I need help with pro armor doors..... - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old March 30th, 2010, 06:37 PM Thread Starter
HILLBILLY's Avatar
First Name: Travis
My RZR: 09 green rzr
Member #13525
View HILLBILLY's Photo Gallery(0)
Hey guys and gals. I need some help. I got my pro armor doors in today. I cant get the door latches to thread in the tabs on the doors. Does anyone have any helpful info or tips for me? Also what are the c-clips for? Thanks so much for any and all help.
HILLBILLY is offline
post #2 of 9 Old March 30th, 2010, 06:49 PM
FJK's Avatar
First Name: Frank
Member #8689
Feedback Score: 18 reviews
View FJK's Photo Gallery(279)
Re: I need help with pro armor doors.....
Hi there ia a build up of the powder coating on the threads put a wrench on it and turn them in slowly ,be careful not to cross thread them ,
FJK is offline
post #3 of 9 Old March 30th, 2010, 06:49 PM
Sparky's Avatar
First Name: Dave
My RZR: Aerocharged 1110
Member #1007
View Sparky's Photo Gallery(0)
The problem is the powder coating. Take your time - And thread in a couple of turns - Then back out the latch. Repeat this procedure until the latch gets thru the tab.
The c-clip is for door adjustment. Look at the hinge - There is already one c-clip installed. You can raise/lower slightly the door with the use of the c-clip.
Another tip for ya -- You have to drill a hole for the striker/latch to secure the door closed. Do this carefully and you will be rewarded !!
Do it this way -- Use a piece of cardboard and fold it and use this to raise up the door when you shut it. Carefully mark the hole now that the door is slightly raised and also fully closed. Drill the hole and use RED loctite to secure the plastic insert in the drilled hole.
When you are done - The door will not rattle if you do as i've suggested.
Also - Reuse the allen bolt you took out of the front of the roll cage for the back securing tab on the door.
Sparky is offline
post #4 of 9 Old March 30th, 2010, 06:55 PM Thread Starter
HILLBILLY's Avatar
First Name: Travis
Member #13525
Thanks guys for all the info. My doors arent powder coated. The latch will start to go in then it starts to cross thread. It does this on both doors.
post #5 of 9 Old March 30th, 2010, 07:02 PM
Sparky's Avatar
First Name: Dave
Member #1007
Your doors may be coated with a clear coat - Try this ...... Thread in the latch from the other end of the threaded tab.
Other than this suggestion ....... Call um tomorrow and see what they can offer you.
Good Luck .........
Sparky is offline
post #6 of 9 Old March 30th, 2010, 07:11 PM
FJK's Avatar
First Name: Frank
Member #8689
The doors are clear coated ,if you doint have any luck call Alex he is the ceo ,and a great guy 951-343-9270 ,tell him Frank told you to call ,let me know how it works out.i have 2 sets of their doors the black ones were powder coated the silver ones were clear coated .
FJK is offline
post #7 of 9 Old March 30th, 2010, 07:27 PM
King of crash!
Member #787
fjk door's are nice and dont rattle fit great too.....
johnnycat8 is offline
post #8 of 9 Old March 30th, 2010, 08:36 PM Thread Starter
HILLBILLY's Avatar
First Name: Travis
Member #13525
Thanks for all the help guys. Could i use a tap & die set to clean out the threads?
post #9 of 9 Old March 30th, 2010, 09:20 PM
FJK's Avatar
First Name: Frank
Member #8689
that would do it for sure ,go slow you do not want to cut new threads ,
FJK is offline
Pro Armor Doors dudeonit Roll Cages and Safety Equipment 239 December 11th, 2012 11:46 AM
Pro Armor Doors on the 4 Chopjaw RZR 4 Specific Discussion 14 April 1st, 2010 09:50 AM
Pro Armor doors fast68 General RZR Discussion 44 March 16th, 2010 10:24 AM
Purchase Pro Armor doors? HardcoreHeath Roll Cages and Safety Equipment 2 February 15th, 2010 07:32 PM
Pro Armor doors hipcash RZR-S Specific Discussion 28 January 19th, 2010 06:33 PM
