opinions on wheel movement - Polaris RZR Forum - RZR Forums.net
post #1 of 11 Old October 27th, 2016, 05:23 PM Thread Starter
onmy6's Avatar
Member #85186
View onmy6's Photo Gallery(0)
Wrench opinions on wheel movement
So as I was washing up the rzr the other week I noticed the left rear wheel has some wiggle to it (pushing the sidewall in and out). Less than a quarter inch. So I first tightened up lugs. Nothing loose. Decided it was the wheel bearing. Next day I ordered 2 (one to use and a spare). I took off the assembly and the bearing sounded/ felt scratchy but not slop. BUT I saw the outer bushings looked like crap and those sleeve things fell out (i grease after every ride or approx every 8hrs). So decided to grease wheel bearing with my new greaser (pushed out water) and order super daves outer bushing kit. Installed new bushings tonight re assembled and I think slop decreased (could be me just validating my $80 purchase) but it is still there. All other wheels have ZERO play.
My question to yall is... Do I run it how it is (i go to off road parks where Im never more than a few miles from the truck and with a group) and wait for it to bust and replace at the truck (big mallet and socket) or pull it all apart and have it pressed out and press a new one in.
2015 rzr 900 trail EPS- FUTV 3/8 skid plate- bandit suspension- 2x rear facing pods- 30inch light bar-interior lights- dual battery kit- noam offroad 2 speaker system- interior lights- prp harnesses, 5pt- tusk bag- polaris overhead bag- hi lifter jack- wild boar bumper- pawltector- tusk rear rack- spare tire- 3500lb winch- galaxy tab4 with BCN and ram mount- rigid box in bed- all amsoil fluid- utv giant doors- grizztek radiator gaurds- overhead polaris bag- sena bluetooth communications
onmy6 is offline
post #2 of 11 Old October 27th, 2016, 06:19 PM
kmzeidler's Avatar
First Name: Kevin
Member #64019
View kmzeidler's Photo Gallery(0)
Re: opinions on wheel movement
So you bought new bearings and haven't installed them yet?
www.ConcordPolaris.com
Polaris since 93' -Custom UTV Builds and Accessories
Instagram: ConcordPolaris_UTV
kmzeidler is offline
post #3 of 11 Old October 27th, 2016, 06:30 PM Thread Starter
onmy6's Avatar
Member #85186
no because i figured it was the bushings... but i guess all the signs lead to the bearing
onmy6 is offline
post #4 of 11 Old October 27th, 2016, 06:38 PM
kmzeidler's Avatar
First Name: Kevin
Member #64019
They're cheap, fairly easy to change.
post #5 of 11 Old October 27th, 2016, 06:55 PM
gtsum2's Avatar
Member #72995
View gtsum2's Photo Gallery(0)
I had same issue and did new bushings all around and new wheel bearings. Right as a tick now. Press makes it a lot easier
2016 RZR 1000s - Sold
gtsum2 is offline
post #6 of 11 Old October 27th, 2016, 07:50 PM
DRKnight's Avatar
First Name: Dennis
My RZR: 2012 RZR S
Member #41687
View DRKnight's Photo Gallery(0)
Arizona Flag Re: opinions on wheel movement
I had the same issue on my 800S and also left side only (13,000 miles)
Replaced both side bearing,
But I went with Garage products bushing kit as it had the addition of the o-rings to help seal out water and retain the grease....
DRKnight is online now
post #7 of 11 Old October 27th, 2016, 07:54 PM
onemooretime's Avatar
My RZR: 900 XP
Member #33122
View onemooretime's Photo Gallery(0)
1/4" slop is not much at all.
Did you try tightening the half shaft bolt? I had that help in the past.
I wait till I see around 3/4" of slop at the outer edge of the tire before changing the bearings.
I'm lucky if a set of OEM bearings make it through a season.
2012 Orange Madness XP900
935 BB W/Alba Stage II W/UMP Intake
Pro Armor Doors, DG Offroad Cage
Twisted Stitch Seats
Riggid Industries 30" Light Bar W/Dual D side lights
Cognito Shocks W/rear dual rate springs
Rugged Radio's 650 intercom/car to car/ Elite-5M GPS
Hiper Tech 14" dual beadlock wheels
onemooretime is offline
post #8 of 11 Old October 27th, 2016, 08:54 PM
DRKnight's Avatar
First Name: Dennis
My RZR: 2012 RZR S
Member #41687
My OEM bearings had very little noticeable side play in them until the left side started going bad.
I went with Timken bearings for my replacements thinking a major brand name bearing might be better.
But they have considerately more side play than the OEM bearing had.
I guess only time will tell how well these will hold up compared to the OEM.
post #9 of 11 Old October 28th, 2016, 02:13 AM
UncleJerm76's Avatar
My RZR: 2015 900XC
Member #80603
View UncleJerm76's Photo Gallery(0)
Not sure if yours was up on a jack when you were cleaning it, but my passenger rear was doing what you described on my '15 900 XC. None of my other wheels have any play at all. Drove me nuts, thought it was a wheel bearing, then bushing, so I jacked up the rear end to take the wheel off and see what it could be. Turned out the lower shock bolt was so loose I could wiggle it around by hand. So I tightened it up and it has stayed fixed so far. Was much easier to locate once the load/weight was off the wheel by jacking it up and wiggling the assembly by one hand and feeling what's moving around with the over hand.
UncleJerm76 is offline
post #10 of 11 Old October 28th, 2016, 04:04 AM Thread Starter
onmy6's Avatar
Member #85186
1. I ran it in with an impact then checked tq with a torque wrench.
2.i wiggled wheel and felt around nothing on the arms were moving BUT will tighten the shock bolt when i get home!
3. I know its not much play but i am trying to be proactive with fhe rzr instead of reactive.
Btw 400miles and 58hrs
onmy6 is offline
post #11 of 11 Old October 28th, 2016, 04:28 AM
My RZR: 2015 900XC
Member #80603
Yeah I'm not saying you need to tighten the shock bolt - that's just what I needed, I'm saying wiggle stuff around until you find what's wrong. For me it was the lower shock bolt, it might be different for you.
Wheel offset vs Suspension performance Shock Therapist Shock Therapy 218 July 14th, 2019 05:27 PM
Assault Industries steering wheel slop BearGhost General RZR Discussion 9 September 7th, 2016 08:21 PM
Wheel bearing movement waggoner5 RZR XP 1000 8 August 7th, 2016 08:42 AM
