hot clutches - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By roguedriver
post #1 of 5 Old October 23rd, 2017, 05:44 PM Thread Starter
declanmason11270725's Avatar
Member #210825
View declanmason11270725's Photo Gallery(0)
hot clutches
Hello,
I have a 2014 900 xp 4 rzr. I just put a new belt on and was doing a break in period where i would drive for about 1/2 hr-1hr without punching it and drive easy. After about an hour I took it home and decided to pull the clutch cover off cause something didn't seem right. I was getting that belt burning smell the odd time through my ride. And a couple of times towards the end of the ride I gave a cpl punches and it seemed like the belt was spinning a bit. The clutch cover was extremely hot and the clutches were super hot. I spit on them and it made that sizzle sound from being so damn hot. The clutches were hotter than the muffler. I spit on it too and there wasn't any sizzle sound. I am thinking that was the reason i only got less than a 100 kms on last belt. Why would the clutches be getting so hot?? I think they are melting the belts and causing them to explode into 100 pieces. I checked the oil level and its all good. There is a 6" lift and large tires on it but I didn't notice the clutches getting so hot before. Please Help before I blow another belt.
declanmason11270725 is offline
post #2 of 5 Old October 24th, 2017, 04:50 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Re: hot clutches
Could be several things, just a couple to think on
Rollers in secondary clutch flat spotted
Spider nut and spider backing off in primary clutch
One of them is not working as it should
Todd
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #3 of 5 Old October 24th, 2017, 05:27 AM
Clubin's Avatar
First Name: Clayton
My RZR: XPT
Member #61303
Re: hot clutches
Could be belt guts jammed up in the primary and secondary?
2016 XPT
EVO stage 2
EVO captains choice exhaust
EVO charge tube
OSP clutch kit
Rockford Fosgate Stage 4
STI HD5's 31/10.50/15 Super Swamper IROC'S
Clubin is offline
post #4 of 5 Old October 24th, 2017, 05:49 AM
Smooth Moderator
roguedriver's Avatar
First Name: Ken
My RZR: 2011 1102cc 900XP
Member #24045
View roguedriver's Photo Gallery(0)
Re: hot clutches
Have you cleaned out the clutch cover vent ducting? If you've blown belts, the material will fly out that vent duct and sometimes it gets stuck in there. If that's the case, the housing has no way to vent and it can get pretty toasty in there as you've found out. If its clear and its getting that hot, then its because the belt is slipping a lot most likely because the clutch isn't working correctly for a lot of the reasons Todd stated above.
Hunterworks likes this.
Ken R.
roguedriver is offline
post #5 of 5 Old October 25th, 2017, 05:48 AM Thread Starter
Member #210825
Re: hot clutches
can the secondary clutch bolt be on too tight? Would that cause the clutch to not work properly?? I pulled both clutches off the last belt change to clean them. I torqued down the primary to spec cause you can get a hammer in there and its easily torqued. Does the secondary have to be torqued to certain spec? If so what is it and how do you hold the clutch still to get it torqued. I just used an air ratchet and cranked it on. The same way I got it off.
200 mile belt life 2016 XPT - what to expect / what can I do about it? SandyEggo RZR XP Turbo 56 February 3rd, 2018 12:43 PM
The 8th Annual RZR forum ride at the Glamis North Hot Springs March 16th to the 19 th FJK Glamis North Hot Springs Resort Ride 129 November 17th, 2017 06:51 PM
Under the hood battery connections and hot wire with ignition bogger Lighting, Stereo and Electrical 0 October 11th, 2017 09:38 AM
Clutches, looking for some opinions Dharrisauto86 RZR XP 900 0 October 25th, 2016 07:54 PM
