Ultimate Front Diff Thread - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 607 Old February 27th, 2009, 12:56 AM Thread Starter
cheeeto's Avatar
Member #5837
View cheeeto's Photo Gallery(0)
Ok, so after hours of searching only to find others with the same problem and no solutions, I dug deeper into my front diff. I'll post what I've learned. If there is a mistake, please correct me. If there is other info, please add it.
I already blown up the stock plastic cage and replaced it with billet aluminum part. I was still having AWD engage while in 2WD. I completely unplugged the AWD at the front diff. It still locked into AWD. Cluncked REALLY hard too.
I pulled it apart to really understand how it worked. I leared that when the switch is activated and the coil is magnetized, it pulls the armature plate agianst the cover plate causing friction between the armature plate and the cover plate. Because the armature plate "slows" with the friction between the two, the ring gear rotates around the cage and causes the roler bearings to push inward and lock agianst the output hubs. This ultimately turns the front wheels.
Now because I already rebuilt mine with new parts and I was still having problems in the 2WD mode, I tore it all apart again. I found two problems that are cuasing what you may have experienced:
FIRST: the H-springs were damaged and did not push outward on the bearings in the factory cage. This would intermitantly allow the bearings to "fall" inward and the ring gear rotate into the AWD position. Its just plain physics. IT IS NECESSARY TO REPLACE THE H-SPRINGS WHEN REBUILDING.
SECOND: the grove on the inside of the billet cage has a tolerance that is too tight. This is where the h-spring rests. When the bearing is pushed in by the ring gear, it smashes the h-springs into a grove. The aluminum is so tight that the springs cannot retun and push the bearing back out. This allows the bearigs to again "fall" inward, causing the ring gear to rotate and act like its in intermittant AWD.
Tommorrow, I'm contacting the manufacturer of the cage and see what they can do. I'll post details later, but as I feel they can fix this, I won't flame the company...yet.
I'll post picture of the springs jammed into the groove that has been cut for them. Its obvious when compared to the stock cage how tight the billet cage is.
Updated
PHOTO CONTEST - Ugliest plastic cage???
Notice in the 3rd photo of the plastic piece sitting to the billet cage, this is how the spring should look. Its not smashed into the caged (Granted there is nothing left)
ID:	3918   Click image for larger version
ID:	3919   Click image for larger version
cheeeto is offline
post #2 of 607 Old February 27th, 2009, 06:46 AM
guy48065's Avatar
Member #309
Feedback Score: 16 reviews
Re: Ultimate Front Diff Thread
Originally Posted by cheeeto View Post
I leared that when the switch is activated and the coil (5) is magnetized, it pulls the armature plate (20) agianst the cover plate (3) causing friction between the armature plate and the cover plate. Because the armature plate "slows" with the friction between the two, the ring gear (22) rotates around the cage (25) and causes the roler bearings (23) to push inward and lock agianst the output hubs (10, 15). This ultimately turns the front wheels.
Pictures will really make this the Ultimate Front Diff Thread.
guy48065 is offline
post #3 of 607 Old February 27th, 2009, 07:29 AM
kedi's Avatar
First Name: Ken
My RZR: Gen II 2008
Member #1014
View kedi's Photo Gallery(1)
Thanks for the info ... your the "Man"
Ken
kedi is offline
post #4 of 607 Old February 27th, 2009, 09:22 AM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
Good solid info and awesome with the pic. I put the aluminiunm cage in and reused my H springs. Its been in for a year now and I've used the 4wd alot and have been pretty hard on it. I haven't had any problems. Anybody else had problems with th Al cage?
post #5 of 607 Old February 27th, 2009, 09:34 AM
guy48065's Avatar
Member #309
I have a couple questions to try to better understand how the Hilliard works.
Is the armature attached to the cage?
Are the grooves inside the housing (ring gear) actually ramps?
If both are "yes" then I think I get it. The armature drags and twists the cage and the rollers are forced by the ramps to cam down into the hubs & grab.
I hope this is right or I'm just muddying the water more...LOL
guy48065 is offline
post #6 of 607 Old February 27th, 2009, 03:00 PM
Trail Junky
Dusty's Avatar
First Name: Brian
My RZR: 08 Rzr
Member #20
View Dusty's Photo Gallery(0)
Heres a little troubleshooting guide I picked up from somewhere online a few years ago. Kind of hard to read, but it is a good guide for troubleshooting front end problems.
Brian
Otsego, Mi
08 Mean Green
Dusty is offline
post #7 of 607 Old February 27th, 2009, 05:36 PM
Stumpduster's Avatar
First Name: Mike #688
My RZR: 16 1000 XP
Member #1676
With the added diagrams this thread is well on it's way to living up to the title keep it coming!
Stumpduster is offline
post #8 of 607 Old February 27th, 2009, 07:13 PM
mack90
mack90's Avatar
First Name: mack90
Member #6000
View mack90's Photo Gallery(0)
anyone every break the armature plate mine broke 400 miles 2 months old anyone have an after market replacement
mack90 is offline
post #9 of 607 Old February 27th, 2009, 07:31 PM
Site Supporter
GIFF-TURBO's Avatar
First Name: Gary
Member #3946
Feedback Score: 18 reviews
That was great guys............. This need to become a sticky
GIFF-TURBO is offline
post #10 of 607 Old February 28th, 2009, 08:13 AM
guy48065's Avatar
Member #309
Re: Ultimate Front Diff Thread - Pics added
Wow--you almost didn't have a chunk big enough to show us the fit!
guy48065 is offline
post #11 of 607 Old February 28th, 2009, 02:56 PM
HivoltageRZR's Avatar
My RZR: Gen 3
Member #2522
good write up man!
2008 Polaris RZR - 29.5" Outlaws - SS 312 - SSV Works Overhead System - 2" Lift kit - Polaris Sport Roof - Dynatek CDI- Viper 3500 Winch - Custom Snorkels - HL Lift Springs - RZR S Exhaust - Super ATV Axles
HivoltageRZR is offline
post #12 of 607 Old March 1st, 2009, 10:20 AM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
There is A huge market for aftermarket front and rear diffs.There are several problems with both of them.They are not strong enough for the extreme riders.Someone needs to capitalize on it
crazywatson is offline
post #13 of 607 Old March 6th, 2009, 03:11 PM Thread Starter
cheeeto's Avatar
Member #5837
Bumping because people are asking question, and looking at teh other treads on this site..
cheeeto is offline
post #14 of 607 Old March 6th, 2009, 05:22 PM
Banned
sporlan's Avatar
Member #2879
View sporlan's Photo Gallery(0)
I too have the aluminum cage and love it. I ride trails very hard and have had no issuse with it. I don't care what others may say, the plastic Polaris POS is only good for 1 thing and that's the dumpster!
sporlan is offline
post #15 of 607 Old March 24th, 2009, 12:54 PM Thread Starter
cheeeto's Avatar
Member #5837
Glad to see that everyone is adding info and feedback.
I have to tell everyone that I am having trouble with Dragon Fire Racing. For three days, they have not returned my calls as they said they would. They've had my cage for a while now and I've not heard anything from them. We'll see if they come through.
cheeeto is offline
The ULTIMATE pricing thread!! Post what you paid here! Antimatter RZR XP 900 271 April 7th, 2013 07:00 AM
stripped thread rear diff drain bugmanrzr RZR-S Specific Discussion 16 February 23rd, 2013 11:12 AM
Ultimate XP SAND TIRE thread royalnine RZR XP 900 169 January 11th, 2012 02:33 PM
Front Diff. Parts or complete front diff. klewis34 Want to Buy 0 March 23rd, 2011 05:25 PM
Ultimate Axle Clicking Thread HivoltageRZR General RZR Discussion 22 May 1st, 2009 09:38 AM
