RZR compatible oil filters - Page 7 - Polaris RZR Forum - RZR Forums.net
post #91 of 105 Old June 2nd, 2015, 12:03 AM
jimmypsp700's Avatar
First Name: Jim
My RZR: 2014 RZR 900 XP
Member #71205
View jimmypsp700's Photo Gallery(5)
Re: RZR compatible oil filters
Originally Posted by Summers424 View Post
Why is nobody recommending the Fleetguard # LF3644, Fleetguard , aka Cummins Filtration.....do I work for Cummins? Yes I do, however if you research filter companies, Fleetguard is the only one with a 100% warranty.. Not the prorated warranty... I will be happy to answer any questions anyone has either on here or my email..... [email protected]
Where do you typically buy them TSC?
2014 RZR 900 XP
2015 Sportsman 1000 XP
2000 Scrambler 400 2x4 RcR Ported
2016 Polaris Switchback Adventure 600
Triton Elite 79-14
Triton SL8
jimmypsp700 is offline
post #92 of 105 Old June 14th, 2015, 03:34 PM
maxitout77's Avatar
My RZR: 15 900 S
Member #78369
View maxitout77's Photo Gallery(0)
Is this filter list compatible with the 2015 900 motor?
maxitout77 is offline
post #93 of 105 Old June 24th, 2015, 02:33 PM
8thNotch's Avatar
Member #82368
View 8thNotch's Photo Gallery(0)
Subscribe
Let it rip!
8thNotch is offline
post #94 of 105 Old July 2nd, 2015, 11:55 PM
steamy_load's Avatar
Member #33850
View steamy_load's Photo Gallery(0)
First DIY service here today on Desert Tan Edition 800:
Oil Change:
WIX filter
Rotella 5w-40
FrontDiff/TransferCase/Transmission:
OReily Brand hydraulic fluid(JD20 C/D)
RearDiff:
Synthetic 75-90
All is well so far....
steamy_load is offline
post #95 of 105 Old August 29th, 2015, 09:32 AM
colten's Avatar
Member #84216
View colten's Photo Gallery(0)
just got 2015 trail ready to change oil been using valovine atv oil in other bikes found fram oil filter #ph6017a extra guard is this ok to use for 900 trail
colten is offline
post #96 of 105 Old August 29th, 2015, 01:25 PM
First Name: Jim
Member #71205
I would not use a standard fram oil filter as they were very low rated in multiple tests that you can find online.
best brands being wix and pure one along with Mobile 1 and k&n also being highly rated with synthetic filter material. Surprisingly the Supertech Walmart was rated good also but do not believe they make them anymore
2014 RZR 900 XP
Triton Elite 79-14
Triton SL8
post #97 of 105 Old August 29th, 2015, 01:54 PM
colten's Avatar
Member #84216
Usa Re: RZR compatible oil filters
thanks for the info, would the Valvoline atv oil be ok to run in a 900 engine
colten is offline
post #98 of 105 Old September 21st, 2015, 09:40 AM
colten's Avatar
Member #84216
10 w 40 valvoline atv oil can i run in a 900 engine?
colten is offline
post #99 of 105 Old September 21st, 2015, 06:27 PM
First Name: Jim
Member #71205
I wouldn't.
0-40, 5-40 or 5-50 full synthetic recommended.
10-50 HD for high heat climates.
2014 RZR 900 XP
Triton Elite 79-14
Triton SL8
post #100 of 105 Old February 6th, 2016, 02:28 PM
Chief_6.7's Avatar
Member #94089
View Chief_6.7's Photo Gallery(0)
Are these filters compatible with 2015 rzr xp1k? Also how often are you changing the oil miles of months????
Chief_6.7 is offline
post #101 of 105 Old February 6th, 2016, 02:54 PM
Desert900's Avatar
My RZR: 2016 900 EPS Trail
Member #80933
View Desert900's Photo Gallery(0)
NV Re: RZR compatible oil filters
As I recall, the book says every 100 hours. I'm changing oil at 50 hours using the counting hour meter on the speedo.
Retired Chemtrail Vendor
2016 RZR 900 EPS Trail Camo (see garage)
2002 Grizzly 660 Camo, Bighorn 2's, winch
2006 Kodiak 450 Camo, RZR PXT takeoffs, winch (wife's)
Voiding warranties since 1958
Desert900 is offline
post #102 of 105 Old March 27th, 2016, 03:48 PM
Chief_6.7's Avatar
Member #94089
Changing my oil soon and I just need confirmation from someone. For those using full synthetic 0w-40 is this just regular motor oil like mobile 1 motor oil or is it special specifically for Atv/utv motor oil? And is 0w-40 ok to use?
post #103 of 105 Old March 27th, 2016, 05:33 PM
Desert900's Avatar
Member #80933
The book cautions not to use automotive oil, but a powersports oil instead which has additives that are better for your engine. There are a lot of oil threads in this forum that have discussed (and cussed) different oils. Do a search.
As far as weight goes, I would use a weight recommended in your owner's manual, and probably anything in the 5w50, 10W40 or 10w50 range should be acceptable.
post #104 of 105 Old July 1st, 2018, 03:40 AM
Mike Colville's Avatar
Member #236130
View Mike Colville's Photo Gallery(0)
Polaris is listed at 10 microns....Wix is 20 microns....thoughts?
2010 Ranger Crew
2017 RZR 570
2018 RZR Turbo S
Mike Colville is offline
post #105 of 105 Old March 7th, 2019, 07:53 AM
wingryder's Avatar
Member #237129
View wingryder's Photo Gallery(0)
Brian
You left out one complete "box" Do you not service the Transfer Case?
wingryder is offline
K&N air filters Mountain RZR General RZR Discussion 19 April 24th, 2011 05:22 PM
Just to verify Is the 2011 head light assembly compatible with 2010? dmax61 General RZR Discussion 1 January 25th, 2011 01:40 PM
Any extended/long travel kits compatible with WER? BlueSVT Suspension 7 December 3rd, 2010 05:07 PM
Is a Gibson Exhaust Compatible w/ RacerTech Lift Kit? bilinvic Engine and Drivetrain 17 July 14th, 2010 10:43 PM
Oil filters for 08 rzr DEERHUNTERBOB Engine and Drivetrain 15 February 9th, 2009 12:49 PM
