CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 149 Old December 11th, 2008, 07:32 AM
Buzzsaw46's Avatar
First Name: Jason
My RZR: '08 Green
Member #3511
View Buzzsaw46's Photo Gallery(0)
Re: CHECK YOUR THROTTLE PLAY !!!! MAY be only gettin 3/4 throttle
Very good tip I thought my top end was feeling a bit flat. 32h and 504miles on it and it was never adjusted. Oh well I found my missing ponies.
Thanks for the heads up Junky!
Buzzsaw46 is offline
post #17 of 149 Old December 11th, 2008, 08:03 AM
WFO
Freedom ain't free
WFO's Avatar
First Name: Greg
My RZR: S'sssss
Member #4968
View WFO's Photo Gallery(4)
The cables are fine on both my S'. I wonder if this is another miss by polaris exclusively for the rzr that should have been caught at QC? Regardless, if 7 out of 10 are like this it should be in a TSB to be adjusted in the PDI. It baffles me how something as simple yet significant enough to rob performance can be allowed to be delivered?
07 GMC SLE Z71
09 rzr-S
ssg, 1stSFG- LIVE FREE OR DIE
WFO is offline
post #18 of 149 Old December 11th, 2008, 08:46 AM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
I saw on another thread that someone thought that even if you adjust the cable as far as you can you still only get 80-90% full throttle.
They thought that the throttle pedal had to be modified with more throw to be able to open the throttle 100%.
Might be worth looking into.
READ THIS
Tuf-Skin is offline
post #19 of 149 Old December 11th, 2008, 01:35 PM
Buzzsaw46's Avatar
First Name: Jason
My RZR: '08 Green
Member #3511
It's not uncommon for a cable to strech, I'm sure that is the case for me. I dont believe it was something missed by the assembly team, just rutine maint. that I had missed.
post #20 of 149 Old December 11th, 2008, 03:39 PM
Stumpduster's Avatar
First Name: Mike #688
My RZR: 16 1000 XP
Member #1676
If that link stays up it really should be a STICKY..........it would answer a lot of questions for peolpe if they took the time to use it!
Stumpduster is offline
post #21 of 149 Old January 11th, 2009, 06:49 AM
keith88jrfan's Avatar
First Name: Keith
My RZR: 2011 RZR XP
Member #5873
View keith88jrfan's Photo Gallery(0)
Any good pictures of where the adjustor is?
keith88jrfan is offline
post #22 of 149 Old January 11th, 2009, 06:57 AM
renegade44's Avatar
My RZR: 09 RZR LE NUCLEAR ORANGE
Member #5850
View renegade44's Photo Gallery(0)
Link won't connect. Details on adjustment please.
renegade44 is offline
post #23 of 149 Old January 11th, 2009, 08:45 AM
First Name: Keith
My RZR: 2011 RZR XP
Member #5873
I still need a good picture of the adjustor and location!
post #24 of 149 Old January 11th, 2009, 07:26 PM
My RZR: 16 1000 XP
Member #1676
I assume the link to the Rzr Service Manual finally got zapped!
post #25 of 149 Old January 15th, 2009, 08:21 AM
S.O.B son of boss
cheek's Avatar
First Name: Josh
My RZR: Busa RZR
Member #1165
View cheek's Photo Gallery(0)
ok mine only has like 60 miles on it and i had to adjust the screw a 1/4 out. now full throttle only had mabye 3/4 throttle.
cheek is offline
post #26 of 149 Old January 15th, 2009, 09:00 AM
DocJohsnon's Avatar
First Name: Glenn
My RZR: 2009 RZR
Member #3873
View DocJohsnon's Photo Gallery(0)
Posts like this are the reason I love this forum. THANX!
DocJohsnon is offline
post #27 of 149 Old February 16th, 2009, 11:48 AM Thread Starter
LV RzR Rider's Mechanic
LvDirtJunky's Avatar
First Name: Chase
My RZR: 2009
Member #4118
View LvDirtJunky's Photo Gallery(6) Send a message via AIM to LvDirtJunky Send a message via Yahoo to LvDirtJunky
2009 poolaris RZR Bikeman pipe , ump , powercammander , Throttle play adjusted , lonestar grill's .she rips
www.utvcrap.com , These guy's ROCK
I.U.O.E. Local 12 . Work Union Live Better
LvDirtJunky is offline
post #28 of 149 Old February 18th, 2009, 09:09 AM
kade's Avatar
First Name: Kade
My RZR: RZR-S
Member #6319
View kade's Photo Gallery(0)
My new S was only getting 75% throttle. My top rpm I could ever get was 5850-5900.
The bolt that holds the throttle cable to the peddle has a black plastic washer peice that the cable rolls over. I took this off, and then cut a 1 inch peice of 1/2 pvc pipe and put the black washer into the pvc then put it back on. "I had to drill the pvc hole a bit bigger, to get it to fit". This adjusts the lenght that the peddle pulls the throttle cable. I then checked and my TB was WOT. This was very easy, only one bolt and fixed my rzr. Could work for some of you as well.
kade is offline
post #29 of 149 Old April 7th, 2009, 07:27 PM
MUD FLAP 1's Avatar
Member #4093
View MUD FLAP 1's Photo Gallery(0)
can someone tell us how to adjust the link want connect thanks
MUD FLAP 1 is offline
post #30 of 149 Old April 10th, 2009, 10:43 PM
MotoXXX's Avatar
First Name: Jeff
Member #4542
Feedback Score: 26 reviews
Here ya go...straight from the service manual.....
Inspection
1. Place the transmission in the P (Park) position
2. Start the engine, and warm it up thoroughly.
3. Measure the distance the throttle pedal moves before the engine begins to pickup speed. Free play should be 1/16" - 1/8" (1.5-3 mm).
Adjustment
1. Remove the seats and rear service panel.
2. Locate the throttle cable adjuster just above the PVT (drive belt) cover.
3. Squeeze the end of the rubber boot and slide it far enough to expose the end of the inline cable adjuster.
4. Loosen the adjuster lock nut.
5. Rotate the boot to turn the adjuster until 1/16" to 1/8" (1.5 to 3 mm) of freeplay is achieved at the throttle pedal.
NOTE: While adjusting, lightly flip the throttle pedal up and down.
6. Tighten the lock nut.
7. Squeeze the end of the rubber boot and slide it over the cable adjuster to it's original position.
MotoXXX is offline
Throttle Body noodles Engine and Drivetrain 3 November 17th, 2008 07:40 PM
Throttle Too Sensitive drcdac General RZR Discussion 9 October 8th, 2008 04:51 PM
Oil In Throttle Body??? r6realtor General RZR Discussion 10 September 9th, 2008 10:35 AM
Throttle free play BlackRaptor General RZR Discussion 1 July 30th, 2008 11:07 AM
Throttle Bodies Pgreg Engine and Drivetrain 14 March 17th, 2008 05:54 PM
