Bevel Gear Info Thread - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old August 13th, 2017, 09:06 AM Thread Starter
Jimdawg185's Avatar
Member #123937
View Jimdawg185's Photo Gallery(0)
So I spent hours gathering info on this part night because mine failed and instead of throwing in a trans I'm going to build the 14 trans (Xp 1000 2 seater).
There's a lot of misleading info. So for everyone's sake, I thought I'd start this thread and let everyone contribute here instead of all over. I'd love links placed here for the assistance of those who have failures.
I'll contribute what I learn as well.
Jimdawg185 is offline
post #2 of 6 Old August 15th, 2017, 06:41 PM Thread Starter
Jimdawg185's Avatar
Member #123937
Re: Bevel Gear Info Thread
So my issues started with a binding that sounded like the front diff was bad. I changed the diff, and while testing the trans locked up and almost sent me ass over potatoes. So I looked and tested and I eventually got down to chaining the trans oil and a bolt head cane out with it. So that was my smoking gun.
I pulled the trans and this is what I found.
It appears that either the gear broke, and bound up and pushed the pinion out, or the plate bolts bent and broke allowing the pinion to pull back and then snap the gears.
post #3 of 6 Old August 15th, 2017, 07:02 PM Thread Starter
Jimdawg185's Avatar
Member #123937
These are some of the options I've found
https://www.extremesnorkels.com/prod...grade-kit.html
The RCV looks great, but I don't see a gear with the shaft.
http://www.rcvperformance.com/produc...aspx?sku=D7780
post #4 of 6 Old August 16th, 2017, 12:49 PM
TFR Engineering's Avatar
Member #141865
View TFR Engineering's Photo Gallery(0)
Gilbert Designs 300M Output Shaft kit - Gilbert Designs
Several options here, and they support a lot of hill climbing and other racing vehicles.
TFR Engineering is offline
post #5 of 6 Old August 16th, 2017, 02:36 PM
OPTIMUMderic's Avatar
Member #196473
View OPTIMUMderic's Photo Gallery(0)
We've spent a lot of time going through the stock Transmission while researching our shifter box and here's what we know about the front drive bevels. The stock spiral bevel gear set is actually quite well designed. Tooth profile and contact area are both good. Hardness is not ideal.. The real problem is that the bevel gears are coming out of mesh under constant load with the pinion shaft bearing retainer being the weak link. Polaris actually redesigned it in the Turbo tranny with 6 bolts instead of 4. A heavy duty retainer should solve this specific problem but will likely lead to others.
OPTIMUMderic is offline
post #6 of 6 Old August 16th, 2017, 02:48 PM Thread Starter
Jimdawg185's Avatar
Member #123937
I was thinking that ball bearings aren't really meant for this type of thrust application. This is more a spherical beveled roller application.
What is the overall solution?
I'm thinking big bore and turbo, or Z1 when this goes back together. I'm open to any recommendations
Rzr 800 gear reduction stomper1982 Muddin' 4 March 7th, 2017 04:08 PM
Super atv transmission low gear input superdaverazor RZR XP 1000 53 November 15th, 2016 08:08 AM
Gear indicater tattoo305 RZR 570 Specific Discussion 2 July 23rd, 2016 09:01 AM
Need help asap issue going into gear bmerryman RZR 570 Specific Discussion 1 May 5th, 2016 10:54 AM
