New Axles Clicking - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 1 Post By RZR_Joe
  • 1 Post By mikedeezxxx
  • 1 Post By rbakeman
post #1 of 9 Old June 3rd, 2019, 05:50 PM Thread Starter
whitetailchaser's Avatar
Member #198793
View whitetailchaser's Photo Gallery(0)
New Axles Clicking
My old OEM axles have 2700 miles on them and one of the rear axles started to go bad at the CV joint. I decided to go ahead and replace both rear axles yesterday. They are Max Motorsports axles and are a much stronger and heavier axle compared to the OEM. They appear to be very comparable to Rhino 2 axles. Everything went together perfectly and I used two spacers behind the castle nut like the OEM had. When I test drove the RZR afterwards it was driving perfectly while going straight or normal turns but when I made very sharp turns it makes a clicking noise. It sounds louder on the left side compared to the right side. I can see the tires digging and releasing into the grass like it may be binding on very sharp turns but I'm not certain. I've read on the site about the usual issues with old axles or brake pad chatter but these are brand new axles. Does anyone have any ideas of things to check or look at which could be causing this clicking noise?
2013 RZR S 800
Fox shocks
Wild Boar front bumper
Tusk power steering
whitetailchaser is offline
post #2 of 9 Old June 10th, 2019, 08:06 AM
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
Re: New Axles Clicking
Do you have any lift kit on your machine? It seems like the axle is over extended and causes CV joints to bind slightly.
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #3 of 9 Old June 10th, 2019, 08:59 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I have RCV rear axles and they have always done that. RCV says it is normal but it is annoying .
Max H is online now
post #4 of 9 Old June 10th, 2019, 09:41 AM Thread Starter
Member #198793
I don't have a lift kit on it. Just the normal factory settings. It's probably fine but I just don't want to ruin my differential or something else.
2013 RZR S 800
Fox shocks
Tusk power steering
post #5 of 9 Old June 10th, 2019, 09:50 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
If a CV "clicks" when it's angled there is a problem. This is a result of the inner cage hitting the hub and it's not normal. Usually it only occurs at severe CV angles or when the CV is worn badly.
It won't ruin the diff but it will definitely shorten the life of the CV.
mikedeezxxx likes this.
RZR_Joe is offline
post #6 of 9 Old June 10th, 2019, 11:32 AM Thread Starter
Member #198793
There is no lift kit on my RZR so the CV joints are at a normal angle. When I drive around in a sharp turn I hear the clicking sound. It sounds like the clicking or popping noise is out near the wheel. It's louder on the left side but maybe that's because I'm sitting on the left and closer to that wheel compared to the right side. I'm going to try to tear the hub off later this week and look it over again.
2013 RZR S 800
Fox shocks
Tusk power steering
post #7 of 9 Old June 10th, 2019, 01:07 PM
mikedeezxxx's Avatar
Member #263370
View mikedeezxxx's Photo Gallery(0)
From my experience with front wheel drive vehicles using cv axles, that clicking noise when steering left or right means you have a bad axle.
whitetailchaser likes this.
mikedeezxxx is offline
post #8 of 9 Old June 10th, 2019, 05:49 PM
rbakeman's Avatar
First Name: Rod
My RZR: 2018 XP Turbo
Member #36522
View rbakeman's Photo Gallery(0)
Happened to a friends XP1000, was the drive shaft carrier bearing. Give it a look.
rbakeman is offline
post #9 of 9 Old June 17th, 2019, 09:23 AM
Dirtclod1's Avatar
First Name: Jeff
My RZR: 18 Turbo S
Member #258048
View Dirtclod1's Photo Gallery(0)
What have you got your castle nuts torqued to?
Dirtclod1 is offline
