4 wd not working - Polaris RZR Forum - RZR Forums.net
post #1 of 2 Old January 8th, 2010, 02:06 PM Thread Starter
kybodyguy's Avatar
Member #6034
View kybodyguy's Photo Gallery(0)
4 wd not working
ok guys heres the problem , my rzrzs has quit going into 4wd .my son was was riding on the hardtop had gone about 1/2 mile when he said it acted like he was hitting the brakes and slowed down even though he was giving it gas ,then it popped and grinded a little and freed up .2 days later noticed gear oil dripping out of rear diff.pulled left side axle as I thought it may have popped axle out and went back in and damaged the seal.the seal looked fine and oil is leaking from sidecase just under the seal so it must have a hairline crack in it .it leaked about 6 ounces of oil in over a week.dealer said can't get to it for several days so I decide to fill with oil to ride the snow until then and noticed 4wd isn't working .the light comes on but it won't go into 4wd.what do I need to look at now?
kybodyguy is offline
post #2 of 2 Old January 8th, 2010, 02:21 PM
rjsmith's Avatar
First Name: Ralph
My RZR: 2009 RZR Red
Member #4388
Re: 4 wd not working
rear diff has nothing to do with AWD. if the light comes on then check for voltage at the diff you need at least 11.8 v. If voltage then problem could be warped armature or broken sprague cage inside front diff. Only way to find out is to open and look inside. If under warranty report it to dealer, this is a common problem.
XP1000 Titanium Black
RZR 800 put out to pasture
1 Limey in a world of Yanks
rjsmith is offline
4wd not working RAZOR FREAK Engine and Drivetrain 30 July 11th, 2010 04:46 PM
powercomnder not working saqer Engine and Drivetrain 5 January 6th, 2010 06:40 PM
awd only working in reverse heyfordfamily8 Engine and Drivetrain 3 December 2nd, 2009 04:12 PM
4wd not working? jlanier86 Engine and Drivetrain 7 May 24th, 2009 02:01 PM
Working man workingman Member Introductions 1 July 27th, 2008 08:20 AM
