Too much torque on my Z1 swap? - Polaris RZR Forum - RZR Forums.net
Engine Swaps Discussions for Engine Swaps and Engine Replacements.
post #1 of 1 Old May 22nd, 2017, 06:17 PM Thread Starter
drcracer's Avatar
My RZR: 2014 XP 1K soon to be Z1
Member #47304
View drcracer's Photo Gallery(0)
So there I was, checking bolts on the engine mounts to see if anything came loose after my dune season and I see this! The extra support bracket that I welded to the cross member tore! I used 1/8" angle steel, guess that wasn't enough. The welds held, but the bracket did not. Even if I used heavier steel, I'd still have the same problem. Not only did the bracket tear, it pulled up on the cross member bending it! I'll have to take more pictures. But has anyone else had this problem who welded a support bracket to the front cross member?
ID:	426401   Click image for larger version
drcracer is offline
Differential fill plug broke using torque wrench! aswetich RZR 800 Specific Discussion 8 May 23rd, 2017 09:57 AM
2014 XP1000 parts swap with 2016 Turbo JGlover General RZR Discussion 3 April 7th, 2016 11:25 AM
1000 diff swap done Dozer600 RZR 570 Specific Discussion 3 February 18th, 2016 03:16 AM
Torque Spec Anyone? Maxpolaris RZR 570 Specific Discussion 4 January 10th, 2016 06:58 PM
