EPS stopped working?!!? Help please! - Polaris RZR Forum - RZR Forums.net
post #1 of 15 Old February 1st, 2014, 09:12 AM Thread Starter
SilverbulletXP4's Avatar
First Name: Brian
My RZR: 2013 XP4 LE
Member #51821
View SilverbulletXP4's Photo Gallery(0)
Ok so I lawn darted my xp4 pretty good, checked the suspension and steering parts over and over again and all looks good. Problem is ever since I nosed it the power steering won't work. The warning light is on. I checked the relay and it's still good.
Anyone have anything like this happen?
SilverbulletXP4 is offline
post #2 of 15 Old February 1st, 2014, 09:37 AM
chillout's Avatar
First Name: Jim
My RZR: 2013 570 LE
Member #57746
View chillout's Photo Gallery(0)
Re: EPS stopped working?!!? Help please!
One time with mine, I turned the key on/off 3x's and then started the machine. What ever was wrong was cleared and has never happened again. Good luck.
Jim
chillout is offline
post #3 of 15 Old February 1st, 2014, 10:03 AM
blackrhinokenny's Avatar
First Name: Kenny
Member #27327
View blackrhinokenny's Photo Gallery(0)
We learned the hard way putting on an aftermarket steering wheel on the 900 xp that if you hit the center of the steering wheel to remove it, bam it ruins the power steering and has to be replaced.
Not sure if the 1000 is the same, but if it is, I think a hard enough impact while holding the steering wheel real tight could cause the same failure.
blackrhinokenny is offline
post #4 of 15 Old February 1st, 2014, 10:25 AM
trailblazersonny's Avatar
First Name: Sonny
My RZR: 12 RZR 800
Member #48869
View trailblazersonny's Photo Gallery(1)
Check the battery and all your power connections. If thats all good the impact probably did her in. Good Luck... That really blows..
TBS
I can make it up that!!
12 RZR 800
Tusk Skid Plate, ITP SS316, Duro Power Grip Tires, Racer Tech Dual Rate Springs, Prawltector, Cooter Brown Top,
EMP Stick Stoppers, Polaris Sport Seats, Grumpy Mod Pirate Style, KFI Winch
Lock-n-Ride Cargo Box , EMP Flip Up Windshield, ATV Guru front Brush Guard
trailblazersonny is offline
post #5 of 15 Old February 1st, 2014, 11:33 AM
FJK's Avatar
First Name: Frank
Member #8689
Feedback Score: 18 reviews
View FJK's Photo Gallery(279)
1000 is the same way .
FJK is offline
post #6 of 15 Old February 1st, 2014, 01:04 PM
chillout's Avatar
First Name: Jim
My RZR: 2013 570 LE
Member #57746
Good to know. Thanks for the heads up. That's the spot where my wife raps her cell phone to make it pick up a signal. I tell her it won't help, but she never listens to me anyway.
chillout is offline
post #7 of 15 Old February 1st, 2014, 01:52 PM
muduck's Avatar
First Name: Brian
My RZR: 2016 XP 1000 Highlifter
Member #48469
View muduck's Photo Gallery(0)
I put my 1000 through a deep muddy puddle a few weeks ago and blew the EPS fuse under the drivers seat.
muduck is offline
post #8 of 15 Old February 2nd, 2014, 12:42 PM Thread Starter
First Name: Brian
My RZR: 2013 XP4 LE
Member #51821
Is there anyway to test the power steering unit to tell if it's bad? Don't want to go out and buy a new one if that's not the issue
post #9 of 15 Old February 2nd, 2014, 01:25 PM
muduck's Avatar
First Name: Brian
Member #48469
First replace the fuse, then undo the electrical harness under the steering wheel and check to see if you have power .
muduck is offline
post #10 of 15 Old February 2nd, 2014, 01:46 PM
Scoundrel's Avatar
First Name: Paul Sterley
My RZR: 2017 XP 1000 Velocity Blue
Member #20335
View Scoundrel's Photo Gallery(2)
Scoundrel is offline
post #11 of 15 Old February 4th, 2014, 10:36 AM Thread Starter
First Name: Brian
My RZR: 2013 XP4 LE
Member #51821
cant find a fuse that is labelled for the EPS? only a relay
post #12 of 15 Old February 4th, 2014, 03:44 PM
shane wade's Avatar
First Name: Shane
My RZR: 2016 turbo
Member #25218
View shane wade's Photo Gallery(1)
try turning the key on and off 3 times. That worked for me
shane wade is offline
post #13 of 15 Old October 25th, 2017, 05:55 PM
Boagey's Avatar
First Name: Craig
My RZR: 17 XP1000 Ride Command
Member #103321
View Boagey's Photo Gallery(0)
I hit a small ditch, my EPS went out. After reading many posts this morning, I checked my fuse with an ohm meter, it was good, checked for power at the EPS under the dash and there was power, lets me believe the part is bad. If this parts breaks every time you hit a ditch, rock, etc, a very poor design.
Boagey is offline
post #14 of 15 Old October 25th, 2017, 09:05 PM
Scoundrel's Avatar
Member #20335
I hit a ditch in August. I slammed the steering wheel so hard I felt it bend a little. Afterward, my EPS seemed to not be working, though I didn't get any error codes or lights. Further investigation revealed that I simply slammed the steering linkage further down onto the input shaft of the EPS unit. I could see where the splines were dirty, and then about 3/16" of clean splines. I loosened the bolt on the linkage, and it popped back up on the splines, back to where the dirt stopped. So it was applying upward pressure on the input shaft, binding it until I loosened it to let it settle back to the right position, and then tightened it again. All better.
post #15 of 15 Old October 29th, 2017, 06:07 PM
littleboss's Avatar
First Name: Donald
My RZR: 2016 XP Turbo Spectra Orange
Member #47857
View littleboss's Photo Gallery(1)
My XPT has a fuse for the EPS. I have blown it several times while rockcrawling.
'16 XPT & '17 GENERAL & '15 Polaris Ranger XP 900
If you like old John Deere tractors https://antiquetractorblogger.blogspot.com/
littleboss is offline
Tapatalk Stopped Working tbg4 Community Help 5 August 12th, 2013 04:10 PM
Fan stopped working..... GRRRRRRRR! straw2gold Engine and Drivetrain 3 March 15th, 2012 10:25 PM
Trip meter stopped working jsandgren10 RZR XP 900 11 August 27th, 2011 08:17 AM
2011 Headlights stopped working. BruiserID Community Help 4 December 21st, 2010 02:01 PM
tilt stopped working mudweiser-z71 General RZR Discussion 9 January 5th, 2010 09:03 PM
