Fuel pump test setup - Page 4 - Polaris RZR Forum - RZR Forums.net
post #46 of 57 Old February 18th, 2014, 04:10 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Re: Fuel pump test setup
You can get to the end of the fuel rail, with the bed on, by taking the right rear tire off.
You'll have to twist your self around a bit to be able to see along the left side of the valve cover, Then its probably a bit tough to tight a clamp to hold the test kit hose on the fuel rail.
Do yourself a favor and get a UTV Inc. bed plate...and excellent investment!
Pirate
Pirate is offline
post #47 of 57 Old February 18th, 2014, 04:27 PM
Rubberdown's Avatar
My RZR: 2009
Member #1505
View Rubberdown's Photo Gallery(0)
Pirate
I'll see what I can do, I'm a big boy, getting twisted up in tight spots is a tough one for this guy LOL.
As for the bed thing, I wasnt away anyone made one and I've had one on the back burner for a few years now (ever since I pulled the bed off my machine a few years ago) but just havent gotten around to it yet.
Rubberdown is offline
post #48 of 57 Old March 29th, 2014, 08:01 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Clifford,
I tried to help a friend with an XP900 check the fuel pressure.
I'm afraid I think the answer is no.
There is a clip fitting on the fuel rail, but it is the connection of the fuel line to the fuel rail at the injectors.
Beyond the injectors, there is a pressure regulator with a return line to the fuel tank.
This being said, I thing the place to test XP fuel pumps is at the fuel tank. I think that readings there would be representative of what the pressure is at the fuel rail.
I didn't get a chance to figure out if the pressure regulator makes it difficult to determine if the pump is beginning to fail...only that is has.
Just thoughts,
Pirate
Pirate is offline
post #49 of 57 Old October 26th, 2015, 10:36 PM
RCC1948's Avatar
First Name: Clint
My RZR: 08 800
Member #41565
View RCC1948's Photo Gallery(0)
I'm not an not an engineer in fluid dynamics and certainly not an expert on RZR fuel systems.
But I tend to think that a regulator, whether gas, liquid, or voltage, is supposed to regulate!
I would expect a regulator set at 39 psi would have a supply of greater than 39 psi.
The regulator would then allow pressures of 39 lbs of less to go to the injectors. Any pressure over 39 would open the internal valve and slow the excess to be bled off back to the tank through the fuel return line.
To maintain pressures of 39 psi during full throttle, the pump would have to be capable of higher pressures. I would expect a flow of fuel returning to the tank with engine off or at idle, meaning that you would have a minimum of 39 psi and the regulator is regulating!
If you have a weak pump as the injectors open, the pressure would drop.
Trying to reason through this.
My 08. 800 Boggs down about 30 mph up hill and is getting worse. Just replaced tank and pump with aftermarket parts about 300 miles ago.
I'm going to build an inline gauge set up to monitor the pressure under load. I will let you know what I find out.
Clint
RCC1948 is offline
post #50 of 57 Old October 27th, 2015, 05:18 AM
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Feedback Score: 5 reviews
Clint
If it's only under load have you checked out your clutches
Chris Dierkens
teamhog is offline
post #51 of 57 Old October 27th, 2015, 07:55 AM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Clint,
Bear in mind that the injectors are the "pressure regulating" point in the RZR fuel injection system.
If the pressure is a lot higher than the rated, 39+/- 3 psi then the electric injectors might not be able to overcome the pressure and open the injector.
If the pressure is low, failing pump, then the injector is not able to provide enough fuel while its open.
Installing a gauge is probably not necessary. If the pressure at idle and when you step on the gas while in "N" and you get the 39+/-3 psi...the pump is doing its job and providing the injectors with sufficient fuel.
What exactly the ECU does to injector "open time" due to load, isn't a function of fuel rail pressure.
You're having problems...have you checked the fuel pump pressure again after the work you've done and the 300 miles since? That's where I would start.
There have been tales of new fuel pumps that were not good. Did you use an Airtex E-8335? That's the aftermarket pump that fits and works.
Thoughts?
Pirate
Pirate is offline
post #52 of 57 Old October 27th, 2015, 04:59 PM
RCC1948's Avatar
First Name: Clint
My RZR: 08 800
Member #41565
Thanks Stuart, I had a shop install the pump and tank. It was an E 8335. They said the pressure was correct. My machine had 1200 miles when I got. It now has 3600. When the new pump was first installed it was the quickest it had ever been. On my last trip to Windrock, the third day I noticed a loss of power on the long uphill pull on G2. Speed was around 25 - 30 and rpm were 4500 - 4800.
I replaced the air filter and found a big crack (exhaust leak) in the exhaust manifold.
I have a new exhaust.
My biggest problem is my machine is currently 2 hours away. I have a friends shop and 450 acres to test ride on. I'm building my pressure tester and will take it up there Thursday.
I'll let you know what I find.
Clint
RCC1948 is offline
post #53 of 57 Old October 27th, 2015, 09:38 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Clint,
I'll be interested to hear what you find.
If you find the pump is failing, or you're going to take it out for inspection...then would be a good time to consider a Trail Tank 9 gallon fuel tank.
I put one in my 09 RZR 800 this past Winter....very nice to have the extra fuel capacity for long days!
Just a thought,
Pirate
Pirate is offline
post #54 of 57 Old October 27th, 2015, 11:50 PM
RCC1948's Avatar
First Name: Clint
My RZR: 08 800
Member #41565
I have a Trail Tank. I had a slow leak on my oem tank so when the pump toasted last summer I had both replaced.
I love it! I can go to from Windrock Park to Caryville Flats and play all day and get back to camp without having to carry extra gas.
Clint
RCC1948 is offline
post #55 of 57 Old May 4th, 2016, 09:58 PM
stang233's Avatar
Member #73216
View stang233's Photo Gallery(0)
Will this work with a 900xp?
2014 - RZR XP 900 Stealth Black
--Pro Armor Harnesses --Fuel Customs Intake --UTV Giant Cage --UTV Giant Doors --Trail Bright 30" 180W Light Bar -- Alba Switch Plate -- PitsterPro Middle Seat -- Dalton Clutch Kit Alum Rivets w/3 set screws (not yet tested) -- Skat Trak 26x12.5x12 Rear on 10" 5+5 and Buffed Fronts 26x12.5x12 on 8" 4+4
stang233 is offline
post #56 of 57 Old June 23rd, 2017, 12:36 PM
alaska_guy's Avatar
Member #180881
View alaska_guy's Photo Gallery(0)
So I know this is an old thread... But I thought I would provide some feedback as I made the mentioned fuel tester and tried 1/4" ID hose... Way too tight of a fit. Use 3/8" fuel line instead and a hose clamp.
I also was curious if 2011 year and up models are supposed to be 39 psi or 45? My manual says 45 +/- 2 psi, which would be right around 43-47 psi. I am only getting 39psi when running and it takes a bit to get there. From a cold start turning key on I get around 32psi maybe. I think my pump is on it's way out, but want to confirm.
Thanks!
2017 Polaris General 4
2011 RZR 800 Sport - EPI Clutch Kit, SLP Super Silent Muffler, Bumpers, Winch, Windows, fender flares, 27" mud lites, EPS, SuperATV steering rack, RTPro Springs, 5 point harnesses and center seat. SOLD
alaska_guy is offline
post #57 of 57 Old June 23rd, 2017, 04:37 PM
alaska_guy's Avatar
Member #180881
Went to polaris and bought a new pump, installed it and I am getting 45psi now. So 2011+ should be 45psi like the manual stated.
Rzr 800 fuel tank w/ fuel pump for sale rxutv Polaris RZR Parts For Sale 2 February 3rd, 2013 09:49 AM
Fresh air pump- dual setup!!! xtremetoyzracing Polaris RZR Parts For Sale 6 January 31st, 2012 08:20 PM
Would a fuel pump cause this MossLager Engine and Drivetrain 1 November 9th, 2011 10:40 PM
Fuel pump inthetundra Engine and Drivetrain 12 June 1st, 2011 10:43 AM
09 RZR Fuel tank with fuel pump wheelman20012002 Polaris RZR Parts For Sale 2 May 12th, 2011 11:33 AM
