transmission case sealant? - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old May 17th, 2017, 09:56 AM Thread Starter
Go fast or go home
ncstan's Avatar
First Name: Scott
My RZR: 2018 RZR RS1
Member #53879
View ncstan's Photo Gallery(0)
Wanted to here from you tranny experts on what type of sealant you recommend for sealing the tranny case when putting back together and technics or how much to use. I just want to get it right and never have to crack it open again.
My xp 1000 leaked from the beginning from Polaris not using enough.
Thanks.
ncstan is offline
post #2 of 4 Old May 17th, 2017, 08:56 PM
Jballou_woo's Avatar
My RZR: 2015 XP4 1000
Member #151081
View Jballou_woo's Photo Gallery(0)
Re: transmission case sealant?
You have several choices. Toyota FIPG orange for transmissions, Hondabond, Yamabond. I chose Toyota FIPG ( form in place gasket). I have a bit of experience with it, and you don't see Toyota manual transmissions leaking from where it has been used. Aluminum to cast, or aluminum to aluminum, or cast to steel. It doesn't leak from there. So that's what I used when I replaced the bearings and resealed my case.
Jballou_woo is offline
post #3 of 4 Old May 17th, 2017, 10:07 PM Thread Starter
Go fast or go home
ncstan's Avatar
First Name: Scott
Member #53879
Thanks for the help. Did you use the same sealant around the inner clutch case bolts?
wanted to ask since you didn't mention using it with plastic.
ncstan is offline
post #4 of 4 Old May 21st, 2017, 09:42 PM
Member #151081
I just used regular RTV around the plastic inner clutch case to the main transmission housing.
XP 900 Transmission - Blown at 1450 miles! BryanD Engine and Drivetrain 272 January 22nd, 2019 03:25 PM
Disappearing Transfer Case Fluid? turner606 General RZR Discussion 8 August 22nd, 2016 11:07 PM
Cracked transmission case??? timoloco RZR XP Turbo 13 April 17th, 2016 08:08 AM
RZR 1000 Transmission case cracked 1Hammerhead RZR XP 1000 5 January 1st, 2016 09:56 AM
