Desertcraft filters are here!!! - Polaris RZR Forum - RZR Forums.net
 9Likes
post #1 of 42 Old March 5th, 2019, 02:32 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
Two years ago we set on a quest to develop the best air filter on the market. After several medias and independent testing we realized a combination of medias that met or surpassed the best the industry has to offer. Not only did we have the goal of offering the best filter on the market, we wanted it to be serviceable.
Having an extensive background in industrial facilities and manufacturing allowed us to think out of the box when it came to developing our filter. Severe duty filtration is nothing new in the manufacturing sector, protecting tight tolerance equipment such as turbine generators, compressors and alike is key to the longevity and extended service life. Knowing the investment that many make in their UTV's and the severe conditions that can be encountered, we wanted our customers to have the same protection that is afforded to high end industrial equipment.
While other companies concentrate on getting better flow numbers we concentrated our efforts on all out filtration! Please be cautious if a company states that their filter flows better than brand X. High flow comes at a cost, and typically equates to less filtration. If you're trying to shave a 1/10th of a second of your drag strip run then a high flow filter might be for you. If you are looking for a filter that provides superior filtration to protect your investment, then we would like you to consider our Severe Duty Desertcraft filter.
The Desertcraft filter is a dual component dry filter element that needs no special cleaners or oils. For a quick service excess dirt can be tapped off, and compressed air can be used from the inside out to further remove debris. For a deep clean, the element can be rinsed from the inside out with a garden hose, once its soaked simply spray a diluted solution of dish soap or Simple Green on the pleats and let soak a few minutes. Final rinse from the inside out and let dry completely before use.
Key Features......
 Industry leading combination of filter medias for superior filtration
 Dry element that can be serviced and needs no special cleaners or oils
 Stainless Steel exterior wire mesh support for a durable finish and unmatched strength (Most companies use no support or flat stamped steel with a painted finish)
 Internal fine wire mesh maintaining total integrity of the media layup (Went the extra step here)
 Only filter on the market that has a studded end and mounting bracket for a bullet proof / fail safe installation. (Brackets available as an option)
RZR XP1000/XPT/Turbo S Air Filter
Feel free to reach out to us if you have any questions
Name:	900S cropped 1.jpg
ID:	572518   Click image for larger version
Name:	XP1k cropped 1.jpg
Mark
Feel free to contact us at 760-955-1409 if you have any questions about any of our products.
Visit our website at Desertcraft
Like us on Facebook
dmcmark is offline
post #2 of 42 Old March 6th, 2019, 08:59 AM
cbryant_2's Avatar
My RZR: '17 XP4 Turbo
Member #8053
View cbryant_2's Photo Gallery(0)
Re: Desertcraft filters are here!!!
Thumbs up to Mark and Desertcraft. His CVT Blaster made a world of difference on my Turbo. I'm sure this is another quality product from DC.
schomakr likes this.
cbryant_2 is offline
post #3 of 42 Old March 6th, 2019, 09:52 AM
HNDARDR's Avatar
First Name: Steve
My RZR: 2016 XP 4 1000
Member #19112
View HNDARDR's Photo Gallery(0)
So this one stops most of the fine dust from getting through? I got an s&b separator and seeing that the fine dust is still getting in. I have the Donaldson filter and a cover over it and still see the dust past the filter. Hoping to find something to stop the dust. Thanks, Steve
Sent from my SM-J700P using Tapatalk
Enjoy playing in the dirt or water.
HNDARDR is offline
post #4 of 42 Old March 6th, 2019, 03:44 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
We test to sub micron levels, starting at .3 to .5 micron range. Our independent laboratory testing proved that our filter is 18% more efficient at that level.
Regards,
HNDARDR likes this.
Mark
Like us on Facebook
dmcmark is offline
post #5 of 42 Old March 6th, 2019, 04:52 PM
ParaQuader's Avatar
My RZR: '16 900 Trail EPS StealthBlack
Member #47120
View ParaQuader's Photo Gallery(0)
Any plans on ones for the 900 Trail?
FingersCrossed
Guess I shoulda looked .
Polaris lock & ride windshield, Polaris canvas roof, SuperATV rear window, Seizmik Pursuit side mirrors,
Viper Elite 3500 winch, Denali 66" Pro Series plow, UTV Giant lower doors, ATV-Guru front brush guard,
14x7 STI HD Beadlocks 4+3 / Tusk Terrabite 28x10Rx14, MudBusters fender flares, RT Pro springs,
Modified Grafix, LED Headlight bulbs, Sirius LED cube floods on A-pillar
Last edited by ParaQuader; March 6th, 2019 at 04:56 PM. Reason: link wasn't workin for me
ParaQuader is offline
post #6 of 42 Old March 6th, 2019, 05:01 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
Yep the trail is the same filter as the 900S
Mark
Like us on Facebook
dmcmark is offline
post #7 of 42 Old March 6th, 2019, 05:37 PM
XR4Honda's Avatar
My RZR: 2008 RZR, Rear Bench for my 2 boys
Member #13135
View XR4Honda's Photo Gallery(0)
What is the 10$ add bracket option? Is there a forum discount?
XR4Honda is offline
post #8 of 42 Old March 7th, 2019, 03:23 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
The optional bracket was born from racing. Simply a little peace of mind, we have seen the cover fail. Also for custom builds where the air box is deleted or just the lid. Sorry no discounts at this time.
Mark
Like us on Facebook
dmcmark is offline
post #9 of 42 Old March 7th, 2019, 05:08 PM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
09 RZR 800S isn't your target audience, but if ya had one at a reasonable price... We'd get one.
Sponsors: Dynamite Drinks, Blud Lubricants, Big Gun Exhaust, TireJect, Ryno Power, GL Performance Coatings and SuperATV.com
2009 Polaris RZR 800S
442raceRZR is offline
post #10 of 42 Old March 8th, 2019, 03:45 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
Most efficient filter on the market!!! The competitors cleanable filter is not even close, and we are more efficient than the leading throw away filter. Test data to come........
Regards,
Mark
Like us on Facebook
dmcmark is offline
post #11 of 42 Old March 11th, 2019, 03:22 PM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
Most efficient and serviceable/cleanable filter on the market! We even beat brand "D" which is a one time use disposable filter.
Regards,
Mark
Like us on Facebook
dmcmark is offline
post #12 of 42 Old March 11th, 2019, 05:43 PM
whaffner's Avatar
First Name: Wayne
My RZR: 2016 trail 900 eps
Member #16284
Feedback Score: 5 reviews
View whaffner's Photo Gallery(0)
how does this compare to the R2C??
zhoenixx and Vallone1990 like this.
whaffner is offline
post #13 of 42 Old March 12th, 2019, 09:49 AM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
There is no direct comparison..... The competitor uses a single layer media.
The Desertcraft Severe Duty filter is a dual component (2 layer) media lay up. The proprietary lay up is like no other on the market. As for filtration we start testing at sub micron levels of .3 to .5 microns and work our way up to 5 to 10 microns. Here is a snapshot of our testing...
Desertcraft
Micron range/ Fractional efficiency %
.3 to .5 - 89.6%
.7 to 1.0- 99.6%
3 to 5- 100%
Competitor R (Cleanable)
.3 to .5- 71.6%
.7 to 1.0- 95.4%
3 to 5- 99.8%
Competitor S (Cleanable)
.3 to .5- 10.8%
.7 to 1.0- 30.8%
3 to 5- 91.1%
Competitor D (Non cleanable, Disposable)
.3 to .5- 75.6%
.7 to 1.0- 94.8%
3 to 5- 99.9%
As you can see our filter does very well at sub micron levels, beating the best by a large percentage.
Regards,
Mark
Like us on Facebook
dmcmark is offline
post #14 of 42 Old March 12th, 2019, 03:31 PM
whaffner's Avatar
First Name: Wayne
Member #16284
very nice, thanks!
whaffner is offline
post #15 of 42 Old March 14th, 2019, 09:29 AM Thread Starter
Standard Vendor
dmcmark's Avatar
Member #36968
Thank you...... Our filter as well as the competitors were all tested by an independent laboratory.
Regards,
Mark
Like us on Facebook
dmcmark is offline
Tags
desertcraft , filters , filtration , rzr , severe duty
Canít find any r2c air filters for your RZR? SideBySideUTVParts SideBySideUTVParts.com 7 May 1st, 2018 03:53 PM
Stocking Distributor (R2C) Filters!!!! dmcmark General RZR Discussion 2 February 24th, 2016 02:59 PM
a little K&N filter defense totalhavek Engine and Drivetrain 26 September 1st, 2010 09:33 PM
