4wd not working? - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old February 15th, 2012, 09:18 PM Thread Starter
limetime's Avatar
Member #36145
View limetime's Photo Gallery(0)
4wd not working?
my 4wd light comes on the guage when i turn on the switch but it doesnt engage. if i do a donut itll lock in and stay locked in until i put it in reverse. theres 12 volts going to it. i tore it down to find nothing broke so i put it back together. what could possibly be going on? any help would be appreciated
limetime is offline
post #2 of 3 Old February 15th, 2012, 09:23 PM
RZRTOURS's Avatar
First Name: TROY
My RZR: RZRS RZR4 RZR
Member #25042
View RZRTOURS's Photo Gallery(0)
Re: 4wd not working?
In the wiring harness straight below the storage tray in the front, under the hood, there is a "y" . It is wrapped with the flexible plastic. It tends to cut the wire to the front diff. We have had to repair several of these. Its a good place to look . It will just cut the wire enough for you to lose power once in a while, so you will still read power most of the time. Just my experience. Good luck.
RZRTOURS is offline
post #3 of 3 Old February 15th, 2012, 09:42 PM Thread Starter
limetime's Avatar
Member #36145
so i should wiggle the wires while testing them to see if theres a short? because its definitely getting power everytime i check it
limetime is offline
Working the RZR RZRick General RZR Discussion 10 December 4th, 2010 05:56 PM
Rzr S 4x4 not working jmb59801 Community Help 0 November 27th, 2010 11:25 AM
AWD working or not zert800 Engine and Drivetrain 17 September 28th, 2010 06:28 PM
AWD not working jsw_1986 Engine and Drivetrain 16 September 9th, 2010 05:28 PM
4wd not working RAZOR FREAK Engine and Drivetrain 30 July 11th, 2010 04:46 PM
