Fuel pump test setup - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 57 Old March 14th, 2013, 11:40 AM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Re: Fuel pump test setup
To all,
Here's the link to the Photobucket album where my fuel pump test kit documents can be found, printed or downloaded. Its a public album!
Rooster5488's Library | Photobucket
If you can't get to it, lemme know!
Pirate
Pirate is offline
post #17 of 57 Old March 15th, 2013, 12:35 PM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Originally Posted by Pirate View Post
To all,
Pirate
It's password protected, got a "Login Failed" message w/o using a password.
Mike
MikeT is offline
post #18 of 57 Old March 15th, 2013, 03:35 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Mike,
I checked again, its a public album...should be able to get to it.
Send me a PM and I'll get them to you via e-mail.
Pirate
Pirate is offline
post #19 of 57 Old March 18th, 2013, 09:14 AM
MikeT's Avatar
Member #14202
Tried again just now, Site is down for maintenance. Will try again tomorrow.
Mike
MikeT is offline
post #20 of 57 Old March 19th, 2013, 10:00 AM
MikeT's Avatar
Member #14202
PM on the way Pirate. Still can't get on.
Mike
MikeT is offline
post #21 of 57 Old August 19th, 2013, 10:37 AM
rzrwood's Avatar
First Name: Rick
My RZR: 2013 900xp le
Member #2730
View rzrwood's Photo Gallery(0)
Nice set up. Ive got every thing to do that, it really don't matter weather it on the rail or at the pump does it? on an 08 its much easier to access the pump..
rzrwood is offline
post #22 of 57 Old August 19th, 2013, 02:20 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Nope, no difference.
I have a UTV Inc. bed plate, which is easy to remove and give access to the engine compartment. Its actually easier to get to the fuel rail than it is to take the seat out to get to the pump!
I have found that if you test the pump, replace the pump, then turn the key on, the fuel rail pressurizes to 39 psi. If you start the engine...it stays at 39 psi. The pump has the capability to push more fuel than the injectors can use. So you can test with the engine off or the engine on.
Pirate
Pirate is offline
post #23 of 57 Old September 17th, 2013, 06:07 PM
harleybuilder's Avatar
My RZR: 2008
Member #40758
View harleybuilder's Photo Gallery(0)
Great write up..I have a question,my fuel rail (08) has a shrader (sp) valve, do they make an adapter to fit it?
Thanks....
harleybuilder is offline
post #24 of 57 Old September 17th, 2013, 08:58 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Mike,
Is the "however its spelled" valve at end of the fuel rail...towards the back of the RZR past the throttle body?
I believe NAPA or Ace Hdwe or someone that carries a lot of brass fittings will have a fitting that screws onto a valve stem and then converts to pipe thread. From there you can adapt to whatever you are using for the test kit.
RV shops may also have something that's used for blowing out water systems for winterizing.
Pirate
Pirate is offline
post #25 of 57 Old September 18th, 2013, 11:45 AM
My RZR: 2008
Member #40758
Thanks.
Sent from my SCH-I535 using Tapatalk 2
post #26 of 57 Old September 18th, 2013, 11:55 AM
BIGGJIM's Avatar
First Name: Jim
My RZR: R1 Powered Rhino
Member #3236
View BIGGJIM's Photo Gallery(0)
How are you stopping the pressure from going past the pressure releif?
BIGGJIM is offline
post #27 of 57 Old September 18th, 2013, 03:49 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Jim,
Not sure what you're asking.
I attach the test set up to the end of the fuel rail and clamp it.
Then turn on the key and check the pressure.
I've started the RZR and the pressure remains the same.
I've caught all kind of S*^* over past days on a "pressure regulator". If there is one, and I guess there is, then the pressure regulator must set the 39 +/-3 psi. A failing pump doesn't get there.
So I think my answer to you is that the pressure regulator does what its supposed to, by maintaining the 39 psi. If the test gauge reads low...then its the pump. Learning that there is a regulator makes me wonder if there is a chance the regulator can fail...causing low pressure, by relieving too much. Or as the other post, the pressure was too high.
Really not sure how to test the pressure regulator.
Just my take.
Pirate
Pirate is offline
post #28 of 57 Old November 22nd, 2013, 05:08 PM
RMR Man's Avatar
First Name: Steve
Member #11566
Just thought I'd bring this back up. A BIG THANKS to Pirate for this inexpensive set up to help diagnose a common problem.
RMR Man is offline
post #29 of 57 Old February 12th, 2014, 11:37 AM
jagutier82's Avatar
First Name: Javier Gutierrez
My RZR: 2011 Rzr 4 800
Member #49783
View jagutier82's Photo Gallery(0)
Thank you Pirate. Just not sure if its my pump or spark plugs going bad. Changing both any ways. Once again thank you very much.
jagutier82 is offline
post #30 of 57 Old February 12th, 2014, 12:18 PM Thread Starter
Pirate's Avatar
First Name: Stuart
Member #3677
Javier,
If you're changing plugs, put in the NGK Iridium plugs.
No, I can't remember the number right off the top of my head, but if you need it let me know and I'll get it for you.
Pirate
Pirate is offline
Rzr 800 fuel tank w/ fuel pump for sale rxutv Polaris RZR Parts For Sale 2 February 3rd, 2013 09:49 AM
Fresh air pump- dual setup!!! xtremetoyzracing Polaris RZR Parts For Sale 6 January 31st, 2012 08:20 PM
Would a fuel pump cause this MossLager Engine and Drivetrain 1 November 9th, 2011 10:40 PM
Fuel pump inthetundra Engine and Drivetrain 12 June 1st, 2011 10:43 AM
09 RZR Fuel tank with fuel pump wheelman20012002 Polaris RZR Parts For Sale 2 May 12th, 2011 11:33 AM
