changing the fuel pump. - Page 18 - Polaris RZR Forum - RZR Forums.net
post #256 of 258 Old August 23rd, 2015, 01:53 PM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Re: changing the fuel pump.
Originally Posted by RenoDeano View Post
Originally Posted by Pirate View Post
The test set up is very easy to fabricate. I put all the parts you need and how to do it in my post.
Maybe $15 to $20 at most.
Its a great troubleshooting tool when you're looking for a problem, and before you spend a lot of money being a "parts changer".
JMHO
Pirate
Pirate, where do I find you "sticky" on building a fuel pump test for a RZR 800. Where do you connect it?
I have a 2012 and meets all of the symptoms for a bad fuel pump. I cannot find where to people asking about pumps for 2012's was resolved?
Thanks for all your posts. Reno Deano
Here is a link to that thread:
https://www.rzrforums.net/engine-driv...est-setup.html
It is in this forum subject area.
Mike
MikeT is offline
post #257 of 258 Old January 9th, 2016, 08:22 AM
bluetoad7's Avatar
First Name: Ron
My RZR: 2017 XP 1000 Gold Matte Metallic Rock Crawler Edition
Member #19658
View bluetoad7's Photo Gallery(0)
Had the dreaded fuel pump issue. Followed the procedure johnnycat8 posted here. The brass nutserts were a problem as usual since Polaris chose to use thread locker on the bolts. Four of the six were locked into the nutserts and had to be pried off the fuel tank. Reset them with JB Weld and bought a $14.95 fuel pump off Ebay. Pump now works fine, but would't hold pressure. The pressure regulator failed. Couldn't find a replacement with the same rating of 270 KPa and the part number on the Polaris fuel pump assembly doesn't exist nor is there a cross reference that I was able to find. After a lengthy search I found a similar fuel pressure regulator with a rating of 3 Bar. Turns out 270 KPa is 2.7 Bar. 1 Bar = 14.5 psi, so 3 Bar = 43.5 psi. Not quite 39 psi, but close enough. Part number is 0280160557. Fits a VW Jetta Mk 3/Mk4, 1.8T and 2.0L engine. $34.43 on Amazon Prime. Installed it and now the fuel pressure test yields exactly 43.5 psi. It looks slightly different with a hose barb for the overflow exit, but does not interfere with re-installation.
Da Blue Toad
bluetoad7 is offline
post #258 of 258 Old August 26th, 2016, 09:13 PM
freedom24's Avatar
My RZR: RZR 800
Member #4047
View freedom24's Photo Gallery(0)
Ron. Great work ! You're a good man ! My RZR thanks you as well!
freedom24 is offline
09 RZR Fuel tank with fuel pump wheelman20012002 Polaris RZR Parts For Sale 2 May 12th, 2011 11:33 AM
What fuel pump are you using? crazywatson Engine and Drivetrain 5 November 11th, 2009 06:28 PM
Fuel Pump 101 bagman General RZR Discussion 10 June 28th, 2009 04:00 PM
Stock fuel pump turboless Engine and Drivetrain 5 May 21st, 2009 07:11 PM
Fuel Pump crazy coonie General RZR Discussion 4 January 28th, 2009 01:59 PM
