Upgraded Cage Material of Demon Heavy Duty Axles! - Polaris RZR Forum - RZR Forums.net
Demon Powersports
post #1 of 4 Old August 29th, 2018, 09:28 AM Thread Starter
Demon_Powersports's Avatar
First Name: Demon Powersports
Member #168049
View Demon_Powersports's Photo Gallery(0)
We've upgraded our Cage material to 4340 Chromoly!
Demon Heavy Duty axles are now more durable & stronger than ever.
Key Features:
- Dual Heat treated High strength Chromoly steel shaft
- 15%-20% increase in diameter compared to regular CV axles
- 10%-15% increase in CV joint size compared to regular joints
- 30 to 35% stronger than regular CV axles
- Double plunge which allows more suspension
- Thermoplastic polyester elastomer (TPEE) Boot
- An inboard joint is designed to allow up to 40° articulation
- Outboard joint swing from 45°-47° depending on the models
Product Catalogue: Heavy Duty Axle
DM us if you have any questions.
Follow Us on Instagram : @DemonPowersports
Like Us on Facebook : @DemonPowersports
Demon_Powersports is offline
post #2 of 4 Old August 29th, 2018, 03:30 PM Thread Starter
Member #168049
Re: Upgraded Cage Material of Demon Heavy Duty Axles!
Built with stronger components than OEM axles!
DM us or call us at +1-905-475-8383 if you have any questions.
post #3 of 4 Old August 31st, 2018, 03:43 PM Thread Starter
Member #168049
Additional Features:
- Packed with high load molybdenum grease.
- Direct OEM replacement.
Will Fit: Mostly all popular make, models of Polaris, Can-Am, Yamaha, Arctic Cat, Bobcat, CF Moto, Honda, John Deere, Kawasaki, Kubota, Suzuki.
In Stock!! Let us know if have questions.
post #4 of 4 Old June 10th, 2019, 03:15 PM Thread Starter
Member #168049
- Can Fit 2", 3", 4" and 5" Bracket Lifts/Portal Gear Lifts/A-Arms of Particular Brands
- Unique Dual Plunge Design prevents the Axles from the binding
DM us know if have any questions.
Tags
atv axles , canam , cfmoto , demon axles , demon powersports , demonpowersports , hd axles , heavy duty axles , honda , rzr axle , rzr axles , utv axles , yamaha
Demon Axles at Better Pricing!!! craigstumph Pro UTV Parts 110 January 26th, 2019 09:56 PM
Aftermarket Performance Heavy Duty Products at Demon Powersports!! Demon_Powersports RZR XP 1000 0 June 25th, 2018 02:02 PM
NEW OSP HEAVY DUTY RZR cam tensioner 125.00 sale onestopperformance RZR XP 1000 153 July 19th, 2017 07:16 AM
Polaris BLACK ONLY RZR 1000 XP HEAVY DUTY FRONT TOW AND TIE DOWN HOOK onestopperformance RZR XP 1000 64 August 19th, 2016 11:54 AM
