Do you use Anti-Seize when installing new axles?
  • Yes
    Votes: 198 88%
  • No
    Votes: 28 12%
Installing New Axles - Anti-seize? or Not?
1 reading
50K views 49 replies 35 participants last post by  Pullerguy
Just was thinking after reading a few post, that some are using anti-seize when installing axles and some do not. What are your thoughts? :popcorn:
I use never sieze, I also put a little on the hubs where they go into the wheel bearings, had one of the stock ones (no never sieze) get stuck in wheel bearing once, and bugered up hup trying to get them apart, never again. Also I ride where water is, dif. animal here on the East Coast.
Thanks gentlemen. First time I have ever done a mod this big and just wanting to make sure. I have ridden twice since I completed the +5 kit, HD tie rods and lift kit. Love it. Like a different machine. Even the wife noticed a huge difference.
Send from a Samsung 4S using Tapatalk
#20 ·
I use ant seize when replacing mine.
#21 ·
If you want to make them easier to remove for next time, then yes, by all means either grease them or use anti-seize. Personally, I used synthetic "Green-Grease", which is high-temp, high-impact, and, most importantly, waterproof, so that the axle-stubs and splines won't rust or corrode from water-exposure. My two-bits............
Cheers
#22 ·
I personally use antisieze
#24 ·
I replaced rear wheel bearing this week and had to press the axles out of the hub because they were seized up. So yes, everything will be lubed with anti-seeze.
I dont how machines are put together now, but I dont understand why Polaris doesnt use any lube on bolts, axles, shock bushings ect.
#28 ·
X2
Sent from my SAMSUNG-SGH-I337 using Off-Road Forums mobile app
#29 ·
I dont know about the rest of the machines but my 570 is not wet. The rear axle was seized in the diff, I had one heck of a time getting it out. I wont next time though, I just hope the anti sieze works it way over to the other side when I have to change it.
#32 ·
No anti-seize is not an abrasive!!! Gads, get just a pinch on your finger and before you know it, you've to it all over you. If it was abrasive...you'd know it pretty quick!!
I use nickel-based anti-seize on every splined shaft except the end of the rear axles that plug into the diff. As noted, they are in the diff lube so you don't need it.
I use it on every fastener that is on of the "self threading" type. Like the ones that hold the skid plate on. Most of the fastener is exposed, and so it gets covered with mud and who knows what else. The anti-seize will allow you to get the fastener out without ruining it and the threads.
Nickel-based anti-seize is somewhat moisture proof so it doesn't wash off for quite a while. I apply it in a thin coat using a soldering flux brush for the applicator. Doesn't take much!
JMHO
Pirate
Pirate
#34 ·
Only the 800's have the rear inner axle splines into oil.
All other models are a dry socket front and rear.
I like never seize also. But good marine grease will work to. Just don't install them dry. You will regret it later.
