Trans Issue! Shift Indicator stuck in "R" no "High" Gear Blowing fluid out the vent - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old December 23rd, 2017, 09:09 AM Thread Starter
Jmron's Avatar
First Name: Jason
My RZR: 2008 800
Member #230945
View Jmron's Photo Gallery(0)
Usa Trans Issue! Shift Indicator stuck in "R" no "High" Gear Blowing fluid out the vent
New to the forum. Any help would GREATLY be appreciated! I have a 2008 RZR 800. During last deer season my rzr started to become hard to shift. I coulndt get High gear unless I really pulled the shifter almost past the gear position. It operated like this for a while then the gear indicator on the gauge stuck on "R" no matter where you shifted. The whole shift pattern seemed to move back. Park is where Neutral normally is, so within normal shifter travel... Park Neutral and Low are the only gears i can get. There is no detent between them. The cable moves freely, I had hoped it had stretched or something... The shift lever moves freely with the cable removed. I had just replaced all the fluids. It seems like I may have over filled the trans, it was overflowing out the vent on the muffler at high speeds. The fluid looks good, no steel... Does anyone have experience with this can of worms?? Thank in advance!
Jmron is offline
post #2 of 9 Old December 23rd, 2017, 10:41 AM
XR4Honda's Avatar
My RZR: 2008 RZR, Rear Bench for my 2 boys
Member #13135
View XR4Honda's Photo Gallery(0)
Re: Trans Issue! Shift Indicator stuck in "R" no "High" Gear Blowing fluid out the vent
Does it grind gears a little when you try and shift? If so that is the one way bearing in your primary clutch.
XR4Honda is offline
post #3 of 9 Old December 23rd, 2017, 11:09 AM
sea157's Avatar
First Name: Steve
My RZR: 2011 RZR 800S
Member #216377
View sea157's Photo Gallery(0)
Is the shift cable in good condition and adjusted correct?
sea157 is offline
post #4 of 9 Old December 23rd, 2017, 11:55 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Originally Posted by Jmron View Post
1) I had just replaced all the fluids
2) The shift lever moves freely with the cable removed.
1) Did you overfill the transfer case? See below photo.
2) With cable disconnected, can you feel detents when you move the transmission lever?
....Can you get it into park and high?
2014 800 LE w/EPS 50”
PRO ARMOR trail doors, RYFAB rear windshield, MotoAlliance Fire Storm cab heater, RYFAB cargo rack, WARN PV4500S wide spool winch, POLARIS front windshield and top, 2008 tail lamp assemblies with backup lights, RACERTECH 2” lift, Duraclutch, R2C Air Filter, Garage Products A-arm bushings.
CA 800 is online now
post #5 of 9 Old December 23rd, 2017, 12:06 PM Thread Starter
Jmron's Avatar
First Name: Jason
My RZR: 2008 800
Member #230945
It does grind a little when shifting if the rpms are high when I shift. I re-shimmed the pulley last fall when I replaced the belt and it seemed to help.
I ordered a new cable and when I took the old one off it seemed to operate fine. That wouldn't explain why the gear indicator on the gauge is stuck on "R"....
I can feel the detents and it will go into all gears when shifted by hand without the cable attached.
I do think I overfilled the transfer case...
Thanks for the input guys!
Jmron is offline
post #6 of 9 Old December 23rd, 2017, 12:43 PM Thread Starter
Jmron's Avatar
First Name: Jason
My RZR: 2008 800
Member #230945
Man.... I filled it to the fill plug! What have I done?? I drained it down to the level check plug...
Jmron is offline
post #7 of 9 Old December 24th, 2017, 06:32 AM Thread Starter
Jmron's Avatar
First Name: Jason
My RZR: 2008 800
Member #230945
I drained the transfer case to the level plug and replaced the shift cable. Manually I can find each gear, but after starting the machine the same situation exists, no park or High and is grinds relentlessly between gears and it feels like there are no detents. Do you think the one way in the clutch failed? That could explain the grinding but what about the gears, where are part and high? Could overfilling the transfer case have pushed fluid into the gear indicator causing it to malfunction?
Jmron is offline
post #8 of 9 Old December 24th, 2017, 09:27 AM
XR4Honda's Avatar
Member #13135
You can pull the primary clutch off and feel the one way bearing by hand. I replaced the one way bearing on my old 800. No clue on the park and high gear.
Another thought is to call Todd at Hunterworks next week. He knows his stuff.
XR4Honda is offline
post #9 of 9 Old December 24th, 2017, 09:53 AM
RZRTito's Avatar
My RZR: 2016 XP1000...one upgrade at a time!
Member #138385
View RZRTito's Photo Gallery(0)
I think you need to adjust the shift cable. Mine did the same thing on a WVA trip right after I put the EMP shifter in. Rode Saturday struggling to get to high gear. Adjusted Sunday morning and all is well.
2016 RZR XP 1000: SuperATV Rock Sliders, Polaris roof, Tusk Cab Pack, PRP 4.2 harnesses, 4000lb Superwinch, Super ATV Rev1 tuner, SuperATV cooler/cargo box, Rough Country 30" curved light bar, Hunterworks round rollers
RZRTito is offline
Deeper Explanation of Shift RPM Hunterworks Hunterworks 18 June 13th, 2017 06:55 AM
Gear oil for trans fluid? Research inconclusive TC CAD RZR 1000 Engine 4 September 25th, 2016 11:17 AM
