Assault rear bumper - Polaris RZR Forum - RZR Forums.net
 1Likes
post #1 of 22 Old May 27th, 2016, 11:49 AM Thread Starter
HNDARDR's Avatar
First Name: Steve
My RZR: 2016 XP 4 1000
Member #19112
View HNDARDR's Photo Gallery(0)
Assault rear bumper
Got my rear bumper from the Costa Mesa off-road swap meet.
Sent from my LGLS770 using Tapatalk
Enjoy playing in the dirt or water.
HNDARDR is offline
post #2 of 22 Old May 27th, 2016, 11:53 AM
pkrider's Avatar
First Name: Philip
My RZR: 2015 xp4 1000 white lightning monochorme
Member #76863
View pkrider's Photo Gallery(0)
Re: Assault rear bumper
I agree ! Great bunch of guys, the owner is extremely down to earth, and awesome products!
When you stop holding people accountable, you lose the right to lead!
pkrider is offline
post #3 of 22 Old May 27th, 2016, 03:48 PM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
Yes the owner spoke with us for a while. Talked about his trip to Dubai.
HNDARDR is offline
post #4 of 22 Old May 29th, 2016, 11:13 PM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
Bumper won't go back on with the new heat shields. What do we do now?
HNDARDR is offline
post #5 of 22 Old May 30th, 2016, 07:10 AM
pkrider's Avatar
First Name: Philip
Member #76863
Well that sucks! Bad ass bumper!! Hope you find a way
pkrider is offline
post #6 of 22 Old June 26th, 2016, 08:02 PM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
Got it installed after all. Just a little tweaking and went on.
HNDARDR is offline
post #7 of 22 Old June 27th, 2016, 05:08 AM
2015 XP 1K
Oilcan's Avatar
My RZR: 2015 XP1K
Member #66512
View Oilcan's Photo Gallery(0)
Check on the driver side front end of the heat shield where your tail light harness goes from the buggy to the lights. I had to form the heat shield down on the corner or it would have cut into the harness.... Nice bumper.
Only in Canada... Eh !
Oilcan is offline
post #8 of 22 Old June 27th, 2016, 08:46 AM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
Thank you I've been looking at that wire thinking that's going to rub through. Time to do some more bending.
HNDARDR is offline
post #9 of 22 Old July 19th, 2016, 11:33 PM
GJJack's Avatar
Member #111545
View GJJack's Photo Gallery(0)
I tried fitting an assault rear bumper today on my 2016 xp1k and the heat shield is in the way. Not sure how the top bolts go through without drilling. No instructions came with either the front or rear bumper. But should be a simple install. Ill try again tomorrow. Can you provide photos of how it bolts on the upper mount? Did you use the existing bolts? Thanks
GJJack is offline
post #10 of 22 Old July 20th, 2016, 10:16 AM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
You have to drill the top. There's already a hole on the back that you use, but you'll need to drill it through the front . I'll post a picture tonight when I get home. Heat shield I just bent up and it worked.
HNDARDR is offline
post #11 of 22 Old July 20th, 2016, 10:26 AM
GJJack's Avatar
Member #111545
I talked to Assault today about the bumper and they said that the heat shield needs to be bent.
Not an easy install.
Hndardr, how did you tweak your heat shield? Did you need to remove it?
GJJack is offline
post #12 of 22 Old July 20th, 2016, 10:32 AM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
No I didn't remove it. I just put a long screw driver under it pushed up and pulled down the outer edge with my hand.
HNDARDR is offline
post #13 of 22 Old July 20th, 2016, 10:34 AM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
I'll try and remember and post that tonight as well.
HNDARDR is offline
post #14 of 22 Old July 20th, 2016, 11:14 AM
GJJack's Avatar
Member #111545
Well I'm making progress. I hammered on the shield to bend it up and removed one rivet that was in the way. I have the lower bolts on. So now i need to drill out the uppers and install the long bolts.
And yes the cable on the drivers side needs to be zip tied out of the way. Hopefully the front bumper is easy. But I'll wait till i install the winch. Oh joy.
On the pita scale this is a 4 out of 5.
Ill take some photos.
GJJack is offline
post #15 of 22 Old July 20th, 2016, 11:28 AM
GJJack's Avatar
Member #111545
ID:	289161Click image for larger version
ID:	289169Click image for larger version
GJJack is offline
UTV INC RZR XP1K, XP TURBO & XP TURBO "S" ROLL CAGES UTV Inc. UTV Inc 139 June 21st, 2019 11:29 AM
