4wd not working - Polaris RZR Forum - RZR Forums.net
post #1 of 23 Old June 3rd, 2010, 01:37 PM Thread Starter
boat4life's Avatar
Member #6680
View boat4life's Photo Gallery(0)
4wd not working
I just rebuilt my sprague carrier with the billet one and installed everthing into carrier as told to..i have power at plug,but my awd will not kick in...dealer told me to replace flat armaure and it will fix...any input on how this will fix the issue thanks
boat4life is offline
post #2 of 23 Old June 3rd, 2010, 03:03 PM
Trail Boss's Avatar
My RZR: 2013 RZR XP 900 HO Kit
Member #15298
View Trail Boss's Photo Gallery(0)
Re: 4wd not working
Do a resistance check on wires from front diff, if not good needs new housing assembly
just did mine, broken wire to coil inside housing
Trail Boss is offline
post #3 of 23 Old June 3rd, 2010, 03:24 PM
Adnoh's Avatar
Member #14866
View Adnoh's Photo Gallery(0)
Re: 4wd not working
Not only check resistance also check the u- shape insert where the coil sets and the armature wear marks as noted in manual. You can also check the awd wiring thu the spedo and to see if its sending power to the coil. I first check spedo then power at plug by diff and then coil resistance and check for short and then tare down and inspect the armature plate and u- shape insert.
Name:	Armature plate and wear marks.JPG
ID:	16530   Click image for larger version
Name:	Armature plate inspection (normal wear).JPG
ID:	16531   Click image for larger version
ID:	16532   Click image for larger version
Name:	Disconect harness plug to coil .JPG
ID:	16533   Click image for larger version
Name:	Coil resistance.JPG
Adnoh is offline
post #4 of 23 Old June 7th, 2010, 09:40 PM Thread Starter
boat4life's Avatar
Member #6680
Re: 4wd not working
what do you check at speedo. checked all wires and ohmed out plug..got 23.8 ohms.. i know i'm getting power..i just replaced the armature plate...will the front wheels engauge with all wheels in air on jacks if i rev it up in awd or does it need to be on ground..
post #5 of 23 Old June 7th, 2010, 09:45 PM
sandspanker's Avatar
First Name: Jerry
My RZR: 2008 aerocharger xmf 6"
Member #1472
View sandspanker's Photo Gallery(4)
Re: 4wd not working
I had to go back in and change the armatur also, now its money.
sandspanker is offline
post #6 of 23 Old June 7th, 2010, 10:06 PM Thread Starter
boat4life's Avatar
Member #6680
Re: 4wd not working
could you see issues with the armature or not i just replaced mine tnite but haven't taken off the jacks but my front wheels will not lock up.. maybe need to ride to find out...
post #7 of 23 Old June 7th, 2010, 10:08 PM
King of crash!
Member #787
Re: 4wd not working
dumb question but do you have a gear indicator and 4x4 indicator lit up on insterment cluster?
also some people have had to replace the springs on the carier the old one's didnt work right
johnnycat8 is offline
post #8 of 23 Old June 7th, 2010, 10:27 PM Thread Starter
boat4life's Avatar
Member #6680
Re: 4wd not working
The h springs??? all my indicator lights are working
post #9 of 23 Old June 7th, 2010, 10:31 PM
King of crash!
Member #787
Re: 4wd not working
yep the h springs some have had a problem with some warped part also sorry but i cant remeber it ill try and find it...it was posted by ralph rjsmith
post #10 of 23 Old June 8th, 2010, 07:29 AM Thread Starter
boat4life's Avatar
Member #6680
Re: 4wd not working
will the 4x4 kick in on jack stands or do you have to run on ground....
post #11 of 23 Old June 8th, 2010, 10:32 AM
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Feedback Score: 5 reviews
Re: 4wd not working
I would think it would kick in...
Chris Dierkens
teamhog is offline
post #12 of 23 Old June 8th, 2010, 11:19 AM
bagman's Avatar
My RZR: 2015 1K Havasu Red
Member #649
Re: 4wd not working
Yes, AWD engages with all the tires off the ground.
bagman is offline
post #13 of 23 Old June 8th, 2010, 03:22 PM Thread Starter
boat4life's Avatar
Member #6680
Re: 4wd not working
any body have any ideas of what to check next.. thanks for the input...i really need 4x4
post #14 of 23 Old June 9th, 2010, 08:00 AM
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Re: 4wd not working
Go through the punch list of items that are required for the 4WD to engage...
I believe all of them have been listed here in this thread..
If not, make a list and then go through it..
Chris Dierkens
teamhog is offline
post #15 of 23 Old June 9th, 2010, 08:34 AM
willaili's Avatar
My RZR: 2008
Member #12069
View willaili's Photo Gallery(0)
Re: 4wd not working
I am in the exact same situation. I replace the carrier, new h-clips, new armature, new seals. All electrical checked and rechecked it was all ok I then replaced the speedo thinking there was a problem internally, didn't work. I put it up on the lift and ran a direct connection from the battery to the front diff I could hear the armature engage when voltage was put to it. I then ran it up on the lift with the direct connection from the battery and the fronts locked in and started turning. I assume now that somewhere in the system there is a bad ground although I have not been able to find it!?!?! I have traced every wire and followed every popo service manual flowchart. I am completely stumped.
anyone have another idea???
willaili is offline
awd not working Pipefitter RZR-S Specific Discussion 32 April 5th, 2012 10:23 PM
4wd not working RAZOR FREAK Engine and Drivetrain 30 July 11th, 2010 04:46 PM
awd not working Eddiebtuff Engine and Drivetrain 6 February 1st, 2010 06:21 PM
4 wd not working kybodyguy Engine and Drivetrain 1 January 8th, 2010 02:21 PM
Working man workingman Member Introductions 1 July 27th, 2008 08:20 AM
