XP to RZR front differential swap - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 159 Old March 21st, 2013, 10:32 AM
Fun4many's Avatar
First Name: Don
My RZR: RZR 1000 Nuclear Sunset
Member #52968
View Fun4many's Photo Gallery(0)
Re: XP to RZR front differential swap
Your calling the cage the aluminum housing? I'm assumming after reading that the difference in the housings are one (900) is thicker than the (800)? I currently have a 900 rzr xp4 and shattered the housing this past weekend and am looking for a replacement to carry with me. I have noticed the 800's are more available and less expensive. Warranty is supposed to cover my stock one but the breakage put me out of commision. If I would have had a spare I could have been rolling again.
Fun4many is offline
post #17 of 159 Old March 21st, 2013, 11:10 AM
jamies123a's Avatar
My RZR: 2012 xp4 900
Member #40852
View jamies123a's Photo Gallery(0)
the aluminun housings are the same ..
Look at the links i gave you
the part numbers for the the cover and housing for the xp and 800 are the same
Kit, Gearcase Asm. [Incl. Hose Fitting, [+]
3235172
Asm., Cover Output [Incl. O-Ring, Dowel [+]
3235168
what i am talking about is the cage inside
Asm., Billet Roll Cage [Incl. Roll Cage, [+]
3235262 --- this is the xp
Asm., Roll Cage, Zn [Incl. Roll Cage, [+]
3235261 --- this is the 800
all the rest are the same part numbers
jamies123a is offline
post #18 of 159 Old March 21st, 2013, 11:55 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Fun4,
It would be interesting to see what you find in the shattered housing. A lot of what has been seen, and I have one in the shop, is that the pinion nut comes loose, the pinion moves deeper into the ring gear, gets wedged and then the rotation forces the pinion down and shatters the housing.
Would be interesting to see what caused yours. Pictures maybe?
Thanks,
Pirate
Pirate is offline
post #19 of 159 Old March 21st, 2013, 12:04 PM
jamies123a's Avatar
Member #40852
Originally Posted by Pirate View Post
Fun4,
Thanks,
Pirate
mine was the ring gear teeth were torn off ... i missing around 4 teeth .. all chewed up ... Nut was tight taking it apart ...
was almost as much to buy ring and pinon kit then a complete new one ..
post #20 of 159 Old March 21st, 2013, 12:14 PM
King of crash!
Member #787
i see some confusion with some answers here.... first 08-10 800 vs a xp 900 front diff they are differant the xp is larger and as said it will fit with some triming wile your 11 800-4 may be the same this doesnt mean all are also is a non 4 2011 the same? it could be they put the bigger diff in the 4 seaters.
johnnycat8 is offline
post #21 of 159 Old March 21st, 2013, 12:16 PM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
My understanding is that to run a 2011+ diff in a 2008-2010, you need to also shorten the propshaft, or replace it with the later one.
We ordered all the parts to do this in a 2009 RZR S, just waiting for them to show up to make sure it is that simple.
I found this thread when researching this, it has some good photos:
https://www.rzrforums.net/engine-driv...f-changes.html
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #22 of 159 Old March 21st, 2013, 12:29 PM
jamies123a's Avatar
Member #40852
the parts i listed are for the 2 seater ... 2010 and up xp,2 seater 4 seater are the same ... excatlly the same except for the cage inside.
The 2009 and down are different , totaly different but i too have read on here that they can be used in a 2010 up ..
post #23 of 159 Old March 21st, 2013, 12:39 PM
King of crash!
Member #787
i know all the xp are the same i was talking about the 800 you said your 800 diff is the same as the xp.
post #24 of 159 Old March 21st, 2013, 12:41 PM
Fun4many's Avatar
First Name: Don
Member #52968
Fun4,
Thanks,
Pirate
This is the only pic that I will have due to it being under warranty. I couldnt get in there to get a really good pic. Hopefully it loads.Click image for larger version
Name:	rzr differential.JPG
Fun4many is offline
post #25 of 159 Old March 21st, 2013, 12:41 PM
Member #25882
I believe that 2008 and 2009 are the same, in 2010 they added the metal carrier but kept the same housing, and in 2011 they completely changed the housing.
Here are the parts diagrams from Polaris:
2008-2009:
2010:
2011-2013 800:
2011-2013 XP(including jagged X:
Chris @ ARR
303-400-0205-shop #
post #26 of 159 Old March 21st, 2013, 12:44 PM
King of crash!
Member #787
according to hawk the diff change is in 2011 not 2010 and trust me hawk knows his stuff
post #27 of 159 Old March 21st, 2013, 12:46 PM
King of crash!
Member #787
2008-2009:
2010:
2011-2013 800:
ok it shows 2010 as the smaller diff still so the larger is a 2011 and up thing... alot of internal changes for the better too huge size increas on the pinion bearing that was a weak spot
post #28 of 159 Old March 21st, 2013, 12:47 PM
jamies123a's Avatar
Member #40852
sorry you are right i meant to say 2011 and up ... 2010 and down are differnt ... just look at the part numbers and you can see for yourself...
post #29 of 159 Old March 21st, 2013, 12:50 PM
Member #25882
The polaris parts catalog has all of those diagrams, plus exploded views of each different differential. There are some cool things to learn by studying the differences.
Chris @ ARR
303-400-0205-shop #
post #30 of 159 Old March 21st, 2013, 12:51 PM
King of crash!
Member #787
is the diff conector the same still ??? thats alot better diff but i also saw a brok one on here last night first one too this seems like a good upgrade for a older rzr or the turbo guys
Front Differential ... What Oil to use chipster314 General RZR Discussion 11 May 14th, 2013 05:24 AM
XP 900 front differential,half shafts,front axle,seat, steering wheel, seat belt, etc twvette Polaris RZR Parts For Sale 7 December 8th, 2012 12:10 PM
900 front diff swap??? sharktank RZR-S Specific Discussion 7 November 5th, 2012 12:20 PM
08 rzr front xp diff swap?? Fthl.kid.21 Engine and Drivetrain 1 November 3rd, 2012 06:54 PM
Yfz450 front shock swap for 50"RZR front end thundermountainatv Suspension 9 January 17th, 2011 06:38 AM
