Front differntial rebuild - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old May 25th, 2017, 08:24 PM Thread Starter
Bandit1009's Avatar
Member #200201
View Bandit1009's Photo Gallery(0)
Wrench Front differntial rebuild
Hello all new to the forums, have a question about 2015 RZR1000 front differential. Had a lot of play in the front axles (2100 miles). Been reading a lot in the forums about the plastic Sprague carrier and decided to replace with aluminum Sprague, also new output hub assembly, rhino axles and seals. Problem im having after rebuild is when in four wheel drive and turn left or right I get a vibration, also a dull noise not a grind but a low growl, going straight is fine. Before rebuild, stock axles, plastic Sprague no noise!! Just wondering if anyone else has had this problem after rebuilding front differential?
Replaced:
3235622 Polaris Front Hub assembly
3235625 (ARC-1-33-003-k) Sprague carrier super atv
rzr 1000-stock length axles Rhino super atv
Bandit1009 is offline
post #2 of 3 Old June 5th, 2017, 05:19 PM Thread Starter
Bandit1009's Avatar
Member #200201
Re: Front differntial rebuild
Bump bump, any suggestions? Talked to super atv no suggestions.. They (super atv) asked if there were shims in the differential, no shims.. Heading to Black MT. in a week, Hope its ok lol!! Love the ride and the performance of the razor awesome machine, when its not on jack stands!! Just sick of the quality of the wheel bearings, bushings, front differential, timing chain tensioner, slop in the cv splines etc etc!!! MADE IN AMERICA LOL!! Sorry ranting a little bit lol!! Cant wait for HONDA to come out with a REAL MACHINE!!
post #3 of 3 Old June 5th, 2017, 05:56 PM Thread Starter
Bandit1009's Avatar
Member #200201
Nothing against Super Atv or any other after market company trying to make the razor reliable... Just very disappointed in the reliability of the razor.. You and I spend 20,000 on a side by side 5,000 in extras.. After a couple hundred miles it starts nickeling and dimeing you.. Then after a couple of thousand hold on to you're ass... Polaris is supposedly the industries leader in the side by side market.. If this is the case POLARIS, work on the reliability before reaching the next mile stone with can-am...
RT Pro - RZR 900 / 1000 / Turbo Front Arm Brace Kit RT PRO RT PRO UTV 65 March 11th, 2018 05:44 PM
Front Fascia 88_pathy RZR XP 1000 3 May 2nd, 2016 08:10 AM
XPT and Fox Edition front sway bars available Shock Therapist Shock Therapy 5 April 11th, 2016 12:47 PM
2013 900xp motor rebuild Powerstrokenit RZR XP 900 2 February 22nd, 2016 03:45 PM
Xp front end rebuild s102000 RZR XP Suspension 0 December 14th, 2015 11:16 AM
