Set for XP1k4 with 28" paddles - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old March 3rd, 2014, 03:25 PM Thread Starter
Sandtastic's Avatar
First Name: Randizzle
My RZR: 2014 RZR 4 1000
Member #63435
View Sandtastic's Photo Gallery(0)
Hi Dale,
I bought one of your clutch kits for my Rzr XP41k and when I bought it I had you set it up for a stock machine to run at Glamis with stock knobbie tires.
Since then I have added a set of sand tires. I am running Sand Tires Unlimited Blaster 28"s with a full set of the #1 paddles. There are 14 paddles total with each at 7/8" high.
With the set up you sent me I was hitting the rev limiter with the paddles on. I never ran it with stock tires and your clutch kit so I dont know if it would hit the limiter or not with stock tires.
I did however run it in the dunes with stock tires and the stock clutch and never hit the rev limiter.
I called once and asked how I should change the weight set up to keep it off the limiter and you asked me to add 1 small washer to the middles and tips for a total of the following;
Base: 2 thick and 2 thin
Mid: 2 thin
Tips: 2 thin
My question is since I am still hitting the limiter how should I change the weights? Or something else? And what would be my 2nd and 3rd change if the initial doesn't fix it?
Thanks in advance,
Randy
760.908.7420Click image for larger version
Sent from my GT-P5210 using Tapatalk
Sandtastic is offline
post #2 of 5 Old March 3rd, 2014, 03:48 PM Thread Starter
Sandtastic's Avatar
Member #63435
Re: Set for XP1k4 with 28" paddles
By the way, I blew a belt with the set up above with four adults running the dunes mid to high throttle with air temps in the low 60s. Total weight of passengers was abt 750 lbs.
post #3 of 5 Old March 3rd, 2014, 03:48 PM Thread Starter
Sandtastic's Avatar
Member #63435
My belt housing exhaust temp was never above 180 degrees F.
post #4 of 5 Old October 4th, 2014, 10:10 PM
mstrav1973
Guest
mstrav1973's Avatar
Member #
Posts: n/a
View mstrav1973's Photo Gallery()
what were the final adjustments on this?
Matt
post #5 of 5 Old October 5th, 2014, 07:40 AM Thread Starter
Sandtastic's Avatar
Member #63435
Base - Unchanged
Mid - 1 thick
Tip - 1 thick
Paddles and maybe rims for xp1k4 The Legend Discount Tire 1 December 16th, 2013 07:22 AM
Paddles - STU Blasters - 26" with 12" DWT Rims ~SOLD~ benhoopes Misc For Sale 2 November 30th, 2013 01:10 PM
Lumberjack Paddles 25" & Douglas 12" Wheels lvhonda55 Polaris RZR Parts For Sale 1 January 11th, 2013 06:25 PM
Stock "S" wheels any good for paddles? safehaven Wheels and Tires 5 November 7th, 2010 03:55 PM
Paddles are not worth it "READ" LvDirtJunky Wheels and Tires 29 December 15th, 2008 07:47 PM
