Super hot center console in 2017 RZRXP Turbo. - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 2 Post By warrenhdavis
post #1 of 7 Old May 25th, 2017, 06:40 PM Thread Starter
warrenhdavis's Avatar
Member #99161
View warrenhdavis's Photo Gallery(0)
ID:	427593Click image for larger version
ID:	427601I have a lttle over 400 miles and now it's getting warner in the Desert so I had to try and help the situation out. My cup holders might as well be coffee warmers. I got this aluminm backed, sandwitched bubble wrap for an air gap style insulation from Home Depot. Used high temp 260 deg aluminum tape and scissors to cut out all the pieces. Since the insulation holds it's shape pretty good I made another insert around the radiator pipes inside the console. Will be testing this weekend an report back.
glockmeister and blairg like this.
warrenhdavis is offline
post #2 of 7 Old May 25th, 2017, 07:46 PM
kleake's Avatar
My RZR: 2017 S 1000
Member #167257
View kleake's Photo Gallery(0)
Re: Super hot center console in 2017 RZRXP Turbo.
I just used the spray in expanding foam. Worked pretty well. Yours looks nicer though.
Sent from my SM-G950U using Tapatalk
2017 RZR 1000 S EPS with some goodies
2015 Grizzly 700 Special Edition
2013 Grizzly 700 Special Edition
2006 Kawasaki Prairie 360
kleake is offline
post #3 of 7 Old May 26th, 2017, 12:27 AM
CRAWLR's Avatar
First Name: Derek
My RZR: XPT
Member #355
View CRAWLR's Photo Gallery(0)
I used the same bubble wrap stuff just around the cup holders and it made a big difference. I was thinking about adding more like yours since it worked so well. Let us know how you like it
IUEC local 8
CRAWLR is offline
post #4 of 7 Old May 26th, 2017, 04:51 AM
Cobra_Gt's Avatar
First Name: Paul
My RZR: 2019 XP Turbo
Member #77130
View Cobra_Gt's Photo Gallery(0)
Firewall gets hot too. When the temps get hotter, I am considering doing something similar to it. Right now with the temps cool at times it keeps my feet warm.😊
Sent from my SM-G930V using Tapatalk
2019 Titanium XP Turbo
2016 General
Cobra_Gt is offline
post #5 of 7 Old May 26th, 2017, 05:57 AM
UT Trails's Avatar
My RZR: 2016 S 900 EPS
Member #146497
View UT Trails's Photo Gallery(0)
I installed these awhile back. I wonder if you could put that between the aluminum pieces and the firewall? How thick is the insulation?
Inner Fender Armor; Front - Thunderhawk PZ7974 - Thunderhawk Performance
UT Trails is offline
post #6 of 7 Old May 26th, 2017, 10:44 AM Thread Starter
Member #99161
I was thinking about covering my whole firewall behind the seats with the same insulation. Then cover the silver exposed with some black vinyl car style fabric. It would kinda be like a blanket on the rear wall. I also bought some molded floor mats and gunna insulate the bottom of them too.
post #7 of 7 Old May 31st, 2017, 08:41 AM
Cobra_Gt's Avatar
First Name: Paul
Member #77130
I haven't noticed heat coming from the inner fender area, more from the firewall area behind dash. My XP1K had a turbo hood which aided cooler fresh air, however, I noticed my new XPT had a deflector to capture the air coming through the hood opening and redirected it to the larger radiator and intercooler. I believe this increased heat being dissipated is increasing the heat into the cab.
2016 General
Cobra_Gt is offline
2017 XP Turbo Products! Bikeman Performance Bikeman Performance 7 March 18th, 2018 08:05 AM
2017 Turbo Hood Clint Mo RZR XP 1000 46 March 28th, 2017 05:42 AM
2017 Turbo Gates Belt in stock!!! Hunterworks Hunterworks 2 March 21st, 2017 07:44 AM
Looking for a 4 seat 2017 Turbo Razor Warlock General RZR Discussion 0 January 10th, 2017 10:24 AM
