and blow the heat out the bottom!
'16 XPT & '17 GENERAL & '15 Polaris Ranger XP 900
If you like old John Deere tractors https://antiquetractorblogger.blogspot.com/
littleboss is offline
post #27 of 41 Old July 23rd, 2017, 06:02 PM
Profuzz's Avatar
Member #163225
No change in operating temperature since install !!
Profuzz is offline
post #28 of 41 Old July 24th, 2017, 06:24 AM
Backfire1's Avatar
My RZR: XP1K
Member #202297
Here is what I did and I could tell on the next two rides. The stuff I used is for a roof. It is metal tape with tar on the other side. Very sticky and I cleaned the underside of my console with alcohol. My drinks are not as hot and my leg did not get as hot as it did.
Name:	2017-07-15 20.25.04.jpg
ID:	447889   Click image for larger version
Name:	2017-07-15 18.51.38.jpg
ID:	447897   Click image for larger version
Name:	2017-07-15 18.51.34.jpg
ID:	447905   Click image for larger version
Name:	2017-07-15 18.41.15.jpg
ID:	447913   Click image for larger version
Name:	2017-07-15 18.41.10.jpg
UncleJerm76 and Bullitt427 like this.
post #29 of 41 Old July 25th, 2017, 09:23 AM
Dwight45's Avatar
Member #753
View Dwight45's Photo Gallery(0)
The op waited to know about reversing the fan. I've been thinking about this myself since spending 6 days riding in Wyoming during almost record heat. We are primarily trail riders and seldom achieve speeds that have much effect on cooling the radiator. With that said, maybe a reversible fan would work. As soon as the stock fan comes on you can feel the heat in the cab. We've just moved back from an xp1k4 to a gold le and there's a considerable difference between the two of them for cab heat. I have the wolfsnout heat blanket behind the seats and will be insulating the tunnel next but something will have to be done about heat coming thru the firewall. I did seal the firewall seam with black silicone seal but I can't tell if it helped any. Still looking for ideas. I have front and rear full windshield and roof and lower doors.
Dwight
Dwight45 is offline
post #30 of 41 Old July 25th, 2017, 10:14 AM Thread Starter
btrshoes's Avatar
My RZR: 900S
Member #48027
View btrshoes's Photo Gallery(0)
Well I abandoned the reversing fan idea for now. Going to Kentucky soon to ride but I've insulated the rear of cab, wrapped my rad lines under tunnel, made a shield behind the fan to block direct hot air and I'm removing my door lowers so short of riding around naked or adding AC I think it's gonna be Ok!
btrshoes is offline
