Fast in Low Gear or Slow in High Gear? - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old February 27th, 2010, 06:29 PM Thread Starter
WARPARTY36's Avatar
First Name: Robert
My RZR: 2018 General Ride Command
Member #11427
View WARPARTY36's Photo Gallery(0)
Question Fast in Low Gear or Slow in High Gear?
I remember 7 mph being the guideline number whether you should be in low or high gear for extended belt life. If you are on a trail where you are crawling rocks with short runs inbetween them and can hit 15-20 mph, is it better to stay in low? Should you crawl in high gear at all? Shifting back and forth all the time can't be good on them either?
Let's hear some opinions
WARPARTY36 is offline
post #2 of 10 Old February 27th, 2010, 06:41 PM
SPCAS40's Avatar
My RZR: '10 RZRs / RZR170
Member #13350
View SPCAS40's Photo Gallery(0)
Re: Fast in Low Gear or Slow in High Gear?
I want to know the same info Warparty. I find myself in that same window quite a bit.
2010 RZR-S (x2), RZR170 pulled by my trusty '02 Cummins 2500 which is almost broke in
SPCAS40 is offline
post #3 of 10 Old February 27th, 2010, 06:51 PM
jeepster's Avatar
First Name: Dan
My RZR: 08 Green
Member #34
View jeepster's Photo Gallery(0)
i crawl on rocks or thru mud in low. then rev it up for those peices between the xlow parts.
08 Green
Power Steering
Rubberdown Lift
29.5 Outlaws
Holz Billet Diff Carrier
Snorkeled
SSV IPod stereo
jeepster is offline
post #4 of 10 Old February 27th, 2010, 06:52 PM
Searching_ut's Avatar
First Name: Jeff
My RZR: 2010 800 LE
Member #11223
View Searching_ut's Photo Gallery(0)
I tend to stay in low and just wrap up the motor a little. As long as you're not getting to high rpm wise, it shouldn't be too hard on the motor, and it's the way I always ran my trucks without having engine issues. Staying in high range and lugging it however can lead to belt slippage, and other problems. Like you guys, I sure wish you could shift between high and low on the fly.
2010 Silver LE, Tusk uhmw skids, FUTV a-arm skids, Roktek 3" lift, Tusk soft top, Tusk Mirror, UTV crap seat lowering bases, RyFab storage box, Kolpin 4 gallon flatpack gas can
Searching_ut is offline
post #5 of 10 Old February 27th, 2010, 07:59 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Since the motor wants to run in the 5500-6000 range anyway for best torque, when crawling I will go low gear then if short runs inbetween will stay in low gear, you can run upto 28 mph before you hit the rev limiter. If it is going to be a longer stretch where i think I will be going faster than 20 ish, i will stop and shift to high. I do not see that you will damage the belt running high rpm in low, rather you can damage the belt running low rpm with high torque need in high gear.
XP1000 Titanium Black
RZR 800 put out to pasture
1 Limey in a world of Yanks
rjsmith is offline
post #6 of 10 Old February 27th, 2010, 08:11 PM
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
i run low for anything under 20 mph no problems whatsoever.
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
HivoltageRZR is offline
post #7 of 10 Old February 27th, 2010, 08:11 PM
jklein322's Avatar
First Name: Jim
My RZR: 2016 XPTurbo
Member #2348
View jklein322's Photo Gallery(19)
I tend to keep it in high all the time.
Jim
Phoenix Arizona
2020 Pro XP
WWW.UTVINC.COM
jklein322 is offline
post #8 of 10 Old February 27th, 2010, 08:11 PM
biohazard58's Avatar
First Name: justin
My RZR: 08 rzr
Member #3428
View biohazard58's Photo Gallery(0)
i think my rzr has only been in low mabie twice really for no reason lol and i ride pritty much all kinds of trails im in high all the time
biohazard58 is offline
post #9 of 10 Old February 27th, 2010, 08:26 PM
blazeman's Avatar
My RZR: 2013 900xp turbo
Member #12099
View blazeman's Photo Gallery(0)
As a rule of thumb... I try to never run, at least on a pull (climb) below 3200 rpms. I belive I read this in a owners manual somewhere. It may have been in my 05 sportsman 800 manual. I have had that machine since new, and still have the same belt. and I have done a lot of pulling and climbing with the sportsman through the years, and it still runs great, so I figure to do the same with this rzr, even though, I don't remember seening this recommendation in the 2010 rzr manual. As I believe they have the same basic twin Polaris 800 engine, and transmission set up..John
blazeman is offline
post #10 of 10 Old February 28th, 2010, 05:25 PM Thread Starter
WARPARTY36's Avatar
First Name: Robert
Member #11427
Good and varying opinions so far. Any one else have an opinion or experiences from doing the wrong thing on speeds and gears?
rzr stuck in high gear dkreuz Engine and Drivetrain 16 January 26th, 2010 11:36 AM
Razr is "stuck" High gear and won't move beerseason Engine and Drivetrain 29 November 9th, 2009 07:06 PM
won't go into geaR pszutiak Engine and Drivetrain 2 July 10th, 2009 09:04 PM
Shifter Hard to get out of High Gear, Help Fatboy4diesel Engine and Drivetrain 3 April 3rd, 2009 08:03 AM
Gear Selection High/Low. txmd500 Engine and Drivetrain 4 January 17th, 2008 05:26 AM
