Ultimate Front Diff Thread - Page 41 - Polaris RZR Forum - RZR Forums.net
 2Likes
post #601 of 607 Old July 11th, 2018, 08:47 AM
ILquadrider's Avatar
Member #156033
View ILquadrider's Photo Gallery(0)
Re: Ultimate Front Diff Thread
Been having issues with my 2012 rzr 800s front diff. Stuck in awd in forward gears and no awd in reverse. Got the diff out and torn apart. The sprague appears to have a break in one of the wires holding it together. Is that normal or not? I'll attach a picture.
2012 rzr800s
ILquadrider is offline
post #602 of 607 Old December 4th, 2018, 08:19 AM
DONOVAN1964's Avatar
First Name: CHRIS
My RZR: 2008 RZR 800S 2 SEATER
Member #263818
View DONOVAN1964's Photo Gallery(0)
I have replaced my sprauge gear with an new one and now have it back together. now when I spin it on the table the axel moves like in 4x4. is this normal? I did try and stop it with tools and it is engaged real snug. did I put together wrong? it spins good but I just was thinking it should not move axles until I plug in and hit awd.... HELP
DONOVAN1964 is offline
post #603 of 607 Old April 12th, 2019, 05:35 PM
WickedWhite's Avatar
Member #268468
View WickedWhite's Photo Gallery(0)
Anyone put a 2011-2014 front diff in a 2008-2010 rzr 800?
WickedWhite is offline
post #604 of 607 Old July 6th, 2019, 01:04 PM
wcs61's Avatar
First Name: Bill
My RZR: 2013 RZR S
Member #52990
View wcs61's Photo Gallery(0)
Okay to avoid having to read 12 pages and get a quick answer what kits is best for a 2014 800 S front differential?
I know the plastic cage has to be coming apart with the slack in my axles at the diff housing. It gets worse little by little. I just change the fluids and the seal did their part. Not a drop of water mixed in with the oil fluid.
I want to replace all seals, bearings, cage, and H clips unless you think I should add more parts.
2013 White / Orange RZR S
Motomax tires, MSA M18 wheels
27x10x14 front
27x12x14 Rear
SuperWinch Tera4 4K lb winch
Top, Fold down windshield
Custom Stereo/power outlet unit
Custom Speaker/power control unit
wcs61 is offline
post #605 of 607 Old July 6th, 2019, 02:04 PM
Clothier's Avatar
First Name: Brian
Member #65577
The 2013 should not have a plastic sprague. It should have a cast zinc cage. Where are you getting slack? If you are talking about where the front axles plug into the diff then more than likely your problem isn't the sprague, instead its likely the axle stubs are worn. They are softer than the diff output hubs, so when they get dirt and water around them it eats the axle stubs. I've replaced mine twice in 5000 miles and they could stand it again now.
Clothier is offline
post #606 of 607 Old July 6th, 2019, 04:47 PM
wcs61's Avatar
First Name: Bill
My RZR: 2013 RZR S
Member #52990
The 2013 sgould not have a plastic sprague. It should have a cast zinc cage. Where are you getting slack? If you are talking about where the front axles plug into the diff then more than likely your problem isn't the sprague, instead its likely the axle stubs are worn. They are softer than the diff output hubs, so when they get dirt and water around them it eats the axle stubs. I've replaced mine twice in 5000 miles and they could stand it again now.
If so I should be able to pop the axles out and mic them to see how wear they have, any specs for those? These are the factory axles on front and I only had to change one in the rear thanks to the wife knocking a boot off the CV joint.
All in all it's a 13 so I will go ahead and rebuild the front diff just to be on the safe side.
27x10x14 front
27x12x14 Rear
wcs61 is offline
post #607 of 607 Old July 6th, 2019, 05:19 PM
Clothier's Avatar
First Name: Brian
Member #65577
I honestly have no clue what the specs would be if there are any listed anywhere. And I would at least put a billet sprague in the diff. My zinc cage shattered. I'm running a JJ & A Racing sprague in mine. Also using their breather cover on the valve cover. Both high quality parts. And great guys to deal with.
wcs61 likes this.
Clothier is offline
The ULTIMATE pricing thread!! Post what you paid here! Antimatter RZR XP 900 271 April 7th, 2013 07:00 AM
stripped thread rear diff drain bugmanrzr RZR-S Specific Discussion 16 February 23rd, 2013 11:12 AM
Ultimate XP SAND TIRE thread royalnine RZR XP 900 169 January 11th, 2012 02:33 PM
Front Diff. Parts or complete front diff. klewis34 Want to Buy 0 March 23rd, 2011 05:25 PM
Ultimate Axle Clicking Thread HivoltageRZR General RZR Discussion 22 May 1st, 2009 09:38 AM
