oil pressure adapter - Polaris RZR Forum - RZR Forums.net
post #1 of 10 Old June 23rd, 2019, 04:20 PM Thread Starter
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
After much research, I have determined that Polaris oil pressure adapter Pu-50565 is made out of unobtainium. I am not sure how many Polaris engines this may have been used for. The plug for the port on my (or most all) 900XP is 12mm-1.5. Am wondering if anyone has used an Autometer 2277 adapter or a Mamba K027-0172 adapter. Might be used to add an oil pressure gauge or warning light as well as testing oil pressure. Not sure if the gasket will seal to the block. A warning light can be installed for about half the price of a reflex kit.
I have also noticed that there is very little interest in adding an O/P gauge or light on RZRs. Even when there is no factory oil warning system at all.
ntrsandman is offline
post #2 of 10 Old June 23rd, 2019, 06:46 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: oil pressure adapter
Are you just wanting to add an OP gauge? I had an Alba Racing OP gauge on my xp 900...
Not sure about any other setup tho
2018 XPT4 - Bailey
RWB713 is online now
post #3 of 10 Old June 23rd, 2019, 07:38 PM Thread Starter
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
How was the gauge connected to the engine?
post #4 of 10 Old June 24th, 2019, 04:54 AM
RWB713's Avatar
First Name: Richard
Member #70552
They include a sender that uses the port you mention
https://teamalbaracing.com/i-2390021...psi-gauge.html
2018 XPT4 - Bailey
post #5 of 10 Old June 24th, 2019, 06:36 AM Thread Starter
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Too bad Alba or Reflex do not show a picture of the adapter or sender. That is the question. Will the adapters I listed work in place of the Pu-50565?
post #6 of 10 Old June 24th, 2019, 06:39 AM
RWB713's Avatar
First Name: Richard
Member #70552
I'm not sure which specifically they use, but the use an adapter with their sender, so i'm sure it something similar. You mention a gasket above... but there is no gasket, just thread sealant on the fittings is all you use.
2018 XPT4 - Bailey
post #7 of 10 Old June 24th, 2019, 07:01 AM Thread Starter
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
The gasket/seal on the adapters mentioned are similar to those used on the engine, trans, and diff plugs. Not sure if the case has a flat surface for the washer to seal against. Or if sealant can be used. I suppose if someone needed an adapter to test oil pressure, they're out of luck.
post #8 of 10 Old June 24th, 2019, 07:08 AM
RWB713's Avatar
First Name: Richard
Member #70552
You wouldn't even need that seal, thread sealant is plenty sufficient. I never had an oil leak problem from the sensor at all on my 900 using only thread sealant
2018 XPT4 - Bailey
post #9 of 10 Old June 24th, 2019, 09:56 AM Thread Starter
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Good to know. They will likely work fine in testing. Again, based on the obvious lack of need for oil pressure devices on RZR engines, I will back burner the idea.
post #10 of 10 Old July 14th, 2019, 03:42 AM
DaveD's Avatar
My RZR: XP1000
Member #93754
View DaveD's Photo Gallery(0)
True! but also as a shop or personal I rather get the tested and qualified solution rather than buying parts, do the wiring, soldering etc. Bought couple of the oil check system from Reflex, nice product and working well. My customers are happy. Never tested the Alba ones.
DaveD is offline
