Having some issues - Polaris RZR Forum - RZR Forums.net
post #1 of 7 Old February 22nd, 2017, 05:34 PM Thread Starter
Dizzledog1's Avatar
First Name: Josh
My RZR: 2016 xp 1000
Member #70121
View Dizzledog1's Photo Gallery(0)
Having some issues
Recently my 16 xp has been idling funny. It will start low then go high then low so on and so on and then it will die. Fires right back up and does it again until it starts to get warm, then runs normal. It seems like it's not getting the right amount of fuel or air on a cold start. We rode last wkend and it was around 65 degrees. So I don't think weather is the issue. My question is do y'all think tmap sensor or maybe tps? Not showing any codes. I've visually checked intake boot and didn't see any rips and clamps were tight. I guess it could be tore where I can't see. I hope my motor is not dusted. Any help would be much appreciated . Thanks
Dizzledog1 is offline
post #2 of 7 Old February 22nd, 2017, 06:31 PM Thread Starter
Dizzledog1's Avatar
First Name: Josh
Member #70121
Re: Having some issues
Anybody out there?
post #3 of 7 Old February 22nd, 2017, 07:19 PM
RMR Man's Avatar
First Name: Steve
Member #11566
I may be way off on this, but I fixed mine and another fellow rider's machines by replacing all of the relays under the seat. They were doing the exact same thing you are describing. That has been over 1 year ago. I keep 4 spare relays in the glove box too.
RMR Man is offline
post #4 of 7 Old February 23rd, 2017, 03:48 AM Thread Starter
Dizzledog1's Avatar
First Name: Josh
Member #70121
Did yours run normal after it was warmed up? I will check the relays this evening if I get off work in time. I also thought about maybe the battery. Once stator charges for a few minutes it starts to idle normally. Idk. Guys keep the suggestions coming. I'm pretty much at a loss. Don't want to start throwing parts on it hoping it fixes the issue or issues.
post #5 of 7 Old February 23rd, 2017, 05:30 AM
RMR Man's Avatar
First Name: Steve
Member #11566
BEFORE I changed the relays, (fuel pump/chassis relay was my suspect) yes it would run just fine after it warmed up. First symptom was stalling when I was unloading it from the trailer. It would restart, but seemed gutless for the next 5 minutes. Absolutely nothing had changed from the conditions of my last ride a day prior. Never unloaded it from the trailer or refueled it from the day before.
I had seen a few posts on here in late 2014 about relay issues, so I ordered 5 of them from Del City for about $4 each and now had them as spares. It's an easy job to replace them, and I'm not one to start thinking main bearings or piston rings failed overnight in the trailer.
RMR Man is offline
post #6 of 7 Old February 23rd, 2017, 02:28 PM Thread Starter
Dizzledog1's Avatar
First Name: Josh
Member #70121
Thanks for the tips! Guys keep em coming
post #7 of 7 Old February 23rd, 2017, 02:44 PM
rush2252's Avatar
First Name: Kolby
My RZR: 2013 Rzr 800
Member #135881
View rush2252's Photo Gallery(0)
I think you are on track with the intake boots. I have seen a ton of them rip under the clamp at the bottom and you dont see it until you remove them from the cylinder head! It always seems to be the driver side boot in the ones Ive found!
rush2252 is offline
The Reasons XP1000 have belt issues article Hunterworks Hunterworks 27 January 24th, 2018 05:23 PM
Power loss or clutch issues with 30-10-14 tires?? oneeye RZR 4 900 12 February 24th, 2017 08:25 AM
More Issues tazz3069 RZR XP 4 1000 19 August 11th, 2016 02:38 PM
Bendix Starter Issues 2010 50 inch birdrl RZR 800 Specific Discussion 0 May 9th, 2016 09:16 AM
New xc has issues LM3LGS RZR 900 - 50'' Trail Models 11 March 30th, 2016 02:39 PM
