What Oil and oil filters are you guys using?? - Page 14 - Polaris RZR Forum - RZR Forums.net
View Poll Results: What oil filter
Stock 246 56.94%
Fram 25 5.79%
Bosch 8 1.85%
Mobil 1 55 12.73%
Others...Please do tell 98 22.69%
Voters: 432. You may not vote on this poll
post #196 of 209 Old July 30th, 2010, 07:23 PM
Redfish's Avatar
My RZR: 2010 RZR S white and Wife has 2010 RZR S Orange
Member #17132
View Redfish's Photo Gallery(0)
Re: What Oil and oil filters are you guys using??
So looking to do oil change on mty 2010 and I made notes of a ton of numbers on all 14 pages of this post...Can someone confirm the 2010 is the same?
Redfish is offline
post #197 of 209 Old August 1st, 2010, 04:25 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Using Joe Gibbs Racing XP7 semi-synthetic motor oil. That's what Holz Racing recommended for the Stage III motor. Using Polaris filter. Did buy a set of Channelock filter pliers....makes it easy to get the filter off anything I own. (and that's a lot)
Pirate is offline
post #198 of 209 Old August 1st, 2010, 07:22 AM
De Oppresso Liber
LouDiamond's Avatar
First Name: Scott
My RZR: 09 RZR
Member #3259
How long have you had your HOLZ stage 3 Big Bore Kit?
PRODUCTS I USE ON MY RZR AND VENDORS I RECOMMEND
UTV INC (623) 934-3070
HOLZ Stage 3 Big Bore Kit (360) 398-7006
PIT BULL TIRES
Rugged Radios (888) 541-7223
RIGID INDUSTRIES LED Bars, 20" and 6" Amber
LIQUID EYEWEAR SUNGLASSES AND GOGGLES
LouDiamond is offline
post #199 of 209 Old August 1st, 2010, 09:34 AM
hoser's Avatar
First Name: Hoser
Member #6551
View hoser's Photo Gallery(0)
Originally Posted by jmarx82 View Post
I finally got all my fluids in my RZR switched to amsoil and I am impressed. The engine seems to run better and smoother. I put the series 2000 chaincase oil in and it also seems to shift better. I have just been really impressed with the amsoil products in all my vehicles.
If this is something you can see or feel then this is something Amsoil can show by using a chassis dyno and with vibration detection equipment another words factually show their is an improvement just by changing your oil, you need to contact them and tell them your story perhaps they will investigate it use you or your idea in their advertisements and supply you with oils
hoser is offline
post #200 of 209 Old August 2nd, 2010, 05:10 AM
Pirate's Avatar
First Name: Stuart
Member #3677
I got the Holz Stage III kit installed in mid-June. Been out on the trails with it four times and man does it like to climb hills and roar down the trails!!!
Pirate is offline
post #201 of 209 Old August 2nd, 2010, 08:00 AM
De Oppresso Liber
LouDiamond's Avatar
First Name: Scott
My RZR: 09 RZR
Member #3259
I can second that. I am very impressed with the Holz Stage 3 Big Bore kit's performance. If only they came with an engine like that from Polaris, but I doubt that will happen any time soon.
PIT BULL TIRES
post #202 of 209 Old August 2nd, 2010, 11:44 AM
Desert Rat
scotty1111's Avatar
First Name: Scott
My RZR: 2010 RZR S LE Purple Thunder
Member #14659
View scotty1111's Photo Gallery(0)
Redfish, if your RZR is still under warranty I'd go with Polaris fluids. That way, if something should go south, they can't give you the old "You were running non-recommended oil" routine. And save your receipts!
Dune Shooting is indeed a blood sport, at least in my case!
You can say 'STOP' or 'ALTO' or use any other word you think will work, but I've found that a large bore muzzle pointed at someone's head is pretty much the universal language.
scotty1111 is offline
post #203 of 209 Old August 2nd, 2010, 11:49 AM
Redfish's Avatar
Member #17132
Probably should have but to late I did it Saturday night. Its all done and was a snap at that.
Glad I did not pay for the maint. package on mine....just wished we had not bought it on hers either. Oh well you learn from mistakes.
Very hard to find 0W 40 it appears down here. Also wanted to run the walmart filters but tried two of them and they dont have them so had to go with another brand that yall said fits.
Redfish is offline
post #204 of 209 Old August 6th, 2010, 01:57 PM
CanuckRzrS's Avatar
First Name: Greg
My RZR: 2009 Rzr S
Member #16469
View CanuckRzrS's Photo Gallery(9)
I ran Rotella T in my Yami Kodiaks... will run it in my Rzr S when the warranty runs out...
'09 Rzr-S Dalton Clutch Kit / Cummins OptiAir Intake / Snorkels By guy48065 / Remote Viper Winch / Makin Trax Progressive Springs / EMP A-arm Guards / Pro Armor Doors / Pro Armor 5pt Harnesses / J Strong Roof With Stereo / HID's By DDM / Bush Guard / Shoulder Bag
CanuckRzrS is offline
post #205 of 209 Old August 28th, 2010, 03:32 PM
ssjeff's Avatar
My RZR: 2008 RZR
Member #17467
View ssjeff's Photo Gallery(0)
I have been running Rotella In my Polaris outlaws since it will work with wet clutches and it is CHEAP at walmart. Not one problem with it. To make it even better I add Lucas Oil Stabilizer to it. With the wet clutch of the quad they recommend using less than 10% of the Stabilizer. It seems to shift better with it. And it is around $10 q quart which lasts quite a long time for me with 2 Outlaws. I will run this same thing in my RZR. I also run it in my Triumph Daytona 955i. Not one issue.
I heard about the Rotella from racers. I guess the KTM racing team uses Rotella and most racers who have to buy their oil do to. The ones who get Klotz and other brands use it and I would too if they gave me oil.
ssjeff is offline
post #206 of 209 Old August 29th, 2010, 09:48 AM
Pirate's Avatar
First Name: Stuart
Member #3677
I just put in one of the Ultimate SXS (used to be Ultimate Rhino) oil filter relocation kits. put the filter up high and nearly vertical on the left side by the air filter box. Using a Bosch 3500 filter...so the system now holds nearly 3 qts of oil.
Since having the Holz Stage III motor kit installed, I'm using Joe Gibbs XP7 oil as Holz recommends.
Doesn't use a drop, oil fiter is now a snap to change, doesn't make a mess, and system holds more oil. The Gibbs oil is available on their website, and they didn't charge me shipping.
Pirate is offline
post #207 of 209 Old November 5th, 2010, 11:02 AM
Jack Daniels please..
GEEZER's Avatar
First Name: Clem
My RZR: 09 Camo
Member #8938
View GEEZER's Photo Gallery(0)
Back to the oil filter discussion.. Napa now says 1356 (wix) for rzr 800..This filter flows more than the 1357..GEEZER
2009 RZR Camo
1985 Yamaha Tri-z
2007 Crew cab D-MAX
"Why don't you practice falling down, Ill be there in a minute..." BJL 2004
GEEZER is offline
post #208 of 209 Old November 5th, 2010, 06:47 PM
De Oppresso Liber
LouDiamond's Avatar
First Name: Scott
My RZR: 09 RZR
Member #3259
Since you have the Holz Stage 3 kit, you have a PRV valve and the pressure gauge that came with the kit. After the install of the oil filter relocation kit did you check the pressure? If so, what change if any did you notice?
PIT BULL TIRES
post #209 of 209 Old February 7th, 2011, 11:39 AM
Mr T's Avatar
Member #22427
View Mr T's Photo Gallery(0)
I`m interested in knowing this too.
Did you ever check pressure / compare ?
Mr T is offline
oil filters/aux. gas can rzr187 General RZR Discussion 15 February 3rd, 2013 02:39 PM
Air filters xD :P Santa rzr General RZR Discussion 1 June 9th, 2009 07:19 AM
Oil filters for 08 rzr DEERHUNTERBOB Engine and Drivetrain 15 February 9th, 2009 12:49 PM
Tell me what you guys think about my RZR S. jimmyelza General RZR Discussion 7 December 13th, 2008 02:05 PM
Hey guys getfit74 Member Introductions 1 May 10th, 2008 05:10 AM
