Steering wheel with exclemation point - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 2 Post By hotrod_sxty8
post #1 of 7 Old May 27th, 2017, 03:22 PM Thread Starter
sfsapper's Avatar
First Name: TOM
My RZR: 2014 800s efi eps
Member #117273
View sfsapper's Photo Gallery(1)
So from reading the forms here I have found it's the power steering. Wondering if this is something I can fix or do I need to take it to a shop.
Background... went to the storage today, found the battery dead, had to jump start it. When it fired up the light was on. Had not been ridden for about 5 months or so, light was not on prior to storage. Drove it around for about 5 minutes and power steering is not working. I don't see visually anything wrong with the steering system. Wondering if maybe it's just something electrical from having to jump start it?
sfsapper is offline
post #2 of 7 Old May 27th, 2017, 03:41 PM
rzr4hank's Avatar
First Name: Alex
My RZR: 2014 RZR4-900
Member #61009
View rzr4hank's Photo Gallery(0)
Re: Steering wheel with exclemation point
May need a new battery.
rzr4hank is offline
post #3 of 7 Old May 27th, 2017, 04:24 PM
Wingman02's Avatar
My RZR: 800 S
Member #40774
View Wingman02's Photo Gallery(0)
You may have to clear the fault before the EPS will work again. It probably did not see the correct voltage to start with!!
Wingman02 is offline
post #4 of 7 Old May 27th, 2017, 07:40 PM Thread Starter
sfsapper's Avatar
First Name: TOM
Member #117273
Ok, let's start with the cheaper one first. How do you clear the fault?
sfsapper is offline
post #5 of 7 Old May 27th, 2017, 08:56 PM
hotrod_sxty8's Avatar
My RZR: 2012 RZR 800s(sold) 2016 RZR 900s
Member #74749
View hotrod_sxty8's Photo Gallery(0)
get the battery to full charge first.
then start up the machine and see if it clears, if it does good if it doesn't dont freak out just yet.
drive it around for a little bit in low gear 5-10 minutes then shut it off and restart it may clear up. if this doesn't work you can see what the code is by doing the following:
Toggle the mode button until the chk eng shows on the screen
then press and hold the button until the diagnostic menu shows up
A set of 3 numbers will appear on the screen
the 1st, number on the far left is the number of trouble codes stored 0 thru 9
the second is on the top right and can have up to 6 digits and is the suspect parameter that has faulted
the third is: on the bottom and is one or two digits and is the fault mode.
write the code down and come back here for an answer.
mine was doing this in cold weather and it was a speed sensor or crank position sensor, anyway ever since it has warmed up I have not had the issue return.
TennesseeRZR and mannysouza like this.
2016 RZR 900s in blue fire, 30 inch carnivores, 6 speaker kicker stereo , Polaris upper door enclosure, Polaris lower door inserts, custom switch panel, 20 inch led light bar, Polaris front bumper, Superwinch Terra 4500, tender spring swap from RZRAID (now allthingsutv) new shock resivior end caps from Schmidity racing,3500 miles and counting!!!
Founding member of the Ewing Off Road Club in Southern Illinois!!
and I do all my own stunts!
hotrod_sxty8 is offline
post #6 of 7 Old May 27th, 2017, 10:16 PM
BLOODY BILL's Avatar
First Name: CHRIS
My RZR: 2016 xp1000 eps
Member #22587
Feedback Score: 16 reviews
Colorado Re: Steering wheel with exclemation point
subscribed
BLOODY BILL is offline
post #7 of 7 Old June 19th, 2017, 04:50 PM Thread Starter
sfsapper's Avatar
First Name: TOM
Member #117273
So the battery was causing the issue. Finaly hot a chance to get it on a charger for a couple days and battery is good starts right up now and everything is fine. I have another problem though. I'll ask it in a different post
sfsapper is offline
UTV INC 1.5" Steering Wheel Spacer UTV Inc. UTV Inc 10 January 8th, 2018 07:32 AM
2014 XP1K Power Steering Unit PaulK Polaris RZR Parts For Sale 5 July 27th, 2017 03:50 PM
DIY XP1000 steering wheel removal/puller CrawlerJamie Projects and How-To 3 October 1st, 2016 03:18 PM
