rzr parking brake, great new system! - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 193 Old March 30th, 2009, 11:03 AM Thread Starter
gunrunner's Avatar
First Name: Man
Member #4830
Re: rzr parking brake, great new system!
Originally Posted by rjsmith View Post
Do the break lights activate when you have the parking lock on?
Yes if you have the switch turned on, but not if switch is off. Its a simple system it pushes down on the brake pedal and locks in position, locking all 4 wheels until you release the lever.
gunrunner is offline
post #17 of 193 Old March 30th, 2009, 01:52 PM
botrod's Avatar
Member #4762
View botrod's Photo Gallery(0)
this woudl also help when trailering. I hate to have it in Park on the trailer because even when strapped down, it moves back and forth a little. That seems to be strain on the tranny it could do without.
botrod is offline
post #18 of 193 Old March 30th, 2009, 01:57 PM Thread Starter
gunrunner's Avatar
First Name: Man
Member #4830
I had not thought of that but it would help hold it in place while on the trailer.
post #19 of 193 Old March 30th, 2009, 01:59 PM
botrod's Avatar
Member #4762
do i get a discount for thinking of another selling feature
botrod is offline
post #20 of 193 Old March 30th, 2009, 02:22 PM
bajarzr's Avatar
First Name: chuck
My RZR: gen two
Member #3074
View bajarzr's Photo Gallery(0)
here is the problem i see with it,the rzr uses a 2 stage master cylinder,if you break a brake hose on the front or rear the brake pedal will drop further but you will still have some brake, if the rod won't let that pedal drop when this happen's you will have no brake's at all ,and anyone who ever had a broken brake line a an old car will know what i am talking about
bajarzr is offline
post #21 of 193 Old March 30th, 2009, 03:47 PM
airbornjim's Avatar
First Name: Jim
My RZR: '09 LE
Member #5400
View airbornjim's Photo Gallery(35)
SS braided lines aren't as likely to break as an Old Car though
'09 Nuclear Sunset LE, +4 MB Products LT w/WER shocks, DMC dual Exhaust, Dynatek CDI & Controller, F2 Racing air box, Polaris winch, 2" hitch, Wideband O2, A/F, oil pressure, Water temp, Volt guages, Dragonfire Harnesses, full belly skid plate, A-Arm covers, MB Products cage, HID's, Heavy duty front bumper, Holz Clutch
airbornjim is offline
post #22 of 193 Old March 30th, 2009, 04:25 PM
botrod's Avatar
Member #4762
I see this as something I would use only when trailering or having to stop on a steep hill. If you are going to blow a brake line, it seems like it would happen either way. This may put on some constant pressure and make it more likely, but I would much rather replace a brake line than a tranny
botrod is offline
post #23 of 193 Old March 30th, 2009, 04:36 PM
bajarzr's Avatar
First Name: chuck
My RZR: gen two
Member #3074
ya but they will break if something goes in there and breaks a hose , i replaced one of mine i hit a peice of steel and it cut the left front line all the way though ,i still had rear brake's but the pedal went almost to the floor
bajarzr is offline
post #24 of 193 Old March 30th, 2009, 08:34 PM
guy48065's Avatar
Member #309
Feedback Score: 16 reviews
It doesn't look like the rod prevents the pedal from going all the way to the floor. It pushes only.
guy48065 is offline
post #25 of 193 Old March 31st, 2009, 12:16 AM
wildmanMG's Avatar
First Name: Phil
My RZR: 2008 Green GEN3 RZR
Member #1864
View wildmanMG's Photo Gallery(0) Send a message via AIM to wildmanMG Send a message via MSN to wildmanMG Send a message via Yahoo to wildmanMG
The rod is telescopic. It slides outwards when you hit the pedal. When you lock the lever down it bottoms out the slide and presses the brake pedal. I designed something like this in cad but never had it produced. Good work there looks better than what I had planned.
2008 Green RZR- Front and rear deluxe bumpers,polaris 3500 winch with wireless remote,RCI 4 point harnesses,ITP wheels with 27 inch mudlite xtr's,Lone star gas pedal with KMS heavy duty spring,KMS intake setup with custom snorkle,Rotopax fuel cans,Roktek 3inch Lift, LTE Dual Exhaust.
wildmanMG is offline
post #26 of 193 Old March 31st, 2009, 08:01 AM Thread Starter
gunrunner's Avatar
First Name: Man
Member #4830
yes the likely hood of a brake line failure while sitting still is almost non existent, and if something failed in the master assembly and the pedal went down this unit would let it move as its not connected. This system works as simply as you putting your foot on the brake as we do thousands of times as we ride. The key to using the system is to apply the lever before putting the tranny in park this lets you be in park but without putting pressure on the shifting mechanism.
post #27 of 193 Old March 31st, 2009, 08:03 AM
botrod's Avatar
Member #4762
how difficult or timely was it to install?
botrod is offline
post #28 of 193 Old March 31st, 2009, 10:10 AM Thread Starter
gunrunner's Avatar
First Name: Man
Member #4830
took about 30 minutes but i was not in a hurry, its simple to install as it comes with everything needed and each is numbered. You take out the pin holding the pedal to the master cyl. add the lower rod and helm joint and replace with the longer pin. Then you take the bottom bolt out of the tilt shock and replace with the longer screw and put the brace on and add the nut. Then bolt other end or brace in pre existing hole in the brace under the dash. Then slide the ss sleeve over the bottom rod, slide the handle assembly in and tighten bolt. Then you only have to drill a hole in the tilt shock bracket for the second hole in the brace for more strength. Then you use two 1/2 wrenches to adjust the amount of pedal pressure you want. It comes with a full color photo instruction sheet with each step laid out. Id say most anyone could install it in no time, its that easy.
post #29 of 193 Old March 31st, 2009, 10:51 AM
RazorSGirl's Avatar
First Name: Jeanie
My RZR: 2014 1000xp
Member #5500
View RazorSGirl's Photo Gallery(0)
Does he have alot of these in stock or do you have to wait for them?
RazorSGirl is offline
post #30 of 193 Old March 31st, 2009, 11:52 AM Thread Starter
gunrunner's Avatar
First Name: Man
Member #4830
He told me he would be getting kits ready and even if he was temporarily out he could fill orders in 7-14 days. So the quicker a order is placed the better chance it will be filled quickly. I got mine in 4 days after my paypal payment was made.
Parking Brake for the RZR ThrottleOut Projects and How-To 77 February 15th, 2016 09:19 AM
Parking brake?? qdawg1976 General RZR Discussion 6 October 11th, 2009 03:45 PM
rzr parking brake, great system gunrunner Engine and Drivetrain 0 March 29th, 2009 07:37 PM
parking brake speedjunky General RZR Discussion 2 March 14th, 2009 07:16 PM
Parking Brake txmd500 Engine and Drivetrain 0 April 23rd, 2008 08:55 PM
