Dropped clutch - Polaris RZR Forum - RZR Forums.net
 2Likes
post #1 of 16 Old February 28th, 2018, 04:14 PM Thread Starter
vtprairie's Avatar
Member #70416
View vtprairie's Photo Gallery(0)
Dropped clutch
So before I start for the life of me I don't know how I dropped the primary off my 2017 1000s. I am so pissed at myself. I installed a Heel Clicker clutch kit in my 1000s swapped out the weights and spring and turned to grab a rag accidentally hit the primary and it landed on the floor. It left a smush on the cover were the bolt head is and so I took a screwdriver to wiggle in between the bolt and the "smush". I couldn't get the socket on the head to tighten it up. All of a sudden POP the "smush" part actually broke off. I almost crapped myself. So the million dollar question is? Will this affect the clutch or should I get a new top or do I have to get a whole new clutch. Thanks everyone
Bill
2016 RZR 900 Trail EPS
2017 RZR 1000S
vtprairie is offline
post #2 of 16 Old February 28th, 2018, 04:29 PM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Dropped clutch
To my knowledge the primary clutches are a balanced assembly, that is why Polaris only sells the complete assembly. So you cant buy just the top from Polaris. So the bad news is you are more than likely looking at buying a whole primary clutch.
Clothier is offline
post #3 of 16 Old February 28th, 2018, 04:31 PM Thread Starter
vtprairie's Avatar
Member #70416
Re: Dropped clutch
That would really suck if I had to but it is my own fault.
2017 RZR 1000S
post #4 of 16 Old February 28th, 2018, 05:20 PM
srt20's Avatar
My RZR: 2015 RZR 4 900 Red
Member #23480
View srt20's Photo Gallery(0)
Re: Dropped clutch
I'd run it without any hesitation.
Very small piece, try and weigh it. It will amount to virtually nothing.
If its that big of a deal, I know a few different people that balance clutches. I dont recall how much it is to balance, but I do know its much much less than a new clutch.
Some sled guys balance their clutches just because. Its not like they are balanced perfectly from Polaris.
dartersracing and todztoyz like this.
2015 900 4 SSV Works door pods and glovebox sub, UTV headquarters roof, 30" curved led bar, Mudbusters flares Maxxis Liberty 29x9.5x15 tires, KMC Machete 15" wheels 5x2
Sold
2011 Boardwalk Blue and White LE 26" Bighorns on 14" SIXr wheels, 1.5" spacers, 58" wide, Racertech lift, front and rear bumpers,tunes by SSV Works, LTR 450 shocks
srt20 is offline
post #5 of 16 Old February 28th, 2018, 05:21 PM
srt20's Avatar
Member #23480
Re: Dropped clutch
BTW, what state you in?
Sold
srt20 is offline
post #6 of 16 Old March 1st, 2018, 01:14 AM Thread Starter
vtprairie's Avatar
Member #70416
Re: Dropped clutch
I'm in Vermont
post #7 of 16 Old March 1st, 2018, 03:53 AM Thread Starter
vtprairie's Avatar
Member #70416
Re: Dropped clutch
That is true I didn't think of that. Thanks for the info
2017 RZR 1000S
post #8 of 16 Old March 1st, 2018, 05:46 AM
Ridin' above 10,000 ft!
J to the B's Avatar
First Name: Jim
My RZR: 2015 XP1K Blue Dragon
Member #6112
View J to the B's Photo Gallery(21)
Re: Dropped clutch
Definitely run with it. Wear the thing out and then address it.
J to the B is offline
post #9 of 16 Old March 1st, 2018, 05:54 AM
RickRou56's Avatar
My RZR: 2017 XPT Velocity Blue
Member #28887
View RickRou56's Photo Gallery(0)
Re: Dropped clutch
You can buy parts. I always believed you couldn’t.
My dealer showed me his exploded parts sheet of a XP 1000 clutch and most of it was there.
They rebuilt my primary with bearing, buttons and a few misc parts they recommended. My clutch was howling at slow speed under load. This fixed it.
$160. I took them the clutch. Everything worked out great.
Perhaps you’d want to have it balanced afterwards in this case.
Check with a reputable dealer about individual parts for it.
The online guys were not showing the parts that the dealer was able to provide for this repair.
RickRou56 is offline
post #10 of 16 Old March 1st, 2018, 06:51 AM
Backfire1's Avatar
My RZR: XP1K
Member #202297
View Backfire1's Photo Gallery(0)
Re: Dropped clutch
Sounds like you are having a bad day. That is the kind of luck I have. Hope it all works out.
Backfire1 is offline
post #11 of 16 Old March 1st, 2018, 06:55 AM
Bullitt427's Avatar
Member #133409
Re: Dropped clutch
Run it, nothing to worry about.
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #12 of 16 Old March 1st, 2018, 07:19 AM Thread Starter
vtprairie's Avatar
Member #70416
Re: Dropped clutch
Thanks guys. Thing only has about 300 miles on it.
2017 RZR 1000S
post #13 of 16 Old March 1st, 2018, 07:27 AM
Jim
Moab.Jim's Avatar
First Name: Jim
My RZR: 2017 XP 1000
Member #230657
View Moab.Jim's Photo Gallery(0)
Re: Dropped clutch
I would run with it. I would probably weigh the part that broke off then get a thin washer that weighs very close to the same and put the washer under the bolt with blue locktite
Moab.Jim is offline
post #14 of 16 Old March 1st, 2018, 07:58 AM
Clothier's Avatar
First Name: Brian
Member #65577
Re: Dropped clutch
Or just take a die grinder and notch all 5 other corners to match the broke 1.
Clothier is offline
post #15 of 16 Old March 1st, 2018, 08:00 AM Thread Starter
vtprairie's Avatar
Member #70416
Re: Dropped clutch
Both ideas sound good thank you
2017 RZR 1000S
200 mile belt life 2016 XPT - what to expect / what can I do about it? SandyEggo RZR XP Turbo 56 February 3rd, 2018 12:43 PM
WARNING on clutch holding tools!!! Hunterworks Hunterworks 14 November 12th, 2016 05:00 AM
Clutch puller sheared off in clutch. WylieCoyote Engine and Drivetrain 14 September 12th, 2016 04:28 AM
