How to pull rear axle that broke by diff? Xp4 1k - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By RZR4familyguy
post #1 of 11 Old February 28th, 2017, 06:39 PM Thread Starter
Metatrox's Avatar
Member #182745
View Metatrox's Photo Gallery(0)
Hey guys having a hard time trying to figure out of the pull the rear driver axle. It broke close to the diff and have nothing to pull on. Most videos I see broke at wheel.
Any thoughts or techniques?
Thanks!
Metatrox is offline
post #2 of 11 Old February 28th, 2017, 08:19 PM
Zap!
LadderLogicLloyd's Avatar
First Name: Lloyd
My RZR: XP1000
Member #83265
View LadderLogicLloyd's Photo Gallery(0)
Re: How to pull rear axle that broke by diff? Xp4 1k
Use flat rope? Half hitch that sucker three or four times and tug it the hell off.
Pull the boot off, find a way to get a slide hammer hooked good.
Maybe get a two jaw puller, it may fit behind the cv if it is thin fingers, then use the puller to hold on to and get some oomph on it.
Last ditch, maybe pry GENTLY between the case and the cv... careful prying against the case though!
Surrounded by awe inspiring amounts of open desert, attempting to explore every square foot of it.
LadderLogicLloyd is offline
post #3 of 11 Old February 28th, 2017, 09:00 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Can you pull the passenger side axle and push the driver side stub out thru the differential?
2014 800 LE w/EPS 50
CA 800 is offline
post #4 of 11 Old March 1st, 2017, 02:45 AM
Mudgunner's Avatar
Member #178553
View Mudgunner's Photo Gallery(0)
Spray where it inserts into the diff with penetrating oil and let sit for about 30 mins. The splines rust inside the diff and get stuck.
Mudgunner is offline
post #5 of 11 Old March 1st, 2017, 04:14 AM
gmiller0737's Avatar
First Name: Gordon
My RZR: 2012 RZR 570
Member #47617
View gmiller0737's Photo Gallery(0)
Vise Grips With A Slide Hammer Attachment
gmiller0737 is offline
post #6 of 11 Old March 1st, 2017, 04:17 AM
mHMFs's Avatar
My RZR: 2015 900 S
Member #5186
View mHMFs's Photo Gallery(0)
I'm with Geoff.
mHMFs is offline
post #7 of 11 Old March 1st, 2017, 04:36 AM
RZR4familyguy's Avatar
First Name: Brian
My RZR: 2012 RZR 4 800 sold. 2015 900s, 2016 Xp 1k4
Member #49615
View RZR4familyguy's Photo Gallery(0)
Yes you can I've had to do that before
RZR4familyguy is offline
post #8 of 11 Old March 1st, 2017, 04:41 AM
First Name: Brian
Member #49615
There's another thread on here about this with a link to a slide hammer built for this . If that don't work after it's been sprayed clamp vise grips to it then connect a ratchet strap to vise grips then the other end to a fixed object and pull tension while tapping on it with a mallet it should pop out
Mudgunner likes this.
post #9 of 11 Old March 1st, 2017, 04:44 AM
waynesworld001's Avatar
First Name: Wayne
My RZR: 2015 XP 1000 / 2017 XPT 4
Member #94809
View waynesworld001's Photo Gallery(4)
I'm with Geoff.
Agreed. In the time it'll take to keep figuring / trying different ways to grab it and pull it out, you can just pull the opposite axle and tap this one out. Shouldn't take more than 10 - 15 minutes.
Can't sleep. Clowns will eat me.
2017 XTP 4 - TBD.....
2015 XP 1000 - Shock Therapy Level 3 Spring Kit / Front Sway Bar, Alba Racing Stage 1 kit / Rear Radius Rods / Sway Bar Links / Front Bumper, Flight OffRoad "Shorty" Cage, ITP SS112 Wheels, Autotude High Clearance A-Arms, Southern Sounds MTX Roof System, SSV Works Sub, Super ATV 4500lb Winch, UTV Giant Full Doors / Rear Storage, Trail Control Gated Shifter, Adventure Air Onboard Compressor, Pro Armor Harnesses, Gorilla Whips.
waynesworld001 is offline
post #10 of 11 Old March 1st, 2017, 06:03 AM Thread Starter
Metatrox's Avatar
Member #182745
If I decide to pull the other side isn't there a chance the wrong c clip could give way and be stuck with both sides stuck ?
Also does the c clip break or just give in when you yank it out?
Metatrox is offline
post #11 of 11 Old March 1st, 2017, 09:58 AM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
The C clip compresses into a groove when the inner cv is being removed/installed.
You can use a pry bar, or pull the other side and use a punch and a hammer. We usually use a pry bar.
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
Blown rear diff? IZ48 RZR 800 Specific Discussion 13 July 11th, 2016 10:05 AM
2013 XP Polaris Rear Diff Fluid? jeremyb2001 RZR XP 900 2 June 27th, 2016 05:32 PM
Rear diff number Wiser RZR 800 Specific Discussion 10 March 27th, 2016 09:40 AM
WTB stock tie rods, right trailing arm, rear big horn XP4 1000 rzr4for3 Polaris RZR Parts For Sale 3 November 25th, 2015 07:49 PM
