Assault rear bumper - Page 2 - Polaris RZR Forum - RZR Forums.net
 1Likes
post #16 of 22 Old July 20th, 2016, 12:30 PM Thread Starter
HNDARDR's Avatar
First Name: Steve
My RZR: 2016 XP 4 1000
Member #19112
View HNDARDR's Photo Gallery(0)
Re: Assault rear bumper
That's what mine looks like. I put some velcro tape down on the bumper so the shield has some padding and doesn't scratch or rattle.
Sent from my LGLS770 using Tapatalk
Enjoy playing in the dirt or water.
HNDARDR is offline
post #17 of 22 Old July 20th, 2016, 12:47 PM
GJJack's Avatar
Member #111545
View GJJack's Photo Gallery(0)
Complete.
I think it looks great with the assault tire carrier.
GJJack is offline
post #18 of 22 Old July 20th, 2016, 01:20 PM Thread Starter
HNDARDR's Avatar
First Name: Steve
Member #19112
Originally Posted by GJJack View Post
Complete.
Attachment 289225
Looks great.. 👍 👍 👍
HNDARDR is offline
post #19 of 22 Old February 21st, 2017, 08:21 AM
Webone's Avatar
First Name: Webb Farrer
My RZR: 2015 RZR XP1000 4
Member #178001
View Webone's Photo Gallery(0)
Doesn't the heat shield now vibrate on the Bumper?
Webone is offline
post #20 of 22 Old February 18th, 2018, 04:46 PM
motoracerx's Avatar
My RZR: 2018 XP Turbo
Member #109961
View motoracerx's Photo Gallery(0)
I installed this bumper on my '18 XPT today.
The heat shield that had to be bent up on previous models, is not an issue on at least the '18's. It was already bent up from the factory.
Did have an issue with the lower mounting nuts that came with the bumper. There is literally no room for the supplied nut with the large flange on it, to fit on the supplied bolt at the bottom of the down tube of the roll cage. I had to use another nut that didn't have the large flange.
I had to tape the nut to a box end wrench and hold it at the mounting hole and then thread the bolt to it. I could not get my fingers in between the axle/cv boot to hold the nut. Once you get the bolt started, take the box end wrench off or you wont be able to get your wrench out without loosening it up. The wrench will get stuck behind the bolt and the roll cage.
Also had to remove the OEM plastic bumper in order to drill the top 2 mounting holes.
Somewhat of a PITA, but it's on. I hope that the Polaris HL radius arms i have coming will fit with this bumper.
It's a heavy duty bumper, with a clean simplistic look.
motoracerx is offline
post #21 of 22 Old April 24th, 2018, 11:43 AM
JJRZRguy's Avatar
Member #95801
View JJRZRguy's Photo Gallery(0)
Do you have any idea how much this bumper weighs? I think it's the best looking and the most functional one out there... I hope so anyway! Thanks for posting this thread.
JJRZRguy is offline
post #22 of 22 Old April 24th, 2018, 12:18 PM
motoracerx's Avatar
Member #109961
I don't believe it's over 20 lbs. Maybe 15. Give Assault a call, they should know.
I agree with the looks and it sure seems to be of great quality.
And the Assault bumper was not an issue for the Polaris high clearance radius arms to fit.
JJRZRguy likes this.
UTV INC RZR XP1K, XP TURBO & XP TURBO "S" ROLL CAGES UTV Inc. UTV Inc 151 August 13th, 2019 03:04 PM
